Old 11-12-2012, 01:30 PM
njsteve's Avatar
njsteve njsteve is offline
Some interesting clearancing on the piston skirts:
  #602
Old 11-12-2012, 01:32 PM
njsteve's Avatar
And the cause of the oil leak. The rear main had spun and compacted itself so there was a one inch gap in the rope seal, in the cap area.
I used Plastigage and checked the oil clearances on the rods and mains and they were .002. I also checked end play and side clearances and they were in spec as well.
  #603
Old 11-12-2012, 02:07 PM
RicksGTO's Avatar
RicksGTO RicksGTO is offline
I had that same Crane cam in a fairly stock, low compression 400. Was a nice street cam for that engine but would seem fairly mild for a high compression 455. What are your plans on the cam and pistons, compression?
'72 Formula 455HO TH400, Revere Silver, black deluxe
'74 Trans Am SD 4 speed, Admiralty Blue, blue deluxe
  #604
Old 11-12-2012, 02:13 PM
njsteve's Avatar
I will be using the 068 reproduction cam from Melling. I need to figure out how to either lower the compression with these domed pistons or sell them and get some stock compression pistons. This thing was rattling on everything but 100 octane avgas (even with the timing dialed way back).
  #605
Old 11-12-2012, 02:38 PM
RicksGTO's Avatar
I'd want to CC the chambers on at least one cylinder per head before dedciding on a plan. Another thing about the TRW's is they are pretty heavy compared to most any other forged piston so I'd be tempted to sell them to someone building a race engine and getting new forged. It would be nice to see what those domes end up weighing without the rods.
  #606
Old 11-12-2012, 02:54 PM
Rocky Rotella's Avatar
Rocky Rotella Rocky Rotella is offline
The rods look to be a stock cast piece with the side beam polished to remove the parting line, and then followed up by shot peening. Unless it's the lighting, the wrist pin end is awful blue!
  #607
Old 11-12-2012, 03:30 PM
njsteve's Avatar
I was just out in the garage looking at old parts and had a stock set of rods to compare with the rods I just pulled from the engine. They had the same remnant of the casting # at the big end confirming my suspicion of the stock cast rod.
And yes they are awful blue.
Looks like it rod and piston time.
  #608
Old 11-12-2012, 03:32 PM
njsteve's Avatar
Heres' the underside of the heads:
  #609
Old 11-12-2012, 03:34 PM
njsteve's Avatar
And the empty block and crank:
  #610
Old 11-12-2012, 07:08 PM
Formulabruce's Avatar
I agree on checking the CC at least one cyl, on a head.
If you are not gonna rev and race those stock rods will be fine, they survived the 10.5+ CR to 1
A "good" set of Rods will be 400 bucks.'
any cheap ones need serious resizing work and balancing. In fact if machined in asia, the holes are water jet "punch through" and are not same diameter on both sides of the rod ( ask me know I know UGH)
As a Mopar owner, Im sure you have the scoop on KB forged pistons. I like em, use the KB rings and special gap. These will put you right where you want to be if heads are stock
Name:	KB pistons.jpg
" Long may we DRIVE !"
  #611
Old 11-14-2012, 02:43 PM
njsteve's Avatar
Originally Posted by njsteve View Post
Got the engine out today.
BTW, Here is today's challenge:
Does anyone notice what else is wrong in this photo???
  #612
Old 11-14-2012, 02:48 PM
Clutch fork boot installed inside out?
  #613
Old 11-14-2012, 03:03 PM
njsteve's Avatar
Well played, Sir!
You win the old boot.
  #614
Old 11-14-2012, 03:49 PM
superdutybob's Avatar
superdutybob superdutybob is offline
Cool
Well played, Sir!
I'm glad I didn't win if that's the prize! LOL
Bob Woodard
Brighton, MI
2012 SRT8 Charger - 12.70 @ 111mph
  #615
Old 11-14-2012, 03:54 PM
2manyT/A'S's Avatar
I really don't know what some people are thinking when they put those pistons in a "street engine".
I've pulled apart several HO's & found them inside......
You might consider milling/machining about 1/2 the dome off to achieve a 9.5 CR?
Goadhead455 (on the forums here) has had some good success (street & strip) with a similar 72 455 HO combo......)
Looks STOCK,runs REALLY fast.....
Eye Candy......garage band?
Go full screen & turn it UP!
  #616
Old 11-14-2012, 07:04 PM
njsteve's Avatar
I already ordered some TRW/Speed Pro/Federal Mogul L2359 forged pistons and some 4340 forged steel H-beam rods. They should be here by next week, along with the bearing sets. The block is already at the machine shop getting tanked, honed and new cam bearings. The bores measured out at exactly .030 over so I am staying at that size. The Heads are getting disassembled, cleaned, and a nice valve job (if needed) by the same shop. The crank will get polished and then everything balanced together, along with the harmonic balancer and flywheel/clutch plate. I already have the new Melling 068 cam.
So, who needs some low mileage, domed pistons and cast rods? Or that Crane camshaft? They only have around 5000 miles on them.
  #617
Old 11-15-2012, 03:44 AM
Many "general" machine shops do not put in Pontiac Cam bearings and install the ones they do put in, wrong. The aftermarket ones go in very tight, and sometimes you cannot even turn the cam. I would have them lube a cam (your old one, if ok) and test it in the bare block first. '
just a fyi. getting the block home and cannot install the first part, wellll
  #618
Old 11-15-2012, 08:07 AM
njsteve's Avatar
The machinist is an old timer who has been working on these since the old days. Had no problem with his previous work on Gramma's car's engine last year. I had volunteered my cam for that one and he said not necessary snce he had one already to use as a "stunt cam"
  #619
Old 11-15-2012, 06:51 PM
njsteve's Avatar
Got the engine block back today! It only took two days for the hot tank, hone and cam bearings!
Rod and main bearings arrived today. Pistons should be here tomorrow and rods on Monday. Heads should be done tuesday, then the reciprocating assembly can be balanced which should take around a week....
  #620
Old 11-15-2012, 07:28 PM
Nice!
