Old 01-23-2013, 11:27 PM
badassgoat's Avatar
badassgoat badassgoat is offline
Default Rust free 69 Bird rolling
Rust free 69 Bird rolling. The one in my SIG pic. $6000
69 'Blackbird'
535 CID IA II SD Wide Port E-head Pro Systems Dominator
Old 01-24-2013, 08:56 AM
ddella22 ddella22 is offline
more info and pics?
Old 01-24-2013, 09:00 AM
badassgoat's Avatar
What would you like to know? PM me.
69 'Blackbird'
Old 01-24-2013, 01:14 PM
mrrat1 mrrat1 is offline
Originally Posted by ddella22 View Post
more info and pics?
x2! rear specs, front end, whats in the interior, any water damage. Thanks Dave
Old 01-24-2013, 04:29 PM
badassgoat's Avatar
OK here goes, NO WATER DAMAGE OF ANY DESCRIPTION!!!
Front end:stock control arms, Moroso trick springs, 90/10 shocks. Wilwood featherlight disc setup that worked great. Front runners on Weld rims
Interior: 2 Racing buckets, no gauges in dash, big tach. 10 pt Moly cage (with outriggers to the front frame rails) done by a pro (Farks Supercars in Brooklyn) for almost 5k in '09. All 4 new floor pans welded in at that same time. Professional tin work between the tubs.
Rear end: Back half (square tube) and tubbed 9" with disc brakes. Brand new (fall 09') Strange center section with 5 passes on it. Brand new at same time Strange 35 spline axles. Spool with 3.89 gears - no passes. Installed after I decided 4.30 was too much gear. Adjustable coilovers. Weld wheels with 31x13 slicks (also 5 passes). Long studs.
Sheet metal fabricated full trunk pan. 15 gallon cell, battery box. You can even have the ugly purple wheelie bars.
It was never a pretty car but it was well capable of going very fast, SAFELY. Was 3225lbs with me (225lb), a 535, and a t-350 in it so it is light.
Anybody with genuine interest, PM me your email addy and I'll send you pics of whatever you want. When I get home from work, I'll post some pics here as well.
All in all this was a well done car that never even scratched the surface of what it was capable of. It launched hard and went arrow straight. It's a shame that I only got the opportunity to make 5 passes.
The hood is a Glasstek bolt on 5" cowl, the decklid is a glass pin on. Aside from those, all factory sheet metal and glass. No rot. Drive shaft loop also.
69 'Blackbird'
Old 01-24-2013, 04:50 PM
Thanks for the response, Im in no hurry Ill wait for pics to be posted on the thread
Old 01-24-2013, 05:49 PM
Electrics in place? Just drop a mtr & trans in and go? Thanks Dave
Old 01-24-2013, 09:46 PM
badassgoat's Avatar
Here are some pics as requested
ID:	310889   Click image for larger version
ID:	310890   Click image for larger version
ID:	310891   Click image for larger version
ID:	310892   Click image for larger version
69 'Blackbird'
Old 01-24-2013, 10:02 PM
badassgoat's Avatar
More pics...
If anyone wants a pic of something specific, let me know.
Also, this car has an intact VIN and can be registered and put back on the street if you want. It has no wiring/lights in it at present but I do have the harness for the rear purchased from PY that go with the car.
Pic one was before the new coilovers were installed, pic two of the Wilwoods, pic three shows the new pans.
Note: the shifter, 2 step, and retard box have been removed
ID:	310894   Click image for larger version
ID:	310895   Click image for larger version
ID:	310896   Click image for larger version
ID:	310897   Click image for larger version
69 'Blackbird'
Old 01-27-2013, 05:32 PM
RussellinNC RussellinNC is offline
Fair Price!!!! Should sell quick....Did ya build a new toy? Here is a pic of my project...Hope to be racing soon if I dont go broke!!! Good Luck Russell
Name:	68 Firebird LF.jpg
ID:	311307   Click image for larger version
Name:	1968 Firebird LR.jpg
Old 01-27-2013, 11:37 PM
badassgoat's Avatar
Thanks bro. I hope it does. No new toy, I'm out of the drag racing biz for a minute. I'm looking to make a deal.
Your bird looks badazz bro. Best of luck to you.
69 'Blackbird'
Old 02-06-2013, 12:27 AM
badassgoat's Avatar
bump
69 'Blackbird'
Old 02-08-2013, 03:04 PM
turbo69bird's Avatar
bump for a great car, Ive got a similarly built car and wouldnt sell it for double this price!!
If I didnt already have one Id jump on this myslef.
Great price!!
960 HP @ 11 psi, 9.70 at 146.
