![]() Got the doors on. Mike had them looking perfect it short order. He likes to remind me there is probably a better body guy out there, he's just not here! Screwin the engine together soon, waiting on the Crane rockers so I can measure for pushrods then set it frame rails. Then we can install the front clip. Trying to get this thing to Seattle next year for the Natties.
1969 GTO 4spd. Antique Gold/black, gold int. 1969 GTO RAIII 4spd. Verdoro Green/black, black int. 1969 GTO 4spd. Crystal Turquoise, black int. 1970 GTO 4spd VOE Pepper Green, green int. 1967 LeMans 428 Auto. Blue, black int. |
Great job lookn good
________________________________________ 65 GTO owner since 84 original ca car
Welded these studs on to my ARP head bolts so I can still use my heat riser on the exhaust manifold and ground strap from battery.
Put on heads and torqued down. Coming along, just slowly as usual.
Holy Crap!!!! that gold looks good!!!
Greg Reid Palmetto, Georgia |
The car looks fantastic and I'm enjoying the steady progress. A true salute to the hobby and a great tribute to your family and grandmother. Excellent!
Crower solid roller bushed lifters (no bearings) installed.
![]() Crower Endura rockers installed. Lash set at .006 intake and .007 exhaust per Dave Bishop.
Ended up using Bill Hirsch engine enamel. It's a little less vibrant then the Plastikote from rattle cans. I think the quart was about $40. Could do 4 or more engines with the quart.
Me minus you is such a lonely ride.....
$3799?!!! I'll take it! :--) Okay seriously, the car looks great. Glad to see you making progress.
Car is a work of art. Beautiful job.
Been getting a lot done on the car a little at a time. Here is an example. Sand blast tiny screws, paint them and install on restored blower motor.
Hope I don't see this again anytime soon as fenders are scheduled to go on tomorrow. Going to try and post some other progress tonight if time allows. ![]() ![]() ![]()
Oh jeez ... great idea on the bolts ... for years I've holding them in my hand in those big ass gloves and doing them one at a time.
JohnnyB |
Finding and cleaning the correct bolts (some got primer on them), going thru pictures to verify where they went etc..... Took half a day but got one fender on. Went great as we already and the shims marked as to where they went and we also had 1/8" alignment holes to line the fender up right where it should go.
Looking at those pictures makes me want to go down to my local Pontiac dealer and order one! Your car looks fantastic.
Looking good GW. More pics please
. When you have time could you post a few pictures of where you drilled the 1/8th inch holes for alignment? Sorry to see the cadmium plating eroded. I installed a complete front end on the 68 442 only to watch the finish do the exact same thing over a period of time, prior to getting back on the road. Glad to see the progression. As always your work is second to none!
1966 GTO Vert automatic. 1969 CR Judge Ram Air III 4sp Pattern Car. 1969 GTO standard 350HP TH-400. 2006 GTO Phantom Black 6spd. 1972 Formula 455HO Ram Air. 1976 LE Trans Am 50th Anniversary Edition with T top. 1976 Formula 350. 1977 Grand Prix Model J 350. 1978 Trans am 400 Pontiac. 1979 Trans am 403 Olds. 1968 Olds 442. 1971 TR6. |
Charles, here's some shots if the 1/8" holes we drilled to realign stuff up.
Back of fender to cowl. ![]() Front of fender to core support. ![]() At door jamb.
Also did the doors and decklid this way. Here is a shot of a door hinge.
![]() And a shot of how we kept all the bolts and shims in order when removed from mock up.
Took a while and some help from fellow PY members for me to figure out the orientation of the inner fender splash shields. I had no picture of the lower ones. After some debate on how they came from the factory I am convinced they were installed a couple of different ways. I went with the one that made the most sense to me and that is shown in the picture below.
![]() The upper shields I had a picture if and although I believe they were also installed from the factory a couple of ways the picture below shows how mine came.
Here is a shot of the restored tilt column that will be going into Nana's car. It is not the original to the car as it did not come with a tilt wheel.
Interesting bit of trivia is that the ignition switch found on the column (green thingy in pict) is different from tilt to standard column. On a standard ignition when you turn the key it pushes on the rod that actuates the ignition, on the tilt column it pulls. ![]() And finally a shot of the Dynamat I installed under the dash on the cowl for noise and heat reduction, along with the restored heater box.
