Did you ever check the vacuum?
-1967 GTO HO Restomod. PKMM 433ci, SilverSport T56 Magnum 6spd, Moser 9", SC&C and a bunch of other pro touring goodies - Build Thread http://forums.maxperformanceinc.com/...615847&page=23 |
It's pretty stock. I still have the original stock springs in it. I have boxed control arms in the back, and the frame stiffeners that tie the front mounting point of the uppers and lowers together. It also has air bags. IIRC the front shocks are 45/55, and the rears are 50/50. I tried (and still have) 70/30's on the front and I didn't like them. However, it was a good way to scare people in parking lots by popping the front end up.
I thought I posted it before somewhere, but I couldn't find it. At a stable idle it is 10 psi. When it slows down it starts oscillating and goes down to 8 psi. Going down means below about 1250 RPM. I'm still working on the center carb to get it work better with this engine and cam.
Uneasyrider “To find yourself, think for yourself.” ― Socrates “The unexamined life is not worth living.” ― Socrates “Wise men speak because they have something to say; fools because they have to say something.” ― Plato |
The combination of slicks and a stick shift makes the launch brutal on the trans. I expect mine to last a long time on the street, even with good tires. Plus I have one spare M-22.
Sound like fun Jim, I had a dry day , rare here, so I took my '74 out and did some long burnouts to clear the plugs and make some noise.
Do you live anywhere near Jess Tyree ? I have been trying to get hold of him for some help on my "63 Gasser project. Thanks Butch |
I'm about 50 miles from Jess, but I've never been to his house. Maybe you can get in touch with him on Facebook.
I have his number,PM me and I will get it for you when I get home this weekend.Tom
![]() My current M-22 is a built supercase muncie, 2.52 first gear ratio, and gusseted tailshaft housing, etc. So far, it's holding up.
Knock Knock Knockin' on 11's Door '70 Judge, Palladium Silver w/Red Interior Powered by SD Performance, Ported 6X Heads 501 HP, 554 ft lbs TQ 12.14 ET @ 114 MPH , Supercase Muncie M22, 3:55 Suspension: HO Racing, BMR< Sykorat, and Bilsteins Narrowed 12 bolt , 16x8 VintageWheel Works, Comp T/As on street, MT Drag Radials @ Strip http://www.sdperformance.com/custome...1.php?carID=42 |
Me too... I wanna' be jus' like OMT when I grow up!
Anybody else on this planet campaign a M/T hemi Pontiac for eleven seasons? ... or has built a record breaking DOHC hemi four cylinder Pontiac? ... or has driven a couple laps of Nuerburgring with Tri-Power Pontiac power?(back in 1967) ... or has a Pontiac born the same year as Jim Wangers? (1926}
Smart aleck! OOPS, forgot - I've got to respect my elders.
Any updates? How's it running?
It continues to run great! I did explode the posi a month ago, but it had seen some pretty severe duty over the years. I replaced it with another Moroso Brute Strength. At the samed time I changed to gear ratio from a 4.33 to a 3.73. Someday I hope to be able to put a 5-speed in it.
Hey Jim,
Now that you changed your final gearing consider coming to our next Pontiac drag racing event at Irwindale on Thursday, October 17. Some of us from the old Pontiac Drag Days group meet every other month at their Thursday T n' T for some grudge racing and some serious pit racing . It looks like you are all setup for Wanger's Petersen and the Driving Museum GTO 50th anniversary events to be held later this month and next year. Call me if you need more details on the Irwindale meets.
Les Iden ---------------------------- '65 Buick Sport Wagon Custom, 340, T350, 3:23 '66 GTO Post/468, 700R4, 3.31 (Mike's as of 9-16) '68 Grand Prix/455, dual AFBs, T400, 2:93 posi (sold) '72 TA tribute/461, T400, 3.08, (Russ's as of 9-16) '97 Mitsubishi Eclipse Spyder Turbo, Konis, 5 speed '09 Torrent GXP, nav, Sun & Sound pkg., Bilsteins |
Details on this event please
Tim Corcoran |
Tim,
You have a pm .
Spraying a tri-power, THAT is too cool Jim! Great to hear you are still at it :-)
Lee
'73 T/A (sold). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 317rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'. '67 Firebird [sold], ; 11.27 @ 119.61, 7.167 @ 96.07, with UD 280/280 (108LSA/ 109 ICL)solid cam. [1.537, 7.233 @93.61, 11.46 @ 115.4 w/ old UD 288/296 108 hydraulic cam] Feb '05 HPP, home-ported "16" D-ports, dished pistons (pump gas only), 3.42 gears, 275/60 DR's, 750DP, T2, full exhaust |
#39
