Old 12-21-2013, 06:25 AM
john marcella john marcella is offline
Mike,
Why do you or Gaby not answer Aaron's question.
Stan
I will.
If 2 motors make the same peak hp.
Motor A makes it at low rpm 6000.
Motor B makes it high at 9500.
Motor B will be faster down track because, when the hp peak is at a higher rpm the amount of rpm between TQ peak and HP peak is further apart. This means that there will be more average power under the usable rpm cure. The high rpm motor will not fall off as aggressive after TQ peak ,same with after HP peak. The result can only be more average power.
Don't forget that past peak is as important as below peak. If you can make the same HP at peak but not fall off as fast past peak, this will let you raise the rpm of the shift point consequently giving you more power under the curve.
You can get all the TQ you want with gear ratio.
Also I would think the spot that has the best ability to accelerate the car is at hp peak.
TQ is how much work it can do. HP is how much work over a period of time.
We race time
John Marcella
Marcella Manifolds Inc.
[email protected]
ph. 248-259-6696
  #382
Old 12-21-2013, 06:35 AM
JD311's Avatar
JD311 JD311 is offline
well im switching to imports!
  #383
Old 12-21-2013, 07:57 AM
Stan Weiss's Avatar
Originally Posted by john marcella View Post
I will.
We race time
Mike,
Can you please explain your physics to me.
Mine goes like this.
800 HP @ 6500 = 646.4 torque
800 HP @ 9500 = 442.2736842105263 torque
What is important is what we can delivery to wheel to accelerate the car.
9500 / 6500 = 1.461538461538461
1.461538461538461 * 442.2736842105263 = 646.3999999999997
So at 6500 axle RPM they both produce torque of 646.4
Now if you want to talk about 2 engines producing the same torque but at different RPM you are on to something.
Stan
John,
Using a a stick / clutch car to take the variable of the torque converter out of the picture.
Max acceleration is at peak torque. Log G force and RPM and plot it out. After each gear change G's will be the highest at that point and drop until you shift into the next gear.
At 9500 you will see a greater drop in RPM after the shift than you will at 6500 but the percentage of drop will be the same.
Stan
Pontiac Pump Gas List
  #384
Old 12-21-2013, 08:32 AM
We all know that the more power pulses that happen in a given amount of time more work is being done -- therfore a better E.T.. An extreem example would be a 400 hp diesle where power is maxed at 2200rpm and a 400hp small block making max at 7000, given the same weight and set up properly the small block will win the race.
Tell me this truck is slower than Jack's car?
Bank's Diesel truck
1300 HP @ 5500 RPM
Jack making 1300 HP (?) @ 8000 RPM (?)
So you guys reasoning the diesel is a pig right?
I just double face palmed so hard it hurt.
Stan you are lost in the space between your ears. You've tried squirming all over the map on this to change the subject in failed attempts to make some incoherent ...thing. Now you claim its me changing the subject. Clearly your "geniusness" is blinding you from how it really works in the real world. I'm done with this. Sad part is you will carry on with your self appraised expert opinion and mislead some poor guy along the way into spending money in the wrong places. Why don't you help some na CV1 guy get in the other lane and get a look at the back bumper from a distance....of my old a$$ crappy eheaded firebird. Should be easy for such a smart guy and a superior canted valve head.
Double quoted for double stupidity.
Originally Posted by mike leech
they don't want to get it.
I really don't know what I could say to further what I mean. All I know is its faster at the higher rpm.... I know this for a fact... I'm not saying know it all .Just what my car likes....
Neither of you seem to get it?
Charlie if you're going faster at the higher RPM, then you weren't making your peak power where you thought?
Running quick at a higher RPM is not the question here?
It's 2 different engines at the SAME HP but different RPM's.
It takes a certain amount of HP to run an ET at a given weight.
How it makes that HP is not real important.
