OHC-6 TECH Over Head Cam projects, questions and advice.
Old 04-08-2013, 10:29 PM
prf. marvel prf. marvel is offline
Default ohc clutch
Interchange question. What clutch (by application) will fit my 67 pressure plate, but a 26 spline T-5 input shaft? I'm using the same trans, etc. (85 T.A.?) from behind the 350 chevy I'm replacing in my 46 cpe. Nowhere near the power, but way cooler!
Old 04-09-2013, 09:27 AM
TheSilverBuick's Avatar
TheSilverBuick TheSilverBuick is offline
Should be a standard 10" clutch and pressure plate?
__________________________________________
"How I learned to stop worrying and love the OHC Pontiac L6"
The Silver Buick- '77 Skylark coupe w/455, SPX, MegaSquirt 3 & TKO-600 (Drag Week 2011, 2012 & 2015!)
1969 Firebird with a turbo'd Pontiac L6 controlled by a MegaSquirt 3 and backed with a microsquirt controlled 4L60e and 4.56 gears! (Drag Week 2018!)
Old 04-09-2013, 09:46 AM
X2, I just called my favorate Clutch Manufacturer and ordered a 10" Disc & Pressure plate with the T-5's Spline count.
On a related issue do you have an F-body T-5? And if so how did you work out the 17 degree tilt issue? Just looking for ideas.
Old 04-09-2013, 09:04 PM
BMFH BMFH is offline
Hello All
Hello Jeff, in my 68 Firebird, I used a WC GM T5 main case, a WC Mustang tail shaft housing and shifter cover.
Everything stands upright, and bolts up to the OHC 6 Bellhousing, there is only a slight angle to work with for the mount.
I made an aluminum Wedge to correct for the angle for the mount, and modified a TH 400 crossmember for the OEM style mount to rest on.
The reason I used a Mustang Tail Shaft Housing was to position the shifter where it would be properly positioned for me, The late model F body Shifter was too far to the rear, the S-10/15 was too far forward, the Mustang was just about perfect for me.
Sounds a little like the goldie-locks story doesn't it
I used the Mustang SVO 2.95 First Gearset too, you can get lower First gear sets but they are very hard on the main case, as in they have a tendency to break the case between the input and countershaft bearing bores.
I have heard that 3rd gear is weak in the T-5's, but I never had any trouble with it myself.
Hope this Helps,
Take Care
Dusty
PS
I can get the deminsions for the shifter hole on the Firebird if you need it, I have it stashed away someplace.
PSS
I would go with a 10.5 inch clutch, they are more common and have added holding power.
The Centerforce Dual Friction Clutch is a good one, however it is a little hard to disengage at High RPM's like 6500-7200 RPM's.
Old 04-11-2013, 09:53 PM
Cool ohc clutch
My wife, a counter person at a major parts house, came up with the cure. The set from an 88 t.a. I was all messed up because I forgot that the 350 was from a truck with an 11 inch clutch. I had fabricated all the mounts etc. so the angle was built into the new cross member in my 46. The 350 was pretty healthy and pulling around a car the weight of a 46 cpe, I'd say the t-5 is up to the challenge. The only problem I had is, even after changing over to motor oil, it still shifts like a sissy. The position of the shifter from the f-body was not too bad in the 46. Thanks for the help gang.
Old 04-12-2013, 05:15 PM
Cammer-6 Cammer-6 is offline
Humm did you try synthetic ATF?
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 04-12-2013, 08:38 PM
Default t-5 stuff
The trans had atf in it when I first got it. It really shifted easy. So easy, the leather boot from the previous trans. would pull the shifter into neutral every time you left off the gas. I guess i'm just used to trucks- and transmisions with linkage, not some teenagers honda. Did that sound old and bitter?
