Getting ready to put my almost 588 hp 455 in my 1974 Trans am/firebird and last time I searched no one made a motor mount that's better than stock that would bolt in, am I looking in the wrong places, thanks, Smitty
1966 421 Bonneville convertible 1974 Transam w/ 600 hp efi 455 I build and modify Transmissions and rear ends. http://www.smittysengtrans.com/ |
did u look for mity mounts?
have them in my 600hp 74 T/A over 8 years now.
http://www.youtube.com/watch?v=3FfKVVZW1-Y Last edited by harry k; 09-28-2013 at 05:13 PM. |
The Following User Says Thank You to harry k For This Useful Post: | ||
Convert the frame to clamshell mounts, install clamshell brackets on engine. Problem solved.
The Following User Says Thank You to Schurkey For This Useful Post: | ||
I have Mity mounts in my 455 TA, less than a year old and my hood scoop comes within a quarter inch of my hood on normal acceleration. They're coming out! Going to the clam shell conversion.
1978 Black & Gold T/A [complete 70 Ram Air III (carb to pan) PQ and 12 bolt], fully loaded, deluxe, WS6, T-Top car - 1972 Formula 455HO Ram Air numbers matching Julep Green - 1971 T/A 455, 320 CFM Eheads, RP cam, Doug's headers, Fuel injection, TKX 5 Spd. 12 Bolt 3.73, 4 wheel disc. All A/C cars |
The Following User Says Thank You to FrankieT/A For This Useful Post: | ||
Mity mounts have 2, $50 bolts installed in cheap offshore mounts, other wise known as the $100 mistake.........................
![]() A 3/8" turnbuckle from the left head to the frame will do the same thing, installed in an hour for less than $10, plus it can be adjusted to have any amount of free play you want, if any. It worked very well for me however even though it's extremely functional, easy to install and cheap, some people won't use one. That's their choice. |
![]() Quote:
got a pic of your turnbuckle? not much space for one in a 2nd gen bird, espcially with power steering. |
Here's a picture of one I saw a few months ago, I'm not impressed with the Mity mounts I put in at the beginning on the summer.
thats a turnbuckle? looks like a chain attached to the upper a-arm cross shaft.
