Old 05-18-2013, 04:24 PM
Schoust's Avatar
Schoust Schoust is offline
Default Mini starter recamendations
So what Mini starter can be counted on for a proper fit? I bought a Jegs a while back from a fellow Member and it was fine for a long time with Zero shims! It began to give me problems so I figured I would buy Summit racing brand Mini well this was a big mistake! And so was the fact that I bought it over a year ago and they will not take it back. Anyway I have tried ten differant way's to shim the sucker using the paper clip method and it just is not right. It seems as though the pad is not the right size? Anyway anyone have any recamendations?
Old 05-18-2013, 05:08 PM
tripwr1964's Avatar
tripwr1964 tripwr1964 is offline
robbmc (no other choice in my book) they are very nice units and support is 2nd to none.
Old 05-18-2013, 05:10 PM
ponjohn's Avatar
ponjohn ponjohn is offline
I bought whatever one the Dude sells.
Old 05-18-2013, 05:23 PM
Bruce Meyer's Avatar
Bruce Meyer Bruce Meyer is offline
Ive bought and used both robbmc and IMI . Both work good with no shimming issues.
If I had to pick between the 2 it would be the robbmc.
Old 05-18-2013, 06:05 PM
grivera's Avatar
grivera grivera is offline
Ram Air Restorations sells a nice unit under their name for $189- I'm not sure who makes it though? It's works flawlessly in my bird and replaced a Summit unit that didn't fit...
http://www.ramairrestoration.com/ms-...and-later.html
Will Rivera
‘66 Lemans, 455, KRE D-Ports, TH350, 12 bolt 3.90 gears
'64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears (Traded)
Old 05-18-2013, 07:03 PM
ron cozzo's Avatar
ron cozzo ron cozzo is offline
Robbmc
'04 GTO Yellow Jacket, A4, Kooks, CAI, etc.
'02 Firebird, V6, auto
'68 GTO Convertible, HO, 4spd, driver
'66 LeMans Hardtop, 400, FI, A/C, 4L80E.
'64 GTO Hardtop, "389", Tri-power, 5 speed, A/C, Yorktown Blue.
http://www.gtoaco.com
Old 05-18-2013, 07:59 PM
bsblguy bsblguy is offline
I've had a powermaster for years, never a problem.
Old 05-18-2013, 08:33 PM
carcrazy carcrazy is offline
I've had 2 RobbMc starters for quite awhile. They have worked flawlessly and support has been outstanding.
Old 05-18-2013, 10:53 PM
oldblueponcho's Avatar
oldblueponcho oldblueponcho is offline
My RobbMc has never let me down.
Some Fear, Because if you've never been afraid- just a little. You're obviously not going as fast as you could be.
Old 05-18-2013, 10:56 PM
leeklm's Avatar
leeklm leeklm is offline
Sorry, cant help, but I have the Summit unit on my 455 and works like a charm. Maybe something a little funky with your flywheel or block?
Old 05-19-2013, 07:25 AM
GTOLou GTOLou is offline
I've used the Summit, IMI and Robbmc all - no issues with any except I had to send in a Robbmc to have a pinion support placed. I can't say that the Robbmc has worked any better - but support is where the good money is paid. If you have any issues, he'll fix it - cheap. The others - I'd guess that you'd just throw the unit away.
Old 05-19-2013, 08:52 AM
chrisp chrisp is offline
IMI excellent .
Old 05-19-2013, 09:07 AM
FrankieT/A's Avatar
I have one I bought used, I don't know what brand it is. Works on the bench. My problem is it won't bolt up using Ram Air III manifolds.
Old 05-19-2013, 10:16 AM
Schoust's Avatar
The thing works great on the bench but for some reason once it's installed it seems to hang on the flywheel. I don't think there is any problems with the block or the flywheel since the Jegs starter worked perfect for so long. I read someplace that someone had a similer issue with a Summit mini and they actually had to shave the mounting block to get it to fit! Wish I had done the homework on this one since they will not take it back now....
I guess I'll go for the Robmc.
Old 05-19-2013, 11:44 AM
Formula8's Avatar
Formula8 Formula8 is offline
X 2
71 Formula 433, Splayed cap 400 block, 4" stroke Scat forged crank, 6.8 Eagle rods, custom Autotec pistons. SD 295 KRE D ports, Old faithful hybrid roller, Torker II, Holley Sniper Stealth, Tribal Tubes, TKO 600, 3.73 Eaton posi.
Old 05-20-2013, 02:43 PM
1966goat's Avatar
1966goat 1966goat is offline
Send a message via AIM to 1966goat Send a message via Skype™ to 1966goat
RobbMc, I heard all the good things on here, bought one, and its quite an amazing little guy. Has not failed me since.
461ci, Edelbrock 72cc heads, KB 15cc dished pistons, comp xe274, PRW 1.5 roller rockers, Performer RPM intake, Holley 80508 750cfm, RARE oversized manifolds, Pypes X-pipe Exhaust
Old 05-20-2013, 03:22 PM
jasonblair's Avatar
jasonblair jasonblair is offline
I ordered my RobbMC today. Spoke to Robb directly, and he answered the phone on the first ring. Looking forward to it!
Old 05-20-2013, 04:12 PM
The Champ's Avatar
I tag on with RobbMC crew.
Bought it for my new 462, but put it on the original 389 when I had some starting problems before the 462 was done.
Worked perfect on the 389 with original exhaust manifolds and works perfect on the 462 with the RARE Ram Air III exhaust manifolds.
Old 05-20-2013, 05:28 PM
beargfr beargfr is offline
One more on the RobbMc. If I don't have at least one of everything he makes, I'm very close to it.
The stuff is high quality to begin with, but where it really meets the road is his support. It's the best I've ever encountered.
Bear
Old 05-21-2013, 08:35 PM
66Post's Avatar
66Post 66Post is offline
Thumbs up Summit Mini Starter
Time 2 on the Summit Mini, had mine 4 years, no issues.
