Hello, I have a 67 GTO that needs work in the rear axle area.
I have some arms with bushings lined up. My question is regarding the rear springs. I have looked at different sources for springs (online, year one, opgi, etc) and am looking for advice on where to get the best for stock springs / mounts. What is there are shot and prev owner added air shocks to get by. Any help is greatly appreciated. Thx. |
You can find a new set of moog rear coil springs on eBay for $65 or so. I bought upper insulators from our host.
1967 GTO, 432 (428+.030), 4-bolt mains, factory Nodular crank, scat rods, icon dished pistons, Lunati HR 243/251@.050, .618/.622 lift, Edelbrock 72cc round port heads, 10.5:1, offy 2-4 intake, Edelbrock 650cfm carbs, Super T10 trans (2.64 first), BOP 10 bolt w/ Eaton posi and 3.36 gears |
I got everything for my suspension, front and back, bushings, springs, shocks etc. from
Rock Auto. Everything is moog. Believe me, I shopped and with the discount coupon (5%) it was the best deal out there. Plus, I got everything in 2 days! |
O'Reilly auto Parts lists a Moog #5409 for a 67 GTO rear at a cost of $87.99.
http://www.oreillyauto.com/site/c/se...GTO&vi=5152716
Our host sells the springs for convertible (for a little extra lift) or coupe/hardtop, $79 a pair on page 288 in the catalog.
Bob,
Thanks for the help. Since I am new to this site can you help me with who the host is? I believe in supporting them because this is a great site. Plus appears they are trusted. Also, from what I have been reading should I order convertible rear springs? They apparently add some height. I am fine with that as long as no spring modification is required. Thanks again for your help. Larry |
![]() Quote:
The host is the owner of this site. Go back to the home page and on the left side you'll see the link for ordering parts. -Don
1966 GTO 1966 421-9.3-1 comp-Race Tec 23cc Pistons 1966 Tri-Power 1967 670 Heads Pontiac "Highlift" TriPower Cam by SpeedPro DUR 214 Int 224 Exh @.050 - 107 ICL LIFT .445" Int .465" Exh Tri-Y-Headers by Tribal Tubes w/ Goerlich Mufflers 1966 Muncie Wide Ratio 4-Speed 1968-72 Chevy 12 Bolt Rear End w/ 3.73 rear gears |
Performance Years is the host of this forum. Click on the Home link as Don pointed out, or just click here. Be sure to bookmark it. If you're restoring a GTO, you'll find a lot of what you need at their online store. Also, I gave the wrong page number and price in my previous post. I was looking at the wrong catalog. My apologies.
Page 175 in the catalog, $79. They're only showing the convertible spring, which is what most use to replace the stock springs in their hardtops and coupes, unless they want to increase the ride height several inches.
Rock Auto has the Moog 5409 springs for $48.79. Use discount code B973B3C370B3 for an additional 5% off.
Code expires 8/14/13
66 GTO, 495, M22, Strange S-60 w/4.10 Sold new at Ace Wilson's Royal Pontiac http://www.youtube.com/watch?v=cUHC-Z8xhtg |
if you want to really jack it up use the same year olds vista cruiser springs. will raise it quite a bit over stock height. great for a gasser look. put them on the front and you will need longer bolts to get front end aligned right. used them years ago to clear a set of mickey thompsons slicks
connman |
This ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
1967 GTO Sport Coupe 49,xxx orig.miles Champagne/Parchment 30 Original Owner Ordered PHS Documented Factory Options Second Owner |
Have a brand new set from Eaton stock height never installed 100.00 you pay the ride.
I have a 66 vert. Theres talk here about using vert springs in a hard top to give the car some lift. So what do I use to get some lift if I have a vert? Wagon springs? I need to buy springs this week.
What rear coil springs did you using on your car
I bought 66 tempest wagon springs and then put in a 3/4" spacer on each side so the wheels would fit better.
Or for a custom height you can have Eaton Spring custom build a set. I used them on my 67 to get the front where I want it. Irgoatmike
I'll bet mine is riding on the original front springs. But the right height is ok. I wouldn't want it any higher.
