Old 04-18-2014, 10:18 AM
njsteve's Avatar
njsteve njsteve is offline
Looks nice. You may want to check on replacing the driver's side visor bracket. Both were very loose when I had the car and I did replace the passenger side one as it would flop down every time you hit the gas. I think the driver's side bracket was a bit tighter.
Kind of scary when you stomp on the go-pedal and an automatic blindfold comes down in front of your eyes!
Old 04-18-2014, 03:23 PM
Formulabruce's Avatar
The roof insulation must have been removed at some point.
" Long may we DRIVE !"
Old 04-18-2014, 03:29 PM
The Boss's Avatar
The Boss The Boss is offline
Looking good, how's it going?
And go racin' in the street.
Old 04-18-2014, 03:52 PM
Bentwheelbob's Avatar
What should it have looked like? There is some type of fiber type panel between the two roof layers, but no sign of any insulation ever having been attached to the inside of the inner roof? It's too late now and.....
It's going good. He's in the stretch, examine, re-stretch, steam, examine, and re-stretch phase. He's never done a Pontiac F-body before. Plenty of '67 to '69 Camaro's, but no second gen Firebirds. Apparently the retainer clips for the headliner bows are somewhat unique to the Firebird, and while he was figuring that out I was getting a little scared. However, I fixed him some boneless bbq pork ribs for lunch and since then he has come on strong. It's getting nice and tight. Just the way we like it...
Here's a few pic's after it was attached to the clips.
Old 04-18-2014, 04:28 PM
So while the upholstery guy guy has been doing his thing, I polished up the the rear side marker lights and grills (?). I spent most of yesterday buffing, polishing, shining, et cetera the rear of the Black Car. It needed to be done, and I decided that this should take place before the new bada_s bumper and bumper guards were installed. I removed the side marker lights to get a better job, and thought it only made sense to polish them while they were out. They cleaned up nicely.
Old 04-18-2014, 04:34 PM
The Boss's Avatar
What did you use on them Bob?
Old 04-18-2014, 05:25 PM
Pretty much the same as the taillights and front park lights, except I have abandoned the 3M headlight kit and am just using regular 3M wet dry paper and a R/O buffer. Sanded dry with 600 grit, 1000 grit and 2000 grit. Wet sanded with 3000 grit and 5000 grit. Then used the R/O with light polishing compound followed by wax. After that I used wax remover to get as much of whitish colored was out of the lettering as possible. It's getting a lot easier the more I do. I am looking forward to doing the headlight lens covers on my '99 F350 truck. They are so yellow....
Well, the upholstery guy has called it a day. i guess I should have had steak for dinner and then maybe he might have stayed and finished. Actually, I don't blame him. He has been wallowing around in the interior all day since 8:00am. He is pretty much done with the exception of reinstalling the trim, sail panels, shoulder belts, et cetera. He wants to let the top sit overnight and dry out from all the steaming, let the wrinkles relax, and see what the adhesive is going to do. I think that is a wise decision. He'll be back in the morning to make adjustments as necessary and install all the trim pieces and parts. Here's the pic's...
Old 04-19-2014, 01:34 PM
Default 00
So the headliner is done and it looks great. He only charged $200, and I gave him a healthy tip. The cleaned up sun visors look fine. I switched out the visor hardware and put the new bracket on the drivers side since as NJSteve pointed out it is tighter. I have also ordered a new mirror for the passenger side, and a new dome light as the base on the existing one was pretty badly scorched inside.
Lots going on here today and I have some questions that I will post up separately. Here's the headliner....
Old 04-19-2014, 02:43 PM
Judge273's Avatar
Judge273 Judge273 is offline
Man o man, that's a nice upgrade!
Mike/Illinois
Old 04-19-2014, 06:18 PM
Default Bumper and Guards
OK, where to start...
The bumper and the guards have been united. I was not looking forward to this. Too much shiny chrome, too much money, and too many previous threads talking about how the guards didn't fit the bumpers. Well, everything turned out well despite the worries. MPD was over today and his help was critical. No way one person could have done this. To protect the bumper while the guards were being aligned we wrapped it with stretch wrap. This worked really well. It was a bit of a pain to remove once everything was lined up and locked in, but the protection it offered was worth the extra effort. We also used a framing square to make sure the guards were plumb to the horizontal plane of the bumper.
