Old 10-09-2013, 07:43 AM
Zyman's Avatar
Zyman Zyman is offline
Originally Posted by blue goats View Post
Zyman,
The ralley centers don't fit but the opening is smaller in the wheel so you could fab up something if you really wanted to.
George
George, Do your PMD caps have the spring clips or the aftermarket washer attachment? It looks like you could get them to mount using either of the attachment scenarios.
"Pride Precedes The Fall"
1968 Firebird Undergoing Transformation
1970 Formula 400 - Keylime Green, Stroked to 462 Cubes - Gone But Forever Remembered
2016 Mustang GT - GT with the Performance Pack, beats my former 12 Boss around the track.
  #142
Old 10-11-2013, 02:14 PM
Young Pontiac Guy's Avatar
Young Pontiac Guy Young Pontiac Guy is offline
Default Bird after US Mag Bandits
Here are a couple of pics outside.
Forgive the glare, or not!
ID:	339466   Click image for larger version
  #143
Old 10-17-2013, 06:08 PM
RAFO9A's Avatar
RAFO9A RAFO9A is offline
This is my Firebird, fresh from a suspension overhaul by Global West, resulting in a 1 inch drop at the front, 2.75 inch drop in the rear.
Fronts: 17 x 7 torq-thrusts, 4" backspace, 225/45-17 tires
Rears: 17 x 8 torq-thrusts, 4" backspace, 245/45-17 tires
Have to admit I'm strongly considering U.S. Mag's Bandit wheels...
Raffi R.
1968 Firebird: 350 .040 over, #11 Heads w/2.05/1.66 valves, Tomahawk TC-03 cam (214/221 flat tappet cam, 112 LSA, .0450/.0465 lift w/ 1.5 rockers), 200-4R w/3.55 gears, Street Demon 625 w/ Edelbrock Performer, H-Pipe dual exhaust w/Delta Flow 50's.
  #144
Old 10-19-2013, 10:14 PM
hada76's Avatar
hada76 hada76 is offline
Originally Posted by mudslinger View Post
Tires from Diamondback rear 255/50 Nitto 555, Fronts 235/50 Falkens
2 different brand 17" redlines, how did you work that?
___________________________________________
the more im around people, the more i like my dogs
  #145
Old 10-19-2013, 10:46 PM
mudslinger mudslinger is offline
We couldn't get the same brand in 255 and 235
Diamondback will cut for you whatever size or manufacturer tire available to them per your order
  #146
Old 11-02-2013, 09:43 PM
Formula jg Formula jg is offline
Posted a pic of my combo a couple of years ago but have made many changes to suspension including DSE UCA/LCA, 2" drop coil springs, hollow sway bar, 3" drop rear with composite spring, C6 Z51 13.5" front and 13" rear disc.
Front Nitto 255/45 and rear Nitto 285/40 on 17" YO snowflakes.
  #147
Old 11-20-2013, 08:14 AM
torqjunki's Avatar
torqjunki torqjunki is offline
That is SICK formula JG! Love the color too. What paint is that?
1971 Base Firebird..505ci IA 2A Round port E-heads by Butler 348 cfm.. Comp street SR 266/[email protected] Victor intake/Quick Fuel Q950. 1 7/8" Dougs headers..3" mandrel bent exhaust with Hooker Max Flow mufflers, T-350 well built with 10" 4000 stall nitrous Continental converter..3.73 posi . Caltracs and 10" slicks. Belt driven water pump, alternator, Pwr steering and brakes,Flex fan. 11:1compression, straight 93 octane pump fuel. 10.35 @ 129.88 with 1.45 60ft N/A at 3700lbs race weight.
  #148
Old 11-20-2013, 08:28 AM
Larry Navarro's Avatar
Looks like Nocturne Blue. I had a 79 t/a in that color. It is nice.
  #149
Old 11-20-2013, 09:30 AM
Thanks guys.
Actually it's a custom version of a (closes your eyes) Toyota color called "Dark Emerald Pearl Mica Metallic". We added a touch more blue, black and pearl and this is what we got when we painted it in '95 and if I were to do it again I wouldn't change a thing with this color, almost 20 yrs later and I personally still love it.
