Engine detailing
I've have been picking away at my engine bay in the 69 Sprint and I could use a bit of help. This car has a mostly virgin engine bay with original paint on the engine (despite a rebuild years ago), matching carb, air cleaner etc. The real eyesores are the following;
Ugly blue plug wires, blue distributor cap, incorrect and chromed generic coil bracket and exhaust shroud looks home made. Apart from the shroud which I would guess is sprint specific I guess the rest are the same as a 1bbl? I was thinking of using correct V8 plug wires and cutting them to length, did the OHCwires look like the V8 ones? Any help in terms of having leads, advice or having these items for sale would be great. I'm not a concours guy but I'd like to have a stock look to the engine bay.
My Break Away Squad 1969 Fbird (base OHC, 350, 400HO & Sprint Cvt’s - 400HO & TA ht’s) 1969 Custom S 2dr ht 1969 LeMans (2dr & 4dr ht & Cvt) 1969 LeMans Safari wagon 1969 GTO (2 Cvt, 2 ht & Judge ht) 1969 Cat (3 Cvt’s & 2dr ht) 1969 Ventura wagon 2 seat 1969 Exec 4dr post 1969 Bonnie Cvt & 2 wagons 1969 Bonnie Brougham (4dr ht & Cvt) 1969 Grand Prix 2 SJ’s 1969 2+2 2dr ht (Canadian) |
ACDELCO 506B
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car. |
You can buy a # 1971324 OE black dist cap for decent dollars at ebay. The spark plug wires I think I bought them through NAPA but that was many years ago. Black in color and IIRC the set came with the correct wire holder thingy. 69 Sprints used a unique coil that had the bracket built in. It sounds like you are using an oil filled unit that requires a separate bracket. You should be able to find a galv steel bracket at any auto store for cheap. We will need a picture of the exhaust shield to see what you are describing.
69 OHC ZH Sprint Hurst 3 Speed 3:55 (1 of 213) 99 Valkyrie 1520cc Flat 6 108hp/110tq - For Sale http://sohcsix.yuku.com/forums/1/OHC-lounge Wanted: 1969 OHC "H" Camshaft |
The AC Delco 506B plug wires and two different AC Delco distributor caps are listed on rock auto parts.
Thanks guys, here is the passenger side of the engine bay.
Anyone have photos of the correct coil?
Finding one from what I gathered is like finding Hens teeth...
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car. Last edited by Jeff Hamlin; 10-19-2013 at 07:55 AM. |
On a Sprint
FYI all 68-9s used that coil
Everything comes and goes Pleasure moves on too early And trouble leaves too slow |
i was gonna say, my 68 tempest has a coil like that
If youre gonna chop up some wires, i have boxes of NOS plug wires i can probably come up with the right insulators and the right dates... especially for a 69
Mark.. The Goat whisperer "I spent a lot of my money on booze, crazy women, and fast cars. The rest I just squandered." |
I really appreciate all the help guys, I'm plugging away at it.
One thing, I've noticed on most of the detailed OHC that the oil tube is painted engine color but mine was clearly black. Any thoughts?
It should be all Pontiac metallic Blue.
Also note that the '69 lost the detailed paint of the Cam Housing Fins & Lettering.
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car. Last edited by Jeff Hamlin; 07-02-2014 at 05:47 AM. |
Strange! mine is 100% original paint and the ribs are bare aluminum on the topand my oil tube is very original looking black. Hmm
John do you have a 69 assembly manual?
I think it may have all the paint details for OHC-6 Ill see if I can dig mine out and check
I do but I've never really studied it. I'll try to have a look, I'm bringing the car to the house this weekend, I'll post some better photos.
My 67 Lemans Sprint had a factory black oil fill tube and black cap for the same.
Tim john--- |
Please post where we would find this in the manual.
dont remember if it was my 67 or my 69 assembly manual I read it in.
has all the components that need to be painted blue. Including backside of flywheel,oil filter etc
FWIW; One thing I've learned over the years with this stuff is never say never, so it is possible. But I will add that all the engines that have come through here and it's been way to many 90% wore orig paint and all were blue all over, other then the funky Yellow & Red ones I've come across clearly bad choices by past owners And I'll add that in my files of images few if any of what appear to be original engines are also all blue.
