Old 11-03-2013, 03:08 PM
1966geeto 1966geeto is offline
Default Console ideas
Any ideas on refinishing a 4 spd console top has a couple of holes drilled in it chrome not great not in the budget for a new one was thinking powder coat or doing like a hammered finish look on it open to any sugestions?
Old 11-03-2013, 03:34 PM
Jeff Hamlin's Avatar
What about going without a console until a later date.
Add dog dish and give that built to run look
Old 11-03-2013, 05:02 PM
My carpet is new but has been cut for an auto so I need to cover the holes.
Old 11-03-2013, 05:04 PM
Plus I have a nice vacuum gauge I'd like to show off
Old 12-06-2013, 10:31 PM
cfd2bc's Avatar
cfd2bc cfd2bc is offline
Here's what I did with one that was in pretty bad shape. I body worked it, shot the black, laid down the decal then cleared it.
kcmusclecars.com
Old 12-07-2013, 08:51 AM
Default Console
Came out nice..
Old 12-07-2013, 06:29 PM
BOB VIDAN BOB VIDAN is offline
Post a picture of the holes on the console.
Practicing social distancing for 65+ years
Old 12-07-2013, 08:13 PM
Default Console
Will dig it out..pretty rough
Old 12-08-2013, 07:49 AM
FWIW; You might go this route until you secure a better option?
http://www.ebay.com/itm/1964-67-GTO-...-/330404415053
They used one of these ABS deals on a customers '65 at the shop and I have to say it didn't look bad once installed.
It was a budget thing but in the end it made the crapped out console top look 100% better.
Old 12-08-2013, 06:41 PM
Default Console
QUOTE=BOB VIDAN;5080172]Post a picture of the holes on the console.[/QUOTE]
Name:	console 001 (Small).JPG
Name:	console 003 (Small).JPG
Name:	console 004 (Small).JPG
Name:	console 005 (Small).JPG
Name:	console 006 (Small).JPG
The holes around the rim by the shifter are the ones I'm worried about thanks.
Old 12-22-2013, 04:47 PM
dracowizard's Avatar
dracowizard dracowizard is offline
Default My option for mine
Of the two consoles I have one had holes in it also,a lot like yours and as if gauges had been mounted. The other has a slight crack just at the upper end where it mounts under the dash. I'll probably use the one that has the holes in it as I've blasted all the chrome off and will fill the holes with epoxy. Then I plan to paint the console a two tone without any chrome.I do have concerns when I go to mount as i'll be adding a Tremec 5sp and i'm not sure what floor mods i'll need to do yet. But considering my car isn't a true GTO my choices are along the restomod ideas i'm applying to my car.I have seen a thread discussing a quality chrome spray paint but I can't remember the name. Hope you find a resolve and update the thread.
Gotta Luv some old Muscle..
64 GTO Sedan Produced w/PwrSteering-PwrBrakes-AC-Padded Dash/Rally clock/ RemoteSideMirror
3sp&3:08/10 boltPosi-Pwr Windows-Pwr Antenna
Silvermist w/BlackVinyl Top
http://s161.photobucket.com/albums/t201/dracowizard/65/
Old 12-22-2013, 09:32 PM
Default console
sidetracked I was installing my refurbed instrument cluster and scratched the top of the column I covered it and dropped it down but still managed to nick it so I had to pull it back out and repaint it was beside myself but it's done started on the con sole using allmetal to fill the holes blasted it not sure but think I will powdercoat it
Old 01-06-2014, 01:03 PM
GT182's Avatar
GT182 GT182 is offline
Jeff, I take it the one on eBay was the plastic. I know it says a New part, but at least they could have said it was metal or plastic.
Gary
Get in, ShuT Up, Hang On!
"Crusin' Is Not A Crime"
Keep yer stick on the ice.