If I can sort out the brake bleeding I'll get it out of the garage and take another pic in the daylight.
  #150
Old 11-20-2013, 10:47 AM
Alvin's Avatar
Alvin Alvin is offline
Wink
Originally Posted by Formula jg View Post
Thanks guys.
Sounds very simular to TABob Wickers' previous 1980 TA 455HO w Richmond 6-spd project creation.
IIRC the color was supposed to be Brewster, but the paint & body peeps said the paint shop mixed it incorrectly. It still looked great, a Dark Emerald Metallic if you will. It too had blue tone mixed w the emerald. IIRC it was the same Brewster paint code # on the chart, just wrong application.
BTW - Yours looks great. How's the ride?
  #151
Old 11-20-2013, 11:07 AM
Thanks again for the compliments.
I can't speak on the ride just yet there are 3 areas I'm trying to address (brake bleed issue, toe-in aglinment and 17"YO hub bore oversize) before the snow hits. Hope to have these all worked out this weekend though.
  #152
Old 12-22-2013, 10:43 AM
DHVoorhees DHVoorhees is offline
Originally Posted by J.T. View Post
These are the polished Cragar Eliminator 500
front: 15x7, 4.125 bs
215/65R15
rear: 15x 8, 4.5 bs
245/60R15
Attachment 321192
Attachment 321195
I have a 1966 LeMans and looking for a similar wheel/tire combo that will fill the wheel well up as much as possible without rubbing. I have front wheel disks so 15" rims are the minimum size I can use. I'm guessing that the same wheel combo you have on the 67' would work on the 66' . I plan to use the American Racing -Torq Thrust II rims. Thanks for your postings.
-Daryl
  #153
Old 01-27-2014, 02:39 AM
72blackbird 72blackbird is offline
Default Ladies and Gentlemen, the 72 Blackbird has found her new shoes
US Mag 18 x 9 Bandits
275/40R18's F/R
H-O Racing 600 lb. front springs/WS6 rear leafs
  #154
Old 01-27-2014, 09:31 AM
Zyman's Avatar
275/40R18's F/R
Beautiful, now just mount some PMD caps, like the guys at "Restore a Muscle Car" are doing. http://www.ebay.com/itm/17x8-17x9-18...item4858dc27de
  #155
Old 01-27-2014, 12:07 PM
Zyman,
The PMD caps do really set the Bandit wheels off- I'm wondering if the Pontiac Chevron caps will work the same way. But the for the meantime the caps that come with the wheels look good enough for me.
Geno
  #156
Old 01-27-2014, 06:31 PM
1966goat's Avatar
1966goat 1966goat is offline
Send a message via AIM to 1966goat Send a message via Skype™ to 1966goat
For all you guys who bought those new throwback wheels, how do you like em?
461ci, Edelbrock 72cc heads, KB 15cc dished pistons, comp xe274, PRW 1.5 roller rockers, Performer RPM intake, Holley 80508 750cfm, RARE oversized manifolds, Pypes X-pipe Exhaust
  #157
Old 01-27-2014, 06:53 PM
First Bird's Avatar
First Bird First Bird is offline
Front
CCW 18x8.5 5" bs Michelin 245/40R18
Rear
CCW 18x10 5.5" bs Michelin 275/35R18
0.125" spacer
Mods
73 Chevy Nova 10 bolt rear
rolled fender wells
Disc conversion front & rear
Lowered 2 inches
- Tom
  #158
Old 02-25-2014, 05:13 PM
YO rallys in black
Just another option
Bill
  #159
Old 03-11-2014, 09:28 PM
john hadcock john hadcock is offline
Default 69 gto
I have a 69 gto 15 inch rims. The tires on the front are 215\65\15. I would like to go to a little bit taller tire to fill the wheel opening, say a 225\70\15. The 225 are 27.4 inches tall and the 215 are 26inch high. Would 27.4 be too big around?
  #160
Old 04-20-2014, 10:18 AM
flunkie flunkie is offline
YO rallys in black
Just another option
Bill
I would love to see a full car shot with the black painted Year Ones !