There were no real surprises. At first it seemed like there was no way the guards would suck down to the profile of the bumper, or vice versa, but we slowly tightened everything up and voila it ended up being a great fit. As we installed the rear bumper brackets we measured center distances on the mounting holes on the back of the Black Car and it looks like everything should line up. That's right - I don't know yet if it will line correctly when mounted, but that's another story. Here's more than a few bumper pictures.
My Pal Dave
Pretty cool the bumper was chromed on my daughters 6th birthday
Old 04-19-2014, 07:19 PM
The Boss's Avatar
VERY nice!
Old 04-19-2014, 08:11 PM
RamAir's Avatar
RamAir RamAir is offline
Wow! Looking good
Old 04-19-2014, 08:35 PM
njsteve's Avatar
Amazing! So did Keystone actually have the bumper in stock?
Old 04-19-2014, 09:41 PM
VERY nice!
Originally Posted by ramair View Post
Wow! Looking good
Thanks, I'm beat, but it's starting to come together. All I need now is to get the radio back and the interior will come back together quickly.
No. I bought the bumper from a member here. It was part of a stalled project that got parted out. I just noticed today that it was chromed on Mini Me's 6th birthday. Pretty cool. I'm going to have her help with the installation.
Old 04-19-2014, 10:18 PM
Default Sign of the coming apocalypse
Ok, so here is a sign that the world may jump off the rails and go headlong into an unsynchronized orbit....
So before the bumper got installed I wanted to buff out the rear end of the car. Over the last few days I got everything but the tail panel and rear portion of the spoiler buffed and looking pretty good. Today MPD started on the tail panel and spoiler. I decided that it would be easier to do the tail panel if it was removed. Well once it was removed and brought out into the light of day it was obvious just how bad it looked and what bad shape it was in. On the back side is a big fiberglass patch, and the front had multiple areas with extremely bad finish.
After a little indecision I decided that before I took the tail panel to the body shop for repainting, I would take a swipe at it myself. So I wet sanded it with 400 grit, laid on multiple coats of high build rattle can primer, wet sanded again with 400 grit and then painted it with Rustoleum Gloss Black rattle can paint. If I do say so myself, it looks pretty bitc_in. I'm going to take inventory tomorrow and might do a light wet sand before applying a final coat of Rustoleum - or I might leave it just like it is. I've also ordered new letters for the tail panel, because the old ones just weren't in keeping with the new "high dollar" finish.
Does anyone know if you can color sand and buff out Rustoleum? Here's some pictures. Regrettably, I did not get pictures of the tail panel prior to the initial wet sanding.
Old 04-20-2014, 08:15 AM
The Boss's Avatar
....since I've gone this far I might as well.....
BTW - $200 was a killer price on that headliner installation - no matter where you live!
Old 04-20-2014, 08:39 AM
Judge273's Avatar
My GT -37 headliner was installed by two guys. Dan and Scott, and I wish I was there to witness that. I did not look at that invoice....
But, that's a great price and the guy came to you? Was that like 20 bucks and hour?
Mike/Illinois
Old 04-20-2014, 09:27 PM
Norwood's Avatar
Norwood Norwood is offline
Those two don't work cheap.......
Bob, I wish I had your energy.......nice work
Old 04-24-2014, 08:25 PM
So I'm back home after a few days on the road and the PONTIAC letters have arrived. They look great, but they came with cheap speed nuts to attach them. The shafts/pins on the letters are short and do not have any ridges for the speed nuts to grip. In short, I need another attachment method. It seems that I remember a thread that talked about using silicone or RTV on the backside of the tail panel and around the pins as a method of securing them. Does this ring a bell? Any suggestions?
<a href="http:
Old 04-20-2014, 08:44 AM
njsteve's Avatar
I think you'll have to wait quite a while for that Rustoleum to cure since it is an non-hardened enamel, before you can attempt sanding it.
BTW you can see where I used the propane torch to clear out all the brazing from the valance to lower quarter seam. The original installer of those NOS quarters thought the gap was not supposed to be there, and filled it full of brass after installing the quarters. One side was mostly body filler but the other was a brazed up solid. I gently heated the area with a propane torch and used a wire handbrush to brush it out. It made me real nervous when I originally saw it as I thought they used steel wire to fill it and that would have taken serious grinding to get it out.
The repair on that fiberglass tail panel is common- it comes from non-Firebird people trying to remove that panel and not knowing there is a single stud on the end, at the tip, holding it in place. One pull and the thin section snaps off.
