Old 12-20-2013, 10:36 PM
David Jones's Avatar
Default Engine Picture.
Because.
Seems to be running well.
Feel free to add yours.....
Old 12-21-2013, 05:50 AM
428GTO70's Avatar
428GTO70 428GTO70 is offline
Send a message via MSN to 428GTO70
Nice clean engine David!
Its been a while since I added any pics of mine as well so I'll jump in on the fun. I decided not to bring my engine to get dyno'd because I just wanted to get it in the car already. Also getting the EFI all setup to work at the dyno was my main discouragement. Here is a pic of dropping it in and a shot of it setting down with headers attached. Its been a while since I touched it now though since the cold hit however. I may bundle up and do a few things to it tomorrow.
1970 GTO 458 CID .040 over 4 Bolt 428 Block, Forged Eagle 455 Crank, 295 CFM SD KRE D-Ports, SD Old Faithful HR Cam + Comp HR Lifters, PPR Maxx-lite rods, Racetec pistons, PRW 1.65 SS Rockers, 900CFM Holley HP TBI, Performer RPM, Hooker Super Comps, 3" X-Pipe into 2.5" mufflers/tailpipes, 2.75 1st TH400, Continental 13" Converter, 8.5" 3.08 Posi.
Everything installed, fired up and tuning has begun!
Old 12-21-2013, 07:32 AM
Jeff Hamlin's Avatar
Talking
The Following 2 Users Say Thank You to Jeff Hamlin For This Useful Post:
Old 12-21-2013, 09:02 AM
Jeff, that's fantastic. Love those OHC 6's.
428, how far off is crank it day?
Old 12-21-2013, 12:47 PM
1969GTO's Avatar
1969GTO 1969GTO is offline
Default my 462
here is my 462 at Spotts Performance,the engine is home nowClick image for larger version
color me gone
Old 12-21-2013, 01:09 PM
428GTO70's Avatar
Well it could be as soon as I want it to be really, however being that its like 10 degrees outside and my garage isn't heated there really isn't any motivation. My plan is to AT LEAST bring in the 8.5 rear I have and have the gears set up, remove the old rear end and install the 8.5 and then get a new driveshaft made before spring. Anything else I get done would be icing.
Then when it gets warm enough to motivate me I will finish it up and fire it in early spring.
And that's a nice looking sprint motor Jeff
Old 12-21-2013, 01:27 PM
10 degrees......no doubt!
Old 12-21-2013, 01:30 PM
Firebob's Avatar
Firebob Firebob is offline
Don't see those Sprint motors everyday that's for sure. Nice.
This was the last version of my motor. Getting to the point where you can't hardly see it under all that crap anymore. Of course now it's hanging on the stand right now awaiting it's newest incarnation for next year.
Name:	firebird parts 002.jpg
Robert
69 Firebird-462/Edel round ports/currently running the Holley Sniper/4sp/3.23posi/Deluxe Int/pwr st/vintage air/4wl disc( a work in progress-always )
http://youtu.be/eaWBd3M9MN4
Old 12-21-2013, 01:50 PM
WARPed's Avatar
WARPed WARPed is offline
Here are a few pics of my 94 bird with a CV-1 headed 505. I should add a few people have asked if it was a RAV.
ID:	347124   Click image for larger version
ID:	347125   Click image for larger version
1994 Formula
535ci NA CV-1 - single 1050 with c14 - 940hp@7000/825tq@5200
Pontiac Powered 4th Gen Project Progress
Old 12-21-2013, 04:16 PM
johnsma22's Avatar
johnsma22 johnsma22 is offline
Can't resist the opportunity...
John
"There are no stupid questions, but there are a LOT of inquisitive idiots!"
Old 12-21-2013, 04:17 PM
gtofreek's Avatar
gtofreek gtofreek is offline
You guys all have some very nice looking engines there! Great job!
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
Koerner Racing Engines
You killed it, We build it!
520-294-5758
87 S-10 Pickup, 321,000 miles
99Monte Carlo, 293,000 miles
86 Bronco, 218,000 miles
Old 12-21-2013, 04:53 PM
No doubt. Quite a broad range of great looking Pontiac's.
Anybody else with an engine?
Old 12-21-2013, 05:24 PM
Blued and Painted's Avatar
Blued and Painted Blued and Painted is offline
Nothing Fancy
Bull Nose Formula-461, 6x-4, Q-jet, HEI, TH400, 8.5 3.08, superslowjunk
The Following User Says Thank You to Blued and Painted For This Useful Post:
Old 12-21-2013, 07:43 PM
72projectbird's Avatar
Here's my 455
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
Old 12-21-2013, 07:52 PM
Old 12-21-2013, 08:18 PM
Wink One day......1964 421 HO
Old 12-21-2013, 08:23 PM
mechanickeith's Avatar
mechanickeith mechanickeith is offline
My high milage motor. 549K on the car.
Keith Collier
61-63 Pontiac Tempest
Tech advisor
POCI.org
Old 12-21-2013, 08:33 PM
400 plus's Avatar
400 plus 400 plus is offline
Old 12-21-2013, 08:44 PM
Here's my 455
No air car? Love it.
Old 12-21-2013, 08:45 PM
Keith, somebody took half......
