Old 10-28-2012, 12:22 AM
gitgo gitgo is offline
Default fuel tank
what is every one using for a fuel tank on 1963 tempest ? will a later model one work ?
Old 10-28-2012, 08:51 PM
TempestFugit's Avatar
TempestFugit TempestFugit is offline
I don't know of any other tank that fits.
Old 10-29-2012, 08:41 AM
c5farmer's Avatar
c5farmer c5farmer is offline
Default fuel tank
I have talked with guys that converted repopped early Nova tanks to fit. The Nova tank is narrower to allow using leaf springs with a conventional axle. The filler neck has to be replaced with the stock Tempest's tank neck (cutting and welding). No repops of the Tempest tank are available.
Old 10-30-2012, 10:15 PM
heater63's Avatar
heater63 heater63 is offline
so in my wifes 63 (it is a 4speed) I was able to use a 64 GTO tank. it fit very well but needed some help with the tank straps. I dont think they fit too well with an auto trans because of the torque converter. Hope it helps
"If you aren't first, your last." Ricky Bobby 2006
