Old 07-23-2013, 12:03 PM
Brewster's Avatar
Brewster Brewster is offline
Yeap, but getting better!
  #1682
Old 07-23-2013, 12:07 PM
The Boss's Avatar
The Boss The Boss is offline
Too early to start drinking? It's after 12:00 here!
And go racin' in the street.
  #1683
Old 07-23-2013, 12:09 PM
That doesn't compute since you had to get the unitized ignition with the 455 HO as a standard part of the package along with Ram Air.
There has to more to it???
This:
As stated above,Unitized was mandatory on Formula 455 HO in 72 but optional on 72 T/A's
If you had a Formula 455 HO, it would have WM or YB engine code only.
You could have a TA with either the WM/YB if Unitized ignition or the WD/YE if it had standard points ignition.
  #1684
Old 07-23-2013, 12:14 PM
Judge273's Avatar
Judge273 Judge273 is offline
Or a GTO/T-41 LeMans with a HO could have any 4 of those engine codes too...
Mike/Illinois
  #1685
Old 07-23-2013, 12:51 PM
The Boss's Avatar
No! The GTO/Lemans would have the WM or YB because the unitized ignition, T-41 option and RAM AIR were ALL mandatory options.
  #1686
Old 07-23-2013, 12:58 PM
Doubt that, would need to ck '72 factory literature for exact verbiage. Have a fairly large database & tons of '72 HO A-bodys listed. all I have listed have WM's or YB engine codes. That goes along with all '72 HO A-bodys being packaged with endura nose, Ram Air & K65 unit ign.
Took quite a while but I went through all the '72 T/A's in my database that I have info on built before end of '71 calender year. So far, '72 T/A's ordered with WM's & YB's outnumber WD's & YE's nearly 20-1. my sample size is only a 1/10 of production & definitely could be bigger, but there seems to be a trend.
  #1687
Old 07-23-2013, 02:31 PM
Judge273's Avatar
Thanks, did not know that and I'm still learning too!
Mike/Illinois
  #1688
Old 09-13-2013, 12:16 PM
bluebird455 bluebird455 is offline
Default 71 formy 455HO
I wish I had the $$$$$!!!!
http://dallas.craigslist.org/ndf/cto/4063888022.html
  #1689
Old 09-13-2013, 12:34 PM
70FormulaCA's Avatar
70FormulaCA 70FormulaCA is offline
Originally Posted by bluebird455 View Post
Paint looks nice but the side vents were either removed or different fenders installed. Wonder what the original color was...Rosewood?
70 Formula 400 Auto non-A/C
Wanted: 1972 Formula HO - leads very much appreciated.
  #1690
Old 09-13-2013, 12:47 PM
Indeed, Am waiting for seller to call me back for more info.
  #1691
RA_Birds RA_Birds is offline
Yeah, nice car. Doesn't mention anything about number matching engine or tranny. Too bad it wasn't a 4spd.
  #1692
Rosewood metallic was very close to that color.
Nice car, but too many shark tank fixes for me.
  #1693
Old 09-13-2013, 01:01 PM
2manyT/A'S's Avatar
My thoughts,exactly......from an original perpective that looks like a shark feast to me...
Eye Candy......garage band?
Go full screen & turn it UP!
  #1694
Old 09-13-2013, 01:02 PM
He probably just bought it for a quick flip. Have not seen it advertised before.
  #1695
Old 09-13-2013, 01:21 PM
RicksGTO's Avatar
RicksGTO RicksGTO is offline
Nice looking car, love the color. Looks like a repop ram air cleaner without the flaps/vacuum pods. Later dash bezel, not exactly full gauges as said, and I can't get a good enough look at the heads to tell if they are round port or not. Seems like 90% of the 71's claimed as HO/Ram Air turn out to be D ports so I'm always skeptical until they post PHS or show more detail.
If someone wants the car looked at before they fly in, PM me and I'll do my best to tear myself away from work and go look at it.
'72 Formula 455HO TH400, Revere Silver, black deluxe
'74 Trans Am SD 4 speed, Admiralty Blue, blue deluxe
  #1696
Old 09-13-2013, 01:22 PM
2manyT/A'S's Avatar
It would have to be numbers match & very close to PHS invoice to command that much $$$$
  #1697
Old 09-13-2013, 01:23 PM
Formulabruce's Avatar
Originally Posted by 2manyT/A'S View Post
My thoughts,exactly......from an original perspective that looks like a shark feast to me...
X2 !
"Full Gauge package"
38K?, and no published numbers or a PHS?
Its a good looking car, about 15K overpriced, IF its got its drivetrain all intact
Notes; hood holes, wrong fenders......Gauges? etc ..etc...
  #1698
Old 09-13-2013, 01:34 PM
"Appears to be Pretty Original with 52,XXX miles." I don't see a lot Original components so far. But I do Like the color combo!
  #1699
Old 09-13-2013, 02:55 PM
2manyT/A'S's Avatar
I think you SHOULD go look at it.....provided it's close by.....would be interesting just to see if it really is what he says it is...
  #1700
Old 09-13-2013, 03:21 PM
RicksGTO's Avatar
I think I will call on it and see where it's at, looks like the northern part of our metro area where I live so might not be too far.
