Old 01-08-2013, 03:26 AM
Nicks67GTO Nicks67GTO is offline
Did you ever check the vacuum?
-1967 GTO HO Restomod. PKMM 433ci, SilverSport T56 Magnum 6spd, Moser 9", SC&C and a bunch of other pro touring goodies
- Build Thread
http://forums.maxperformanceinc.com/...615847&page=23
Old 01-08-2013, 04:29 AM
Old Man Taylor's Avatar
Originally Posted by brut4s View Post
OMT, what's the suspension set up on the GTO?
It's pretty stock. I still have the original stock springs in it. I have boxed control arms in the back, and the frame stiffeners that tie the front mounting point of the uppers and lowers together. It also has air bags. IIRC the front shocks are 45/55, and the rears are 50/50. I tried (and still have) 70/30's on the front and I didn't like them. However, it was a good way to scare people in parking lots by popping the front end up.
Old 01-08-2013, 04:31 AM
I thought I posted it before somewhere, but I couldn't find it. At a stable idle it is 10 psi. When it slows down it starts oscillating and goes down to 8 psi. Going down means below about 1250 RPM. I'm still working on the center carb to get it work better with this engine and cam.
Old 01-08-2013, 06:51 AM
uneasyrider's Avatar
uneasyrider uneasyrider is offline
Originally Posted by Old Man Taylor View Post
I went to the rock crusher from an M-20 for two reasons: I had way too much torque multiplication on the starting line; and I was breaking the M-20's. However, I did also break the input shaft and first gear on a fine splined M-22. That's when I decided to quit racing the GTO.
Yep, I worry about breaking mine too since they are so hard to find. I don't run mine on the strip so the tires are the safety valve. I figure it'll never hook up good enough to break it, I hope... The nice thing is that it's not matching to the car so at least it's not "priceless".
Uneasyrider
“To find yourself, think for yourself.”
― Socrates
“The unexamined life is not worth living.”
― Socrates
“Wise men speak because they have something to say; fools because they have to say something.”
― Plato
Old 01-08-2013, 03:52 PM
The combination of slicks and a stick shift makes the launch brutal on the trans. I expect mine to last a long time on the street, even with good tires. Plus I have one spare M-22.
Old 01-08-2013, 04:46 PM
gtonut1 gtonut1 is offline
Send a message via Yahoo to gtonut1
Sound like fun Jim, I had a dry day , rare here, so I took my '74 out and did some long burnouts to clear the plugs and make some noise.
Do you live anywhere near Jess Tyree ? I have been trying to get hold of him for some help on my "63 Gasser project.
Thanks Butch
Old 01-08-2013, 06:40 PM
I'm about 50 miles from Jess, but I've never been to his house. Maybe you can get in touch with him on Facebook.
Old 01-08-2013, 07:12 PM
tom s tom s is offline
I have his number,PM me and I will get it for you when I get home this weekend.Tom
Old 01-08-2013, 07:29 PM
Silver Judge's Avatar
Howdy OMT, Your '64 sounds like it's running great. Yes, isn't it fun to row through the gears with a M-22? I dig it too. I ended up breaking my first M22 in my 500 hp Judge while driving on the street with BF Goodrich Comp TA radials. 2nd gear just went WHAM at one point. Upon further inspection, it was revealed that all of the 0-80 MPH 1-2-3 shifts I had done on the street practicing for the dragstrip took their toll. The tail shaft was bent to sh!T too. Oh well
My current M-22 is a built supercase muncie, 2.52 first gear ratio, and gusseted tailshaft housing, etc. So far, it's holding up.
501 HP, 554 ft lbs TQ
Old 01-09-2013, 04:07 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Me too... I wanna' be jus' like OMT when I grow up!
Old 01-09-2013, 02:27 PM
Smart aleck! OOPS, forgot - I've got to respect my elders.
Old 10-03-2013, 06:42 AM
brut4s's Avatar
brut4s brut4s is offline
Any updates? How's it running?
Old 10-04-2013, 03:19 AM
It continues to run great! I did explode the posi a month ago, but it had seen some pretty severe duty over the years. I replaced it with another Moroso Brute Strength. At the samed time I changed to gear ratio from a 4.33 to a 3.73. Someday I hope to be able to put a 5-speed in it.
Old 10-04-2013, 12:49 PM
wheelspin's Avatar
Talking Bring it out...
Hey Jim,
Now that you changed your final gearing consider coming to our next Pontiac drag racing event at Irwindale on Thursday, October 17. Some of us from the old Pontiac Drag Days group meet every other month at their Thursday T n' T for some grudge racing and some serious pit racing . It looks like you are all setup for Wanger's Petersen and the Driving Museum GTO 50th anniversary events to be held later this month and next year.
Call me if you need more details on the Irwindale meets.
Les Iden
Old 10-07-2013, 07:07 PM
Tim Corcoran's Avatar
Details on this event please
Tim Corcoran
Old 10-07-2013, 07:16 PM
wheelspin's Avatar
Smile Special events...
Tim,
You have a pm .
Les Iden
Old 10-08-2013, 04:47 PM
Originally Posted by wheelspin View Post
Hey Jim,
I really don't want to race the GTO anymore. Without good tires it is a joke, and with good tires it eats up parts. That's why I built the racecar to begin with.
  #38
Old 10-10-2013, 01:38 PM
Lee's Avatar
Lee Lee is offline
Spraying a tri-power, THAT is too cool Jim! Great to hear you are still at it :-)
Lee
'73 T/A (sold). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 317rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'.
  #39
Old 10-10-2013, 02:44 PM
As long as you continue to beat up on hemi cars and supercharged fords, that's OK
