Old 07-24-2013, 10:19 PM
RAIV-Z's Avatar
RAIV-Z RAIV-Z is offline
Should have some numbers tomorrow.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #802
Old 07-24-2013, 10:41 PM
Travis Q Travis Q is offline
Hope things go better for you this time around, Ed!
TQ
  #803
Old 07-25-2013, 12:04 AM
Jim Robertson's Avatar
Jim Robertson Jim Robertson is offline
Very cool deal. Best of luck to you and the crew. Have a great day with even greater numbers.
  #804
Old 07-25-2013, 01:23 AM
Ron H's Avatar
Ron H Ron H is offline
Good luck Ed
68 Firebird
Are you running with the wind or breaking it?
  #805
Old 07-25-2013, 10:16 PM
RAIV-Z's Avatar
After chasing some ignition/timing issues, we managed to get a partial pull before we had to call it a night.
ID:	330906   Click image for larger version
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #806
Old 07-26-2013, 12:25 AM
jdw_poncho's Avatar
jdw_poncho jdw_poncho is offline
Looks like good numbers.
I'll call you tomorrow.
  #807
Old 07-26-2013, 02:29 AM
David Holmberg's Avatar
Now that's a nice torque curve.
Judging by the 5500 peak tq there is more power above 6100.
Good luck tomorrow!
  #808
Old 07-26-2013, 08:37 AM
About 20 HP more than the original dyno pull.
(a lot bigger cam though)
Was the numbers on this latest dyno pull corrected numbers?
(doesn't say on it)
Now we need some turbo power numbers!
  #809
Old 07-26-2013, 09:48 AM
Stan Weiss's Avatar
I would really like it if the CFM column on the new dyno sheet had data. A/F and VE like the original dyno sheet would be nice but a person could calculate these if there was CFM data. I do like the improvement in BSFC.
Stan
Pontiac Pump Gas List
  #810
Old 07-26-2013, 10:34 AM
ponjohn's Avatar
ponjohn ponjohn is offline
Great power n/a.
The exhaust heads pipes aren't doing you any favors with that non mandrel bend.
Are you going to dyno with the turbos?
  #811
Old 07-26-2013, 10:56 AM
GTO Dan's Avatar
GTO Dan GTO Dan is offline
The dyno is always helpful for the initial tune, controlled break in and to confirm everything is functioning properly...
Now...
Put on the hair dryers and let it eat.
Good luck and wishing you success, you have earned it.
  #812
Old 07-26-2013, 11:51 AM
RAIV-Z's Avatar
(doesn't say on it)
Air Temperature:82
Temperature Correction Factor:1.021
Barometric Pressure:30.06 in Hg
Barometric Correction Factor : 0.995
Relative Humidity:97%
Humidity Correction Factor: 1.038
Vapor Pressure:1.083 in Hg
Final Correction Factor: 0.055
Relative Air Density: 94.84
Correction Method: Standard
Correction Source: Weather Station
We will not be seeing boosted numbers here
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #813
RAIV-Z's Avatar
Stan
I'll see if we have those numbers.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #814
Old 07-26-2013, 11:54 AM
RAIV-Z's Avatar
Originally Posted by ponjohn View Post
Great power n/a.
It's all I could get on short notice, we're running 3" up to the mufflers. That pull was with 35* total and 93 octane.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #815
Old 07-26-2013, 08:37 PM
RAIV-Z's Avatar
Default 716.8hp@6600rpm
Made some good progress this evening, starting early tomorrow.
Seeing gains advancing the timing "total to 40*" and retarding the cam 2*.
Also tried advancing the cam 2*, but power was down.
ID:	331022   Click image for larger version
ID:	331023   Click image for larger version
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #816
Old 07-26-2013, 09:15 PM
RAIV-Z's Avatar
Video link
http://s338.photobucket.com/user/epa...ac801.mp4.html
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #817
Old 07-26-2013, 09:18 PM
mysticmissle's Avatar
Nice job Ed and crew.
  #818
Old 07-27-2013, 11:29 AM
pastry_chef's Avatar
The valve cover fastener at the lower right corner needs some extra holy water! LOL
  #819
Old 07-27-2013, 12:09 PM
Funny thing is you could take Ed's RA-V Head 535 engine naturally aspirated and with that 3500-6500 rpm 600 lb/ft torque curve (basically FLAT from those two rpm points) and have a killer street engine.
Tom Vaught
  #820
Old 07-27-2013, 12:40 PM
shaker455's Avatar
Ed,
Finally headded in the right direction and I see you got Good old Engine master Mr. Lenny Caverly helping! way to go!
I like the video...watch you valve cover T-handle loosen! HaHa!
