Old 01-08-2013, 09:52 PM
John O. John O. is offline
Default installing windshield and rear glass
Body still in primer and vinyl top has been stripped off on 71 GTO. Will install new top when car gets finished but in the meantime I would like to re-install front windshield and also the rear window. Would it actually be better to have the top installed first before installing glass or or does it matter.
Old 01-08-2013, 10:53 PM
Cammer-6 Cammer-6 is offline
I would put full paint under top and window openings
Yes it is better to do top first as its real hard to cut around the studs with glass in and you risk cracking glass too.
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 01-09-2013, 08:30 AM
2002Z4CSS's Avatar
Ditto that!
1971 Pontiac GT-37
Old 01-09-2013, 09:23 AM
steve v's Avatar
steve v steve v is offline
x3. You'll get a better top installation w/o the glass installed.
Old 01-09-2013, 09:36 AM
Rob B's Avatar
Rob B Rob B is offline
X4 on everything above!!! And if you plan on installing a new headliner, do it while the glass is out also. It makes it a little easier to stretch and pull.
74 GTO Bracket/Street car and another 74 for the wifey to race with!
70 GTO 400, 4 spd, #'s matching and a little to nice for me to own.
Friendship is like peeing your pants..everyone can see it but only you can feel the warmth!
Old 01-09-2013, 11:58 AM
irgoatmike irgoatmike is offline
i'd be most concerned with painting the window jambs with a 2 component topcoat (catalyzed) so that you don't eventually get moisture under there and subsequently rust. irgoatmike
