| THE LOBBY A gathering place. Introductions, sports, showin' off your ride, birthday-anniversary-milestone, achievements, family oriented humor. |
Gum cutter works great on a concrete floor. Just spray it on and wipe it off. Raises grease right out of concrete. Buy it at local parts store in a spray can. Jon
Something I'll mention about most of the Purple cleaners...They contain lye which will flat out ruin any aluminum in comes into contact with...Unless you like the mottled dark gray anodized look.
Greg Reid Palmetto, Georgia |
What's wrong with leaving it there? Sounds like a lotta work for a truck. Caked on oil is a good protectant,just unsightly but shouldnt really matter on a dd? Just my opinion
lowes has a cheap electric pressure washer for under 100 bucks. works great.
I'd use one of those parts cleaner tubs with the good parts cleaner. But you have to remove the part. A steam pressure washer works best with no chemicals to clean up afterwards. If you can find one to rent I'd do that, but make sure you have a bunch of stuff to clean like GTO John does with his shop.
![]() Gary Get in, ShuT Up, Hang On! Member of the Baltimore Built Brotherhood MY GTO built 4th Week of March 1966 "Crusin' Is Not A Crime" Keep yer stick on the ice. |
I usually pressure wash mine too, but I have a lift.
1978 Black & Gold T/A [complete 70 Ram Air III (carb to pan) PQ and 12 bolt], fully loaded, deluxe, WS6, T-Top car - 1972 Formula 455HO Ram Air numbers matching Julep Green - 1971 T/A 455, 320 CFM Eheads, RP cam, Doug's headers, Fuel injection, TKX 5 Spd. 12 Bolt 3.73, 4 wheel disc. All A/C cars |
gasoline
The funniest line is the caustic acid in Oven cleaner. Cautic yes, acid no. without getting intot the pH scale here, an acid based material (solution) is low pH and an alkaline or caustic solution is a high pH matrial or solution. The alkaline stuff works better on animal (polar) grease than petroleum grease. Remember grandma's soap from school, that was made with tallow (fat) and caustic. Something petroleum based will be best. maybe a plactic spatula to scrape of the major crud and some diesel fuel (that Gunk engine degreaser spray), which is close to kerosene and jet fuel, home heating oil etc. and a stiff plastic bristle brush, then some purple clean. Wear rubber gloves and splash goggles. Greg |
I'm glad I can amuse you! I meant to say caustic soda, it was late. It's guys like you that make people not want to contribute! Correct me yes, be a jerk, No!
Try ZEP, water base, but will even fizz aluminum if left too long. Spray and saturate on a hot engine or tranny with a pump sprayer and let it set NOT long enough to dry and pressure wash. Same with grease stains in concrete, don't let it dry, and pressure wash. Don't get any on your hands very long or you will be peeling skin off. Buy it at Lowes or Home Depot in gallon jugs.
That's my thought also. It's what was used as undercoating for years
so many pontiacs, so little time.................. moderator is a glorified word for an unappreciated prick.................. "Only two things are infinite, the universe and human stupidity, and I'm not sure about the former." --Albert Einstein "There is no such thing as a good tax." "We contend that for a nation to tax itself into prosperity is like a man standing in a bucket and trying to lift himself up by the handle." - Winston Churchill |
You and your Op haven't a clue. A steam pressure washer and a car wash are NOT the same animal.
Here's a clue for you! Where I live most of the car washes are not the drive your car in and a machine rolls past you. Here, a majority are a bay you drive in and there's a pressure washer nozzle you physically pressure wash your car. It has settings for soap, wax, rinse, Etc. Although not steam I assumed that is what he is talking about. Are you not aware of such devices?
My OP ? WTF is that supposed mean? Do you mean the "original poster"? A" steam pressure washer" is not a bad idea, but to use it effectively you need crawl around under the car!!! I was merely reminding you the guy doesn't want to roll around on wet concrete. Its 30* where he comes from and he has a bum knee. Reread post #1. So, before you think you're the smartest person in world or everybody just stupid you should rethink.
