Old 08-02-2012, 09:06 PM
MD79TA MD79TA is offline
Default Tachometer trans am wiring help
Can anyone tell me the color of the Tach and power wire that goes to plug on the back of the tachometer, looks like white and pink but I am told it should be brown and pink . 1979 Trans Am 400 4 speed. Thanks Doug
Old 12-13-2013, 12:56 PM
T70GTO's Avatar
T70GTO T70GTO is offline
Saw this old post. Great article in HPP this month. 3 wire design. Ground thru cluster,brown wire for negative coil terminal,pink/black wire to 12v terminal on fuse block.
Mine not working either and will check this
70 RA3 Judge 4spd Orbit Orange
66 389 GTO Tri Power 4spd Montero Red
77 400 TA Auto Starlight Black
02 Trans Am WS6 Auto Sunset Orange
Old 12-13-2013, 03:00 PM
If your tach is not working you can repair them by just changing out the chip in the back of the tach. It is round & has 4 prongs on it that just plugs in to the back of the tach. If you can find a tach that the face is all worn out or one that is cheap you can use the chip from one of those to repair the tach you have. I use to repair the hood tach's with the chips from the dash tachs, & it worked fine. The chips work in all the tachs, all they do is unplug from the back.
Old 12-13-2013, 03:13 PM
T70GTO's Avatar
Good info Rex Thx
Old 12-13-2013, 09:31 PM
T70GTO's Avatar
Default 79 Trans am tachometer not working
Guys, my 79 tach only seems to have 2 wires out the back plug. One is white and one is pink/black. HPP article this month said should be 3 WIRE. Is it possible to have 2 wire. any thoughts? Very low mileage original car so I have no reason to believe anything was changed? thx Tom
Old 12-13-2013, 11:24 PM
Ben M.'s Avatar
Ben M. Ben M. is offline
Originally Posted by T70GTO View Post
any thoughts?
All of the '75-81 Trans Am tachs I've worked on have been 2 wire: +12V pink and coil is brown or white depending on year. The case is grounded through the cluster housing. Earlier ones may be different and require a separate ground lead that HPP is referencing.
Old 12-14-2013, 04:43 PM
Correct the later ones 75+ are grounded through the cluster itself & then the lights are in the circuit board plus the later HEI units plug directly into the dist. so they only need the 2 wires to power them. The earlier ones 74- needed the extra ground to the coil for the power / ground source.
Old 11-19-2022, 11:20 PM
Jon Salem's Avatar
Jon Salem Jon Salem is offline
What is HPP?
PontiRocket
Old 11-19-2022, 11:38 PM
Jon Salem's Avatar
What is HPP?
PontiRocket
Old 11-20-2022, 09:13 PM
Been a few years.but that was high performance Pontiac . You might find some old books on EBay . I started this thread 10 years ago and sold that car and now my son had two more 79 trans am . If you got question we will try to help. Doug
1979 Trans Am
307 RWHP 380RWTQ
13.8@103
1979 400 Block, 1970 Heads, Unknown Cam, Comp Cam Lifters, Edelbrock RPM Intake, Hedman Headers, Holley 750 Carb, WFO Drop Base SOLD
1968 GTO convertable project. 400 auto with air. west coast car . Not started in 15 ..update now running (around block spinning tires all the way. Have a lot of cosmetic work to do winter of 17/18
1969 GTO 400 4 Speed this a complete project. Rebuild will start in spring of 2017. SOLD
