Fan clutch
Advanced auto fan clutch is crunchy , did not last very long [100 miles] .What is a good fan clutch to get for my 64 GTO 461 cu.in. Kauffman heads , tri-power , roller cam ? What year vehicle application for a replacement . thermal vs. non thermal ? thank you
fan clutch
the HD unit i got from NAPA is good. I put mine in last year and have close to 1000
miles on it and it pulls good. this is the hayden unit i believe its the 2797 unit. ran her today and never hit 190 and had zero issues with hot restart.\ Gerry
1968 Firebird 400, 068 cam, TH400 & 13" Continental Converter, Auburn posi with 3:08 factory gears, Cliff's Q-jet resting on a 68 factory iron intake, DUI HEI and Ram Air pans and RARE Long Branch Manifolds |
That is good , will look it up . thank you
Yes, the Hayden Thermal HD is the way to go.
Pricey, but will last a very long time. Try Rocks or Summit too. Much Cheaper. Tip: Use studs to install.
........I'm just learning as I go....... |
I recently bought a 2797 for my Bonneville thru O'Reilly's, and it was $60. Well worth it...
Eric "Todd" Mitten '74 Bonneville 4dr Sedan (455/TH400/2.93 open) '72 LeMans GT (455/M-13/3.23 [8.5"] posi) '71 GTO Hardtop (400/TH400/3.07 12 bolt posi) ‘71 GTO Convertible (455HO/TH400/3.23 posi) '67 GTO Coupe (455/ST-10/2.93 posi) '67 Tempest Wagon (428/TH400/2.56 posi) Deuteronomy 8:3 |
Bought a Hayden,check Amazon IIRC,they had the best price.
Made in USA too. |
ebay has them for just over $56 with free shipping.
1973 Formula 400 4 spd 04C build date Norwood assembly plant. |
Thank you all , got one . $62.00 Napa , lifetime warr.
