Old 09-23-2012, 10:40 PM
irismistgto irismistgto is offline
Default Need 1965 Automatic Transmission
Hi,
I am looking to get a 1965 Automatic 2-speed transmissioin for my 1965 GTO. I am hoping something with a date code of December 1965 L??4. Please let me know if anyone has one.
Phil
Old 09-26-2012, 08:51 PM
Cammer-6 Cammer-6 is offline
isnt the date code on the servo cover,which is replaceable
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 09-26-2012, 09:23 PM
I am not sure as the car's transmission was replaced. Do you have one?
Old 10-02-2012, 09:42 AM
michaelroy's Avatar
michaelroy michaelroy is offline
Default 65 2 sp trans.
I have one in S.C. if you can't find one closer. Don't know the date code but will look if you tell me where it's located. Swapped it out for 4 speed. I have the shifter and all the accs.
Old 10-02-2012, 10:44 AM
Hi,
Not sure exactly where it is but it would be in the form of something like L154 or something like that. If you can post the numbers you find i will look them up
Phil
Old 10-08-2012, 01:43 PM
michaelroy's Avatar
Default transmission
I can't find a date code on this transmission. Perhaps you could tell me exactly where to look.
Mike
Old 10-08-2012, 03:48 PM
Hi,
Did the transmissioin your refering to come out of a 1965 GTO? And if so what do you want for the transmission and all assessories? Actuall call me at 978-729-2546
Phil
Old 10-08-2012, 04:27 PM
michaelroy's Avatar
Default trans.
It came out of a LeMans. I have the shifter, linkage and even the correct console.
I have attached a picture of the car it was removed from. The car only had about 65k miles on it when I made a GTO out of the LeMans. It had the 2speed trans and a 326. Still have the motor also.
How about 200 bucks for the trans and shifter w/all the misc. parts.
Old 10-09-2012, 07:27 AM
Thanks and sounds fair. Can you please post the numbers? Any one you find
Phil
Old 10-09-2012, 03:22 PM
66Post's Avatar
66Post 66Post is offline
Correct on the cover.
Old 10-09-2012, 09:22 PM
60sstuff's Avatar
60sstuff 60sstuff is offline
Default Tempest Series Automatic Trans. Info
Date should be stamped in servo cover on RH side as others have mentioned above. Photos borrowed from another thread about this topic.
I think the NB in second pic denotes GTO application on a 65?
Third pic is of my 66 GTO servo cover showing NA = GTO.
Name:	65 Auto Trans Info.png
ID:	299933   Click image for larger version
Name:	65 Auto Trans Info (1).jpg
ID:	299934   Click image for larger version
Name:	66 Matching Numbers (3).jpg
Old 10-10-2012, 09:21 PM
Thank you very much
Old 10-10-2012, 09:22 PM
So there is no date codes?"
Old 10-10-2012, 09:56 PM
60sstuff's Avatar
Default Yes they are date coded
The second pic above shows an automatic with a date of 199 days into the 65 production year.
The third pic shows 90 days (090) into the 66 production year.
Old 10-10-2012, 10:24 PM
Very good information. So i have a 1965 GTO that has date codes of December 0f 1964 on the intake, rear end, block, etc and the data plate show that the car was completed on the first week of January 1965. So what should i expect for a date code of a tranmission for this car?
Old 10-11-2012, 08:00 PM
60sstuff's Avatar
My 66 GTO has the same date window as your 65 but obviously one year later. My drivetrain etc. is all late Nov. 65, Dec. 65 into very early Jan. 66 with a data plate of 2nd week of Jan. 66. My auto trans is shown above at 090 days into the 66 model build so I would think your 65 should have a similar date of 90 + or - days to be correct enough.
Old 10-14-2012, 11:01 AM
michaelroy's Avatar
Default trans.
Didn't look there will go back and see if I can locate the code. I did find this #1357670. It was on the side where the odometer cable attaches.
Old 10-15-2012, 12:32 PM
1968firebird455 1968firebird455 is offline
Send a message via AIM to 1968firebird455
I have a low miles 1965 2 speed out of a Tempest Custom with a 326. I am located just south of Cleveland.
Old 10-15-2012, 01:04 PM
michaelroy's Avatar
Default 65 Trans.
Found the numbers: 66
LA 155 N
Would that be May 4th?
Old 11-03-2012, 12:11 PM
bigpop bigpop is offline
See PM Larry B.
Mr. President, you can't say Dallas doesn't love you "
