Old 10-01-2012, 11:31 AM
TA-71 TA-71 is offline
Default WD-40 Rust Remover?
Has anyone used this new WD-40 product? http://www.wd40specialist.com/products/rust-remover
1971 Trans Am - Sold
1977 Can Am - Sold
2002 Trans Am Firehawk - Sold
2004 GTO - Sold
2006 GTO - Sold
1970 GTO - Sold
1972 Trans Am - Sold
1970 Trans Am - Current Project
Old 10-01-2012, 12:45 PM
Old Goat 67's Avatar
Interesting!
Old 10-01-2012, 01:58 PM
Sirrotica's Avatar
Cider vinegar is probably just as good and cheaper too.
Also a bath of water and baking soda with a battery charger with a sacrificial cathode will dissolve rust quite well too.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 10-01-2012, 03:04 PM
JUDGEMAN70 JUDGEMAN70 is offline
Go to Auto zone and buy a gallon of Evao rust for $20 per gallon. Works great for soaking small parts in.
Old 10-01-2012, 03:05 PM
I have heard of the baking soda-battery charger thing, but I thought that altered the metal some way, perhaps not in a good way?
1977 Can Am - Sold
2004 GTO - Sold
2006 GTO - Sold
1970 GTO - Sold
Old 10-01-2012, 08:26 PM
69Customs's Avatar
69Customs 69Customs is offline
I believe WD 40 uses silicone and it don't get along with paint. So your asking for trouble.
Old 10-01-2012, 08:46 PM
Birdguy's Avatar
Birdguy Birdguy is offline
X2 on the Evapo-Rust. I find it at Orielly's and Harbor Frieght.
Old 10-02-2012, 08:49 AM
Tempest's Avatar
Tempest Tempest is offline
here is a link to the baking soda/battery charger method. (hope it works)
http://www.videojug.com/film/how-to-remove-rust
Old 10-02-2012, 08:51 AM
Sirrotica's Avatar
I've used it and have never had any problems with it welded on it after stripping the rust and it welds fine. It's the same system used by the commercial rust stripping services (Redi Strip) and I had the subframe stripped on my 73 T/A in the late 70s with no ill effects. It's just a plating procedure with polarity reversed and plating parts has no ill effects on parts. It is used on tools and machinery to remove rust so I can't see where it would have any effect on the parent metal in any way.
The process is used by archeologists to clean ferrous metals when found in the soil so it is very delicate to the parent metal and will preserve details much better than any acid based cleaning which will remove metal from the rusted object.
http://myweb.tiscali.co.uk/andyspatch/rust.htm
http://www.stovebolt.com/techtips/rust/electrolysis.pdf
Also many videos on YouTube about how to use the process.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 10-02-2012, 09:17 AM
65Mark 65Mark is offline
Make sure you use washing soda, not baking soda. Also if you use distilled water or RO water you won't get the chemical reaction with the residual chemicals in the water.
Old 10-02-2012, 09:37 AM
Sirrotica's Avatar
If washing soda isn't readily available baking soda can be used, I have used baking soda and it works, from what I have read about it washing soda is preferred and works better read more efficiently than baking soda. They are however interchangeable.
Excerpt from material list:
electrolyte to cause a chemical reaction. This reaction loosens the rust particles from the base metal so you can easily scrub it off and use the tool or car part underneath. The vat in which you will perform the electrolysis should be plastic, preferably a storage tub or bucket, one to five gallon capacity. According to an article by Ted Kinsey at StoveBolt.com, never use a metal bucket or trash can. There may be a danger of electrocution, toxic fumes and undesirable results with your project.
Electrolyte solution is a fancy way to say water with something added to help it conduct electricity better. Most people use washing soda (sodium carbonate) or baking soda (sodium bicarbonate). The difference is simply one carbon atom, and the general consensus at StoveBolt.com and RicksWoodshopCreations.com is that the performance is similar if not identical.
The most readily available electricity source is a 10-volt car battery charger. You will want one with a voltage meter so you can easily see if the current is getting through the rust to the metal underneath.
Finally, you'll need an anode for the rust ions to run to when they leave the tool or part you want cleaned. This can be a steel or iron cookie sheet, pan lid, or other piece of steel or iron that has a larger surface area than the rusty tool.
Read more: Complete Instructions on Removing Rust Using Baking Soda & Electricity | eHow.com http://www.ehow.com/way_5980277_comp...#ixzz289I79ViE
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 10-02-2012, 07:06 PM
My442 My442 is offline
I am a user of the WD 40 Rust Soak.
Right now, I have a parking brake pedal assembly soaking in it.
Last week, I took all of the innards of a A/C heating box (all unpainted), and soaked them over night.
100% of the rust is gone - looks like new metal.
Old 10-02-2012, 07:43 PM
PMD1969's Avatar
PMD1969 PMD1969 is offline
A gallon of that stuff is $35 plus tax . Many years ago I used the baking soda / charger method on an exhaust manifold and it worked well. I did have to use an expendable cooking sheet and a LARGE RubberMaid tub. The OHC manifolds are not small.
69 OHC ZH Sprint Hurst 3 Speed 3:55 (1 of 213)
99 Valkyrie 1520cc Flat 6 108hp/110tq - For Sale
http://sohcsix.yuku.com/forums/1/OHC-lounge
Wanted: 1969 OHC "H" Camshaft
