Old 01-02-2013, 01:20 PM
GhostTown's Avatar
GhostTown GhostTown is offline
Originally Posted by FrankieT/A View Post
Well start off by replacing anything worn out.... Like bushings, tie rod ends, idler etc. then have it aligned. When you changed the spindles you blew the alignment out. The caster is probably way off so now it's squirrelly.
Hmm..... This would bring in several more decisions to make, which is ok. It just brings them up earlier than I expected.
I probably should have just gone with an entire Hotchkis or Ridetech suspension package to sit the car where I wanted it instead of going with the drop spindles. Then everything would have matched up. The way it is now I'm having to piece stuff together one mismatched item at a time.
I was hoping to temporarily get it at least drivable for a few hundred bucks before taking that step. However, if I'm going to be 600 to 800 into it, I may as well skip that temporary step and put the money into a performance kit now.
Originally Posted by ddella22 View Post
if you get springs for an A/C car it will raise the nose up a bit more than regular springs
Thanks for verifying that. Still might be what I do, along with getting everything else straightened out as stock (save for the spindles).
