Old 12-19-2013, 09:10 PM
Firebob's Avatar
Firebob Firebob is offline
Default Pressing New Rods On
Pulled my pistons out yesterday and want to get the old rods pressed off and the new ones on. Do I need to remove the rings before I take them to the shop?
Robert
69 Firebird-462/Edel round ports/currently running the Holley Sniper/4sp/3.23posi/Deluxe Int/pwr st/vintage air/4wl disc( a work in progress-always )
http://youtu.be/eaWBd3M9MN4
Old 12-19-2013, 09:22 PM
54nomore's Avatar
54nomore 54nomore is offline
At the machine shop I worked at, we used a rod heater for assembling the rod and piston. We only used the press to disassemble.
Anyway, the piston holding fixture on the rod heater works better if there are no rings on the pistons. Are you planning to re-use the rings?
Old 12-20-2013, 12:20 AM
Firebob's Avatar
I was figuring as much but thought I'd ask anyways.
Yeah, was planning on reusing the rings. Only have about 5K miles on them.
So the rod heater heated the rods enough that the pins slipped in place by hand?
Robert
Old 12-20-2013, 12:29 AM
54nomore's Avatar
that is correct
Old 12-20-2013, 08:01 AM
MotorHead_811 MotorHead_811 is offline
The shop I work at we usually hottank the pistons and rods than press them off usually when u press the pistons off it burrs up where the wrist pin sits in the piston. So we put the piston in the rod honing machine just for a quick clean up so wrist pin goes through the piston with no problems. We heat our rods up in a sunnen rod heater from the 50's(still works like new) and the wrist pin will slide right through the rod
78 firebird 400/t400
Old 12-20-2013, 08:07 AM
steve25 steve25 is online now
I would remove the rings to play it safe, as any little nick in the compression rings face and your done.
Be sure to sprill the rings off the piston with the lease amount of expansion that you can because if you bend them the least bit oval then that ring is vertually usless.
Old 12-20-2013, 09:08 AM
PONTIAC DUDE's Avatar
Cool
If your shop is burring up the piston. Then you don't have the right equipment.
Old 12-20-2013, 10:29 AM
gtofreek's Avatar
gtofreek gtofreek is offline
We use tool that slips in between the rod and piston so you press directly on the rod while the piston if free floating the whole time. This fixture does not burr the piston.
The old shop I worked at, we had to press directly on the piston. We usually weren't worried about reusing the piston though, as it was usually cracked or the pin hole was pinched in. Sometimes a piston would shatter if it was odd shaped. I didn't like that setup. What we have now is much better.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
Koerner Racing Engines
You killed it, We build it!
520-294-5758
87 S-10 Pickup, 321,000 miles
99Monte Carlo, 293,000 miles
86 Bronco, 218,000 miles
Old 12-20-2013, 12:53 PM
track73 track73 is offline
A couple years ago I junked about 40 pontiac cast pistons. They still had connecting rods attached. So to get max from the recycler it removed them with a tool I made from some pipe and a deepwell socket.
I have installed press fit rods using a mapp torch and an infared temp guage. When the rod got to 350 or 400 I slipped the pin in. I practiced with a few junker pistons first, but the engine still runs strong with that slug in there.
Old 12-20-2013, 09:50 PM
Firebob's Avatar
Well I called two different shops today to get an idea and of course the one closest wanted $100 to R&R the rods on my pistons and the other one that is a bit farther away, so less convenient but has a real good rep, is $60 and $150 to deck the block. Think I'll go with the reputation. Now to order up some bearings and a gasket set and I'll be chomping at the bit to get it back and start putting it back together with the roller cam and round ports. It's starting to feel alot like christmas around here.
Robert
Old 12-20-2013, 10:59 PM
The tool we have is from Goodson and is made to just to press old pistons off mostly we hardy reuse pistons but every so often we do. My boss is 70+ years old and doesn't want put to much money into the place anymore so getting new tools and machinery doesn't happen to often.
Old 12-21-2013, 09:49 AM
Red face
Hell.......... I'm 64 and still buying tooling to keep up with newer design engines and upkeep. LOL. Bwahahahahahahahahahaha.
Times do get tight with the cost of shop supplies, equipment upgrades and basic overall upkeep and overhead. Then ya have the prices you should be charging but can't.
Costs are wayyyyyyyyyyyyyyy out of hand the manufactures have created to increase their profits and sell less. And people wonder why shops are closing down or fewer shops being created.
Carry on.
Old 12-21-2013, 10:54 AM
Carry on.
Plus he has a 12 bay full repair garage and a autobody shop so trying to up keep all 3 places isn't easy
