Old 07-07-2012, 07:57 AM
3tas4me's Avatar
3tas4me 3tas4me is offline
The car is stock, so it has the 3.23 gears. I am not looking to set the world on fire here, just want to make it run the best it can for what it has, which is definetly not the case right now. The dual exhaust alone should have woke the car up to some extent. It is the mid-throttle where the car seems to not run good. Light throttle seems fine as well as heavy throttle.
1970 Trans Am
1971 Trans Am
1974 Trans Am
1978 Y88 Trans Am W72/auto
1979 10th Anniversary Trans Am
1984 Trans Am
1996 Trans Am WS6
1999 30th Anniversary Trans Am
2001 10th anniversary Firehawk #104
Old 07-07-2012, 08:00 AM
johnta1 johnta1 is online now
Is your car an automatic?
A higher stall converter would wake it up also.
Old 07-07-2012, 08:40 AM
rad400 rad400 is offline
Rex RAIII heads were #12s not 670 heads 400 HO.
Conrad
79 Trans AM 406 #12 heads Torker II intake Crower 60210 750 holley vac. sec. T400 3500 Stall 3:73:1 rear. ECMTTFMFers. IHTTFMFers.
Old 07-07-2012, 10:54 AM
2manyT/A'S's Avatar
The stick is "the given" in this equation....
ALL 79 W72's were sticks.
Eye Candy......garage band?
Go full screen & turn it UP!
Old 07-07-2012, 11:22 AM
2manyT/A'S's Avatar
I have several 78 W72 4 speed T/A's that are reasonably low mileage & basically STOCK,other than true dual exhaust (2 1/4") with set up carbs & HEI's and am VERY happy with MY butt dyno readings.....(78 W72 sticks came with 3:42's)
They DO pull pretty HARD & run GOOD but obviously the stock camshaft is holding them back.
You can probably bump your initial to 19.
Did you check for timing chain slop?
Is your stock EFE valve in place still? (and working?)
Old 07-07-2012, 01:01 PM
3tas4me's Avatar
Ok, here is what I did. I pulled the stock 17059263 carb off and replaced it with a 17056263 that I have that is in good condition. I opened it up first and set the float level to 5/16 per HO Racing specs in the "Supertuning the Quadrajet" article. I checked the jets and metering rods and recorded what they are. The jets are 70 and the primary rods are 42K. When I removed the original carb, I noticed that the bolts were loose. Since the car acted like it was lean, this was a good indication that it probable was. I bolted the 17056263 carb on after cleaning and blowing it out. The car now runs like it should. Burned rubber as long as I wanted to in 1st gear when stomping on it after taking off. Pulled all the way to redline without a hint of pinging or any flat spots. I am now going to take the top off the 17059263 and record the jets and metering rods. I am also going to set the float level to 5/16, factory spec is 17/32 which is much lower! It is clear now that the car was having some carburetor issues. I will get the carburetor sorted out and then want to play with the timing advance.
1970 Trans Am
1971 Trans Am
1974 Trans Am
1984 Trans Am
1996 Trans Am WS6
Old 07-07-2012, 09:23 PM
Zirconia Zirconia is offline
Default W72 is fast.
Originally Posted by 2manyT/A'S View Post
Leave your stock exhaust manifolds on........the Ram Air manifolds look COOL but really don't add much,if ANY performance....There are guys running 12's through the log style manifolds.
Beyond carb tuning & dist. recurve for MAX performance,I'd toss in a 068 factory grind cam. (455 HO) It will support an A/C compressor at idle & will wake that engine RIGHT UP.
I swapped out a set of RAIII Manifolds on a 73 455 automatic and gained a tenth of a second! Not statistically significant. You can get more of a power boost (up to three tenths) by cooler ambient air.
