Pontiac Business Entities Exchange Sources, Compliments and Grievances in regard to Pontiac parts or services rendered by an individual or business.
Old 09-10-2012, 09:24 PM
gunmetalgray67's Avatar
gunmetalgray67 gunmetalgray67 is offline
Default Engine work in central Pennsylvania
I need some work done on my Pontiac here in central Pennsylvania. Hopefully near Harrisburg. I need someone to check out the engine while in the car. I do not want to pull it if possible. Compression check, leakdown, adjusting valve lash, carb, timing, etc.
Looking for someone with Pontiac specific knowledge. Engine was built near Pittsburgh by Gary Cygan (Cygan Speed Engineering). He has done several articles in High Performance Pontiac. Very happy with motor. I do not have a place to work on it.
Also, I need my car inspected.
Any help would be appreciated.
1967 Lemans convertible
467 SD ported E-heads, custom solid roller, 606 Dynoed HP
4-speed, full PST poly suspension, Hotchkiss 1 inch lowering springs, 16 x 8 GTA rims
Old 09-13-2012, 09:57 PM
robscar's Avatar
robscar robscar is offline
Have you contacted Racekrafters in Lancaster. They have done many feature articles in HPP.
Old 09-13-2012, 09:59 PM
robscar's Avatar
Default Engine work
Have you considered Racekrafters in Lancaster? They have done several feature articles in HPP.
Old 09-26-2012, 06:44 PM
Yes I contacted Racekrafters and set up an appointment. Unfortunately, I couldn't get one until the end of October.
Smilies are Off
