73-77 A-body TECH Includes 73GTO, LeMans, Grand Am, Can Am
Old 04-09-2012, 06:19 PM
77 Canamman's Avatar
Thumbs up 1973 4 speed GTO
On the Bay.. A board member owns this car. Featured in Hemmings Muscle Machines. I have seen this car several times, and its great example.
http://cgi.ebay.com/ebaymotors/1973-...72f43708#v4-43
2017 Sierra SLT 1500 Z71 4X4
2019 Canyon SLT Crew 4X4
Old 04-09-2012, 09:10 PM
LEADSOLO's Avatar
LEADSOLO LEADSOLO is offline
Thank you, Sir!!
Old 04-09-2012, 10:07 PM
tabob tabob is offline
Very nice. The enine compartment is immaculate.
72 TA 4 speed
76 TA auto father/son project
Old 04-10-2012, 10:09 AM
The Boss's Avatar
The Boss The Boss is offline
Nice rare car!
And go racin' in the street.
Old 04-10-2012, 12:57 PM
Brian Baker's Avatar
I see it's developing the usual bubbles under the vinyl top...mine did the same thing...the factory just did no prep or sealing to the roof on cars getting a vinyl top.
Also, what's up with the nose filler between the nose and the bumper? Looks like it doesn't fit proper in the center.
Old 04-10-2012, 09:00 PM
Wink
This factory shows a GTO with a large filler gap. The one on LEADSOLO's car looks about on par.
Old 04-11-2012, 12:18 PM
Another one:
http://cgi.ebay.com/ebaymotors/1973-...item4602be9ced
ROUGH is the word for this one. This one would need a solid donor car to bring it back..
This is a rare 1973 GTO factory 400 4 Speed with factory console, rally gauges, Sport steering wheel, Rally II rims, and posi. rearend. The drivetrain is complete from carb. to rearend, even has original reverse switch on muncie trans. Motor WP code does run but is not drivable. Alt. is frozen, gas tank is disconnected, and tires are dry rotted. Here is correct VIN# 2F37T3P193XXX. Could not change on ebay. To answer any questions about rust YES everywhere, will need qtrs., hood, fenders, etc., frame is solid. glass is good. PHS documented and is only 1 of 926 made in 1973 with manual trans. and even less with optional muncie 4 speed. More pictures available on request, dial up is tough on uploading. Can deliver in local area.
Last I knew, the reverse switches were always column mounted in '73. He must be mistaking the TCS switch for the reverse switch.
Old 04-11-2012, 04:07 PM
scott w's Avatar
scott w scott w is offline
And all that "roughness" is just what is easy to see, imagine what is hidden??? And wow look at that current bid price and he has a reserve, he may want to take the money and run.
Wanted 1977 Can Am forgotten projects or parts cars, other 73-77 Pontiac A-bodys, also 4-speed setup for 73-77 GTO, Grand Ams, CA e-mail me [email protected] with info. Buy Sell or Trade --------------------------------------
Old 04-11-2012, 08:07 PM
pete315 pete315 is offline
He is referring to the reverse lockout mechanism that usually got removed when an aftermarket Hurst shifter was installed. It's mounted of left side frame rail.
73 Grand Am 455 Muncie M20 4 speed 3.23 gears
Old 04-11-2012, 09:11 PM
Pete, that makes sense. When I bought my GTO, the reverse lockout/ backup lamps were inoperative. All of the parts were present except for the rod that joined the reverse lever on the much superior replacement Hurst shifter to the mechanism on the frame. I modified a F body rod, and it works perfectly, and looks 100 percent factory.
Old 04-12-2012, 02:50 PM
2 years ago I lucked out and bought a brand new in box original ITM shifter for my Grand Am. Must have been in the box for 30 years. Have to pull up on lever to get into reverse. I know Hurst are great shifters, no question about that. However, this ITM shifter has a perfect throw and shifts like slicing through butter. The reason why people removed the reverse lockout when a Hurst was installed was because the factory shifter levers would not fit on the Hurst shifter. The original reverse shift lever was longer and had an extra hole on bottom. The bottom hole is where the reverse rod was mounted. When car was shifted into reverse to back up or to remove the key from the ignition, this reverse rod was moved, causing the swivel to turn,causing the upper rod connected to the steering column to move. Pretty simple design. On a side note, I should be getting my 455 from the rebuilder soon. Can't wait until I drive this Grand Am with the 455.
Old 04-13-2012, 09:14 PM
Thumbs up
Should be a lot of fun, Pete!
Old 04-16-2012, 10:22 PM
SOLD for $1643.. a good price for a complete 4 speed setup, then part/scrap the rest.
Old 04-17-2012, 02:44 AM
LEADSOLO's Avatar
Sold for $14,000.
Old 04-17-2012, 08:15 AM
Question
Originally Posted by LEADSOLO View Post
Sold for $14,000.
To a board member? Wonder if I will see it at Carlisle again?
Old 04-18-2012, 01:18 AM
LEADSOLO's Avatar
Not a board member, but belongs to POCI.
Lives in CT, so Carlisle might not be in the future, but he plans on going to local and regional POCI meets with the goat.
Old 05-11-2012, 08:49 AM
pontiacjeff pontiacjeff is offline
Anybody notice the 70-72 custom sport wheel in the blue car? Whats up with that? The white car had the later custom sport wheel in it.
And the main reason the reverse back-drive control rod was removed was to install headers!
Jeff Ianitello
Old 05-11-2012, 08:57 AM
Most 1973 GTO's have the 1970-72 Custom Sport wheel if optioned that way. It was one of the very few carryovers from the previous generation.
Old 05-11-2012, 09:09 AM
interesting. Why so, if the grand am and gp got the new one? I guess they wanted to delete the old stock of the other wheels? HAHA!
Jeff Ianitello
Old 05-11-2012, 10:04 AM
Don't know the reasoning. None of the GP's or GA's received the small hub Sport wheel.
