Old 09-11-2013, 08:17 PM
RAIV-Z's Avatar
RAIV-Z RAIV-Z is offline
Oil Pressure reading, measured at the front passenger side on the IAII.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #862
Old 09-20-2013, 05:54 PM
67'7F6'Bird's Avatar
Here are some updated photos from the Chassis shop, they are working on the TIN.
Since Ed has been working on the PILE of Mccarty RAV Heads over the past year to Resolve the Problems including the Valve train, Rocker Pads Improperly machined and Sloppy Mounting Holes, Improperly designed Camshaft Supplied, and Oil Pressure Issues - Not Disclosed to him, the list of corrected issues goes on and on. His Brand New Delivered engine from McCarty has been completely gone through and Rebuilt to hopefully correct all the bogus work previously done by McCarty & BES.
ID:	337345   Click image for larger version
  #863
Old 09-20-2013, 06:05 PM
cgeise's Avatar
cgeise cgeise is offline
Here is a hint - put plastic liners inside those wheel tub's -
  #864
Old 10-01-2013, 05:31 PM
RAIV-Z's Avatar
Do you have a recommended source for those liners?
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #865
Old 10-01-2013, 07:14 PM
cgeise's Avatar
You dont need a lot - 1/8in will do and any plastic's shop can get you a good tuff black sheet of the stuff -- It really saves on the dents
  #866
Old 11-14-2013, 10:51 PM
RAIV-Z's Avatar
Last weeks update from the chassis shop.
The RAIV-Z will be ready for the road soon.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #867
Old 11-22-2013, 10:57 PM
RAIV-Z's Avatar
With the latest addition, the drivetrain is just about complete.
[/URL]
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #868
Old 11-23-2013, 12:05 AM
LiL Jack's Avatar
LiL Jack LiL Jack is offline
Dude, u are building a phucking camaro!"?
[email protected]. 3460#s
  #869
Old 11-23-2013, 12:09 AM
RAIV-Z's Avatar
Maybe...
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #870
Old 11-23-2013, 12:21 AM
LiL Jack's Avatar
Jeez, as bad as that Bill Anderson guy
  #871
Old 11-23-2013, 12:23 AM
RAIV-Z's Avatar
Kidding, that not my twin turbo car. It is Pontiac RAIV powered though.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #872
Old 11-23-2013, 12:45 AM
Curious George's Avatar
Curious George Curious George is offline
As long as its Pontiac powered. That'll PO the Chebby guys lol.
Whitmore 462, 670 heads 10.55@125
Same with 310 E D-ports 10.12@131
498 w/single 88 8.53@158
  #873
Old 11-23-2013, 12:55 AM
RAIV-Z's Avatar
It's only a little ~500hp rear wheel pump gas RAIV with a stick . It almost got the TT-RAV.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #874
Old 01-20-2014, 04:36 PM
RAIV-Z's Avatar
Drivetrain final location has been set, left enough room to fit the slightly larger DCI RA-V head if needed.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #875
Old 01-20-2014, 06:06 PM
charlie66's Avatar
Looking good! Are those injectors billet atomizer's?
My Half AN Injun.....
  #876
Old 01-20-2014, 06:20 PM
RAIV-Z's Avatar
Thanks Charlie,
Yes, 235 LB/HR.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
The Following User Says Thank You to RAIV-Z For This Useful Post:
  #877
Old 01-20-2014, 07:05 PM
cgeise's Avatar
Getter done
  #878
Old 01-20-2014, 08:35 PM
charlie66's Avatar
You're welcome..
What are you using for fuel?
  #879
Old 01-20-2014, 10:16 PM
jdw_poncho's Avatar
jdw_poncho jdw_poncho is offline
Looks great!
Did you run the stock filter mount while on the dyno?
  #880
Old 01-20-2014, 10:20 PM
RAIV-Z's Avatar
You're welcome..
Planning on using C16
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