(or by what engine manufacturer)
If Leech has 1000HP NOS engine and I have a 1000 HP N/A engine, in the same weight/car they should run exactly the same.
If they don't the slower car needs to work on his combo to utilize that HP.
Simple as that.
Can't explain it any better.
  #385
Old 12-21-2013, 09:32 AM
charlie66's Avatar
Bank's Diesel truck
1300 HP @ 5500 RPM
Simple as that.
I thought you guys were comparing 2 different engines making the same hp at different rpm peaks.. I have a question. Why would the motor spinning faster not effect the shift from hitting the tire harder. Its like if I punch the wall from 3"s away and then punch it from 12"s away . The momentum helps the impact. I would think the rotating assembly spinning faster would have that same effect.. If I got the question wrong, Then I apologize.. I also think if you are shifting higher then it will drop the same amount because the fact of, more rpm more tire speed .
I dynoed my motor in the car. I do know exactly where it made peak hp..
As for the comparison of the NOS car and the NA car. I would think the 2 would have different characteristics. Which may change where it would perform the best down the track.. As for which on is better got me , Just sayin....
My Half AN Injun.....
  #386
Old 12-21-2013, 09:50 AM
3fastgtos 3fastgtos is offline
The higher I shift the better my engine sounds and that makes me feel better
The Following 5 Users Say Thank You to 3fastgtos For This Useful Post:
  #387
Old 12-21-2013, 09:52 AM
1st dynoing in the car is one of the problems with that style setup.
It's not good for telling how it reacts going down the strip.
Plus lots of things can detract from the 'HP' number they give you.
(tire/roller slip, converter cars not using the converter right, etc)
The gear change RPM situation is a combination problem, not the HP problem?
You need to figure out where the engine likes to run with your power band.
The HP is the same whether you shift at 6800 or 7500 at each respective RPM point.
So if it likes to go faster at 7500 RPM, shift there?
  #388
Old 12-21-2013, 09:54 AM
Yep.
Until you find the breaking point or the power falls off drastically.
As said before, it's not how high you can rev the engine.
  #389
Old 12-21-2013, 09:59 AM
Daniel Barton Daniel Barton is offline
Bank's Diesel truck
1300 HP @ 5500 RPM
Simple as that.
Your comparing a vehicle that weighs about 1000 pounds less than Jacks car to his, and you believe that you have explained this? Please explain why at 1300 hp at 5500 it runs a half a second slower than a legal pro stock truck making about 1000 hp at 9800.
Life is hard, it's even harder if your stupid- John Wayne
The Following User Says Thank You to Daniel Barton For This Useful Post:
  #390
Old 12-21-2013, 10:01 AM
Jeff Kinsler's Avatar
Jeff Kinsler Jeff Kinsler is offline
you guys have way to much free time on your hands
540 c.i. Ultra Street Combo
Tiger Heads with Tiger Intake
Induction Solutions fogger with .046s
1.079 4.52 155.15
3000 lbs
7.77 @ 169 1/4 Mile (2015) with EHTTFMF!!
7.17 @ 188 1/4 mile (2024)
Special Thanks to:
Ron at Rhodes Custom Auto
Butler Peformance
Jim Hostler's Transmissions (HOSGTO) on here
Induction Solutions
BES Racing Engines.
Cheeseburger
VP Racing Fuels
Calvert Racing
The Following 6 Users Say Thank You to Jeff Kinsler For This Useful Post:
  #391
Old 12-21-2013, 10:07 AM
60man's Avatar
60man 60man is offline
We still talking about L'll Jack's heads ?
Have at it..
ECM member.
2008 Outlaw Pontiac Drag Series Champion
MANDRA
Do it now fool! Life is short.
69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. through mufflers. 1.26 60'.
Going back to track with pump gas engine....
My 60 Ventura retired to street/strip duty..
  #392
Old 12-21-2013, 10:13 AM
slowbird's Avatar
slowbird slowbird is offline
Or maybe you don't have enough?