In box stock form breathing through the single catalytic converter, a W72 should, seat of the pants, feel no more than a tic slower than a RAIII. Check out the first car, a box stock Martinique Blue 78 W72 in my Movie This car has the original pellet style single cat:
http://www.youtube.com/watch?v=aLf5a5gejUI
Old 07-07-2012, 10:49 PM
3tas4me's Avatar
Here is what I found with the original carburetor. When I pulled it off the engine, I found a pile of small black pieces. Figured out they came from the charcoal canister. The picture attached shows some of the pieces on the cardboard. Cleaned out the carburetor, reinstalled and tuned it. Runs much better now. I still think there is more to be had however. I set the float to 5/16, which is a much higher setting than the 17/32 that the service manual calls for.
1970 Trans Am
1971 Trans Am
1974 Trans Am
1984 Trans Am
1996 Trans Am WS6
Old 07-08-2012, 04:11 AM
2manyT/A'S's Avatar
Enjoyed your vid... The 78 does pull pretty strong,what RPM were you shifting at?
(sound like you might have short shifted into 3rd a few times}
Old 07-08-2012, 10:28 AM
Generally speaking I don't rev these cars past 4k. Most shifts were in the 3.5k range. Definitely had a few gears left on the martinique blue/black custom 78. Lots of things that sound good on paper (headers) don't necessarily work on these cars.
75 has stock 3.08 rear gears with close ratio t-10 and 2.43 first gear. Sounds terrible on paper, but this is a great combo on the street/road. Plenty of low end torque. Running only 2k at highway speeds.
Old 07-08-2012, 04:26 PM
3tas4me's Avatar
Still looking for that HO Racing information if someone has it.
1970 Trans Am
1971 Trans Am
1974 Trans Am
1984 Trans Am
1996 Trans Am WS6
Old 07-11-2012, 01:55 AM
Default HO article
Here is the data from the mods. Car was a 1977 Trans Am TA/6.6 Automatic, most luxury options (cruise, a/c, etc.). 3.23 rear gear. Data is for 0-50 mph in sec.
Stock baseline 7.0
H-O Power Kit (basically carb rejet) 6.6
H-O Accuracy Kit (dist recurve) 6.5
H-O High Lift Kit (1.65 rockers) 6.2
Tri Y Headers & CrossFire Muffler 5.4
Raise 1-2 shift 4.6k to 5.0k 5.2
To get an idea how your car should run (maybe a tick slower since this is a RAIII) please view my latest test drive video:
http://www.youtube.com/watch?v=8aBrM...hannel&list=UL
Old 07-11-2012, 06:10 AM
Zirconia that is a bad azz RAIII T/A.
Conrad
Old 07-11-2012, 09:50 AM
FrankieT/A's Avatar
In my opinion the only thing that's gonna wake up that car is another point in compression. Compression is directly proportional to acceleration. Maybe a set of 62's so as comp is not too high but still large valve. Don't forget those pistons are chamfered as well as a large chamber head.
I know you said you didn't want to change anything, but if want to make an omelette, you have to break some eggs! JMO
Old 07-11-2012, 09:59 AM
I think what he is doing is just fine.
Conrad
Old 07-11-2012, 10:01 AM
3tas4me's Avatar
Car is running really good now that the carburetor is sorted out. If nothing else, it is at least performing as well as when it was new and I would bet slightly better with the dual exhaust. If I get a chance, maybe I will hook up my Gtech and run it.
1970 Trans Am
1971 Trans Am
1974 Trans Am
1984 Trans Am
1996 Trans Am WS6
Old 07-11-2012, 10:49 AM
Thank you. Not mine, a fellow TA enthusiast stopped by and showed it to me. He scared me. And pushed me back in the seat. Point is, properly runnning TA6.6 should be almost as fast.
  #38
Old 07-11-2012, 02:59 PM
3tas4me's Avatar
I would actually disagree, stock for stock, a W72 should be about .7 -1 second slower in the quarter than a Ram Air III if you believe the period road tests.
1970 Trans Am
1971 Trans Am
1974 Trans Am
1984 Trans Am
1996 Trans Am WS6
  #39
Old 07-11-2012, 03:06 PM
ta man ta man is offline
More compression would help..have the heads been milled?
  #40
Old 07-11-2012, 04:42 PM
We are actually in agreement. As I mentioned previously, W72 is about "a tick" slower or 1 sec. slower.
