Old 06-17-2013, 07:02 PM
DOC DOC is offline
Originally Posted by pontiacmark View Post
Cut slots in adjustment screws with Dremel. Couldn't get it to run enough to see results from adjustments. Gave up and bought a cheap electric trimmer for now as I don't have much yard to trim. I will keep playing with the gas model later and let you know.
This is exactly what I do. then pull the screw out and run carb spray and air pressure through these passages. Just count the number of turns to seat so you can get it close afterwards.
