Old 05-20-2012, 11:03 PM
Nickv's Avatar
Nickv Nickv is offline
Default 67 gto driveshaft with 12 bolt rear and th400
I have a 67 GTO with TH400 and 12 bolt Chevy rear. I've seen driveshafts for 66-67 chevelle, th400 to 12 bolt rear, will it fit?
"Everyone is entitled to be stupid sometimes, but you're abusing that privilege"
www.musclecargalore.com
[www.reverbnation.com/nikivee
1967 Pontiac GTO
1967 Pontiac Grand Prix
1972 Pontiac Lemans Sport Convertible
2015 Dodge Challenger Scat Pack 392, 6 speed
2021 Ford Explorer
Old 05-20-2012, 11:23 PM
Yes.
Both cars ride on essentially the same chassis.
Transmission placement in the frame is the same for Pontiac and Chevy, so the driveshaft length is the same as well when using the Chevy 12-bolt rear.
Old 05-21-2012, 12:24 AM
Kenth's Avatar
Kenth Kenth is offline
With a conversion U-joint your original driveshaft will fit.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 05-21-2012, 11:03 AM
Tim Corcoran's Avatar
You may use Chevelle, Cutlass, Skylark as well. Any GM A body of the correct years from your local junk yard should have a nice selection.
Tim Corcoran
Old 05-21-2012, 01:05 PM
Nickv's Avatar
Thanks guys.. My orginal driveshaft which was the correct one was sheared off when my transmission grenaded. :-), so I need to replace it with a complete new one along with a new TH400 and who knows what else once I get the car apart to see the real damage. I'll post some pics later for your viewing pleasure. :-)
1967 Pontiac GTO
2021 Ford Explorer
