Old 09-12-2013, 12:39 PM
Goatwhisperer Goatwhisperer is offline
Default Parting out a 69 lemans and 65 tempest
Losing storage space and parting these cars out. They were parts car for GTO restoration projects.
Gary
303-423-1117
Old 09-12-2013, 01:38 PM
pugslyx234 pugslyx234 is offline
What parts for the 69 you have?
Old 09-12-2013, 04:12 PM
GTO_6970 GTO_6970 is offline
Do you have the A pillar weatherstrip stainless pieces?
Old 09-12-2013, 04:29 PM
Default More detail
I should have mentioned it's a 4 door. however I may have the pillar trim as we have parted out several A body hard tops over the last couple of years. This 69 is an A/C car. I do not have a deck lid, or 2 door parts just a lot of little, pieces.
Old 09-13-2013, 12:28 PM
Daryls Daryls is offline
Default 1965 parts
I need a bunch of 65 parts, can I send you a list.
Tx
Old 10-11-2013, 10:03 PM
1lms 1lms is offline
Is the Tempest a 6 cyl car?
Old 10-13-2013, 08:15 AM
64gman 64gman is offline
Default looking for sail panel for 64, 65 lemans hardtop
Are the sail panels (panel that connects the rear quarter to the top) good on the 65 tempest? My 64 lemans had a vinyl top and when removed they were pretty ate up.
Old 10-13-2013, 08:57 PM
DOC DOC is offline
Is the 69 a disc brake car? Looking for the proportioning valve and metal brake lines from Master Cylinder to proportioning valve to brake lines for a front disc car.
Old 10-14-2013, 10:59 AM
blubiu65 blubiu65 is offline
Is the 65 a 2dr or 4 dr??
Old 10-18-2013, 06:57 PM
blue bayou blue bayou is offline
Default AC setup
How much on the ac setup and ducting?
Old 10-21-2013, 09:35 PM
nikaworld nikaworld is offline
Default 69 lemans parts
Do you have front running light lenses for the 69 lemans? I just need a drivers side but would take both if you have them. John 440-655-7844 or email
