Old 04-01-2012, 06:22 PM
SHAWN MILLER's Avatar
SHAWN MILLER SHAWN MILLER is offline
Thanks,I ran the engine in my Trans Am race car for a few years.It ran high 10s with a best of 10.82.Its got 9.3 comp so I can still run pump gas and its fairly street friendly.I had to do alot of work to those 660 Holleys to get it there-LOL.Its a blast on the street.
Shawn
67 GTO 455,Super T-10,Wenzler Ram
79 Trans Am 455 Pro Stick Racing
2005 Thunder Mountain Blackhawk 103"
2019 Street Glide 114"
  #502
Old 05-03-2012, 06:05 PM
garyp2 garyp2 is offline
Smile 67 Lemans ragtop
Here is mine. Painted over 4 years ago. Spotts built motor going in. Just finished s/s custom brake lines in order to move the Dist. valve back to clear headers and add lineloc.
Finally starting to work on it again. Excited to get moving after seeing Paul yesterday.
Name:	2012-01-24 16.56.29.jpg
  #503
Old 05-03-2012, 06:09 PM
Default Another pic of my 67
Modified tunnel for Tremec TKO 600
Name:	2012-01-24 16.57.16.jpg
  #504
Old 05-03-2012, 07:34 PM
instg8ter instg8ter is offline
here is my lowly Tempest Custom after an 8 month restoration....
http://s1098.photobucket.com/albums/...966%20Tempest/
  #505
Old 05-03-2012, 08:46 PM
goatwgn goatwgn is offline
Thumbs up
Instg8ter, That '65 interior looks pretty sharp in that '66. The '65 seat pattern is actually my favorite. Nice looking car from every angle.
  #506
Old 05-03-2012, 08:47 PM
Thumbs up
Garyp2, that convertible is going to be great when you are finished. Keep us posted.
  #507
Old 05-03-2012, 09:44 PM
thanks they are actually pristine Corvair seats that i picked up for 200.00, much cheaper than ratty "GTO" seats and the same bases and i also think the 65' pattern was the best interior. This was a budget build...if there is such a thing, I used what i had and what i could trade for or find cheap. And the 326 is in mothballs in the shop in lieu of a forged, roller cammed 463 soon to get new low profile dual quads.
Name:	dual 600's.jpg
  #508
Old 05-04-2012, 12:50 AM
GT182's Avatar
GT182 GT182 is offline
Very nice looking Tempest Custom Instg8ter.
Would you happen to have any photos of the Ram Air setup where it's attached at the front of the car? Looks great from the core support back.
Gary
Get in, ShuT Up, Hang On!
"Crusin' Is Not A Crime"
Keep yer stick on the ice.
  #509
Old 05-04-2012, 07:24 AM
Thanks GT182, they are run to pick up from under the inner fenders right now, i was planning on taking the high beams out and forming some screen from a 67' grill into a domed cover for the holes to mimic headlights, have seen some old drag cars that were set up this way. As soon as i get the stroker back i will be setting up the dual quads so the Ram Air will be used on the next project....thinking 69' firebird coming soon. They do supply mounting cups that would mount on the firewall but tried to avoid cutting holes in anything.
  #510
Old 05-04-2012, 07:45 AM
arbys's Avatar
arbys arbys is offline
You may want to check this out. I used a 12" x24" for my speedster and was about $50 including $5-6 for shipping. Great company to deal with:
http://www.mcmaster.com/#standard-wire-mesh/=hdxfww
  #511
Old 05-04-2012, 10:13 AM
Beautiful car instg8ter. Can you post more pics of that air intake set up??
  #512
Old 05-04-2012, 06:50 PM
you the man Arbys, been looking all over for that stuff...i wish they made an elongated air cleaner for the duals i really like the Ram Air set-up. I will take some pics when i get the motor back in and do the headlight swap, at that time i will put low/high beam halogen single light system in. Whole theme of the build was not so much original as to embody the spirit Pontiac innovations on a limited budget. Used B&M quicksilver shifter modified to fit the console instead of the outrageously expensive His/hers. Molded a 3 gauge pod into the dash pad before i re-stretched it. Did all the work including paint myself over a Michigan winter....photobucket has pics of the whole resto. If you wanted to drill two 3" holes in teh rad support right next to the flange the cups would fit right behind the grill and ducts would be nice and neat.
Might try to make the POCI event OldBlue, I Worked in St. Charles for a minute....still miss me them Italian Beefs, Portillo's, and St. Pauli Girl beer
here is the system from Spectre with the solid stainless ducts...
http://search.aol.com/aol/imageDetai...old+air+intake
  #513
Old 05-04-2012, 07:52 PM
arbys's Avatar
Maybe it's the era that I grew up in but i always liked those stone guards for the headlights. They made the cars look racey especially with the "stacked" headlights.
  #514
Old 05-04-2012, 09:57 PM
imposter's Avatar
imposter imposter is offline
is that a P/S cooler under the bumper or Trans cooler
  #515
Old 05-04-2012, 10:14 PM
I remember them from the old Comet FX drag cars that took air in through one headlight bucket. Auxiliary trans cooler is up front, making some brackets to tuck it up just behind the radiator.
  #516
Old 05-05-2012, 06:40 AM
I mounted the same kind of trans cooler in the same place. Seemed to work better over all than mounting the one in front of the condensor. Painted mine black.
  #517
Old 05-05-2012, 10:41 AM
I agree Goatwgn, i still have it running through the radiator and then the trans cooler ...biggest reason for trans failure is heat so i figure any help i can give it will extend the life and is cheap insurance.
  #518
Old 05-06-2012, 06:19 PM
Have mine running through the radiator and then that one as well. It also increases fluid capacity about 1.5 quarts.
  #519
Old 06-05-2012, 09:56 PM
GoatandBirdCollector GoatandBirdCollector is offline
Default Goats on the O C Boardwalk
Here's a couple pics from the recent Ocean City Cruise weekend.
Must have been a record for attendance as we were stuck for a half hour on the board walk Friday morning waiting for the inlet parking lot to open & then it was full by the time we got there. Ponchos were well represented.
Name:	OC Cruise 12 & Vegas 005.jpg
ID:	286781   Click image for larger version
Name:	OC Cruise 12 & Vegas 003.jpg
ID:	286782   Click image for larger version
Name:	OC Cruise 12 & Vegas 006.jpg
  #520
Old 07-29-2012, 12:18 AM
chiropaul chiropaul is offline
Default 1967 Tempest LeMans w/400cu motor
Hi my name is Paul and this is the 67' Tempest I just picked up last Saturday. Pontiac 400 motor from a 70 Firebird is runnin like a champ!!
ID:	292733   Click image for larger version
ID:	292734   Click image for larger version
ID:	292735   Click image for larger version
ID:	292736   Click image for larger version
