#61
Tod Hoffmann 1966 GTO Montero Red Hardtop - Holley EFI'd 462, KRE DPorts/Muncie 4spd 1990 Chevy 454SS pickup - Accel DFI/T56 6spd - Hot Rod Power Tour Long Hauler 1996 Chevy K2500 ECSB 'Poopy' 2002 Honda VTX1800C 2016 Cadillac CTS Premium My project thread: http://forums.maxperformanceinc.com/...d.php?t=516826 |
#62
Hey Mario65,
In post #45 you said, "FirebirdMI thanks for your work and time on this. I know we all are going to get alot of it. I really hope it works for you. I have been rediculously patient. I am getting the bug again. I dont want to spend 4k on wheels and tires if I think I can get a Rally II look to work. Heres my current stance and look: http://transams.net/MariosCollection...rd_400.html#16 Heres the stance I and look I want. I would much rather have a Rally II wheel do it than aftermarket wheels. http://i168.photobucket.com/albums/u...p/DSC_0125.jpg Do you happen to know what those wheels/tire size are? I too like that look very much. Any ideas. Just wondering. |
#64
Sorry I didn't get back, Just saw the post. "17x8 4-7/8 backspace on front and 17x11 5-1/2 backspace on rear. 245/45/17 and 315/35/17 bfg KDs . DSE mini tubbed All DSE front end, coil over relocation, koni's, DSE UCA/LCA etc. Back is DSE 3" drop leaf w/offset shackle, so basically its lowered 3". No problem with front rubbing, I could pick it up another 1/2 inch but I like the stance."
TransAM Depot The Judge GTO Coupe prototype, DUCATI ST4s DP, Buick Turbo T WE4 not stock. |
#65
Has anyone seen these with some 50 or 55 series tires on an A body yet?
#66
Also can I get away with running 255's up front and 275's out back. The suspension is pretty much stock, but I plan on changing that after I get an idea of what I can do and still fit the tires.
1970 Lemans 350/ TH350 ProTouring Madness |
#67
I called them yesterday and still no news on the 8"
#68
I think I am just gonna bite the bullet.
275/40/17 Drag radials on the back 245/40/17 on the front Worst case they'll stick out a little
#69
Did they give you any time frame for the 8"?
#70
nope they don't have a clue
#71
If you want the approx same size on the front and back, it would be 245/45/17 front.
#72
to anyone who is running these now, I got mine and it looks like I need longer studs. I'm afraid the lug nuts don't have enough thread to bite on.
#73
how many turns are you getting I think you need 5 or more
#74
if you still feel like that's not going to work you can get ET style loves that will help. I have used them with half inch spacers
#75
Would these work? http://www.summitracing.com/parts/BSP-999970/?rtype=10 Last edited by DevoBuzz; 05-03-2012 at 05:56 PM. |
#76
I'm going to see if the ET lugs will work. Other wise I'll just put new studs in.
#77
I just got my new year one rally 2s
I used the same bfgoodwrench kdw nt 275/40/17 tires. The rears are fine , but the fronts rub on the front and back of the fender . Any suggestions would be awesome. |
#78
I just put mine on the car. I have Nitto 555's with 255/45-17 on the front and 285/40-17 on the back. That gives me a 25.94 inch tall tire both front and back. The lug nuts do not inhale the studs anywhere near enough. I going to switch the studs for longer ones because I don't think a set of ET lug nuts would fit. I'll post a picture of them on the car later.
#79
just put mine on , had to go with 245/40/17 front, 275/40/17 rear
i dont think anything else would fit upfront |
#80
Those look pretty awesome!
![]() 1970 GTO 458 CID .040 over 4 Bolt 428 Block, Forged Eagle 455 Crank, 295 CFM SD KRE D-Ports, SD Old Faithful HR Cam + Comp HR Lifters, PPR Maxx-lite rods, Racetec pistons, PRW 1.65 SS Rockers, 900CFM Holley HP TBI, Performer RPM, Hooker Super Comps, 3" X-Pipe into 2.5" mufflers/tailpipes, 2.75 1st TH400, Continental 13" Converter, 8.5" 3.08 Posi. Everything installed, fired up and tuning has begun! |