  #393
Old 12-21-2013, 10:29 AM
charlie66's Avatar
I think my combo is fine. With 538 rear wheel hp car weighing 3370 with me in it. 9.90. im happy...
  #394
Old 12-21-2013, 11:21 AM
PONTIAC DUDE's Avatar
Talking
Have at it..
Bwahahahahahahahahahahahaha.
  #395
Old 12-21-2013, 11:25 AM
GTO Dan's Avatar
GTO Dan GTO Dan is offline
"It's the most wonderful time of the year..."
I always thought that song was only about Christmas.
The Following User Says Thank You to GTO Dan For This Useful Post:
  #396
Old 12-21-2013, 12:11 PM
mike leech's Avatar
mike leech mike leech is offline
Dang I slept good last night.
This is about what i expected to read when i opened this. the MORON computer racers need to have a convention and one of the topics should be unless YOU have done it stop giving advise. You've heard it from a few reputable sources and still carry on with your fingers in your ears convinced you two dolts are the only ones that get it.
THATS WHAT ALL THE CRAZY WEIRDOS THINK ABOUT EVERYTHING IN THEIR LIFE, FROM CAT FOOD TO CALCULATORS THEY ARE RIGHT AND WE ALL NEED TO REALIZE IT! YOU 2 ARE NUTS! FOR CLARITY I MEAN STAN AND JOHNTA1 YOU 2 ARE BATSHXT CRAZY.
EHTTFMF!
Being dead, it is not hard on you. You don't even know you're dead. It is hard on everyone else that is not dead.
BEING STUPID WORKS THE SAME WAY! The rest of us suffer.
The Following User Says Thank You to mike leech For This Useful Post:
  #397
Old 12-21-2013, 12:43 PM
Originally Posted by Half-Inch Stud View Post
Suppose 1 engine has 600 HP at 8000 rpm, vs an engine with 570 HP at 6000 RPM.
when a fella plots the HP & TQ of each engine, the 570 HP @ 6000 RPM may jump out as a real gem. I'll pick that 570 HP @ 6000. HIS
This is only clear to the frustrated when plotted. the 570 HP engine is making far more power from 4000-to-6000 whereas the 30 extra Hp from the other engine yielde less power under the RPM range of usage.
If the question was 570 HP @ 6700 versus 600 HP @ 8000; is the choice clearer.
if the 600 Hp was at 18000 RPM the choice should be painly clear. HIS
Gearing & rev range have inertia & take power, yet what is the engine power (HP) across the applied rpm range? Power is power, yet we need POWER over applied rpm range.
TQ converters that really really really work may allow an argument favoring the higher RPM engine. me thinks the really effective converters can be had for the lower rpm engine for better TQ-multiply. so the better converter argument is for another thread. Otherwise, where's that ideal CVT transmission?
  #398
Old 12-21-2013, 01:00 PM
The engine with a higher rpm limit will be faster then an equal hp engine with a lower rpm limit. The higher rpm engine can be geared lower which will give it a mechanical advantage in accelerating faster over the entire span Its been proven. There are many other factors that make this true aswell but that is a big one.
  #399
Old 12-21-2013, 01:01 PM
mike leech's Avatar
I love ya man but you'd be wrong. Example; my converter flashes to 7000 i shift a 8100 and it drops to 7300 on the gear change. How much time do i spend NOT between 7300 and 8100? About .2 seconds if that. So who cares what my engine makes below 7300 as long as I can efficiently get it to 7300. My car sure don't care. If I made the same power and operated the engine between 7800 and 8600 IT WILL PICK THE CAR UP. Couple hundredths at least.
EHTTFMF!
  #400
Old 12-21-2013, 01:02 PM
mike leech's Avatar
Funny how all the fast guys get it.....Oh wait I forgot about the kre thing so your opinion wont matter like mine.
EHTTFMF!
