Old 01-18-2014, 01:44 AM
transam1972 transam1972 is offline
Default FIREWALL XL-5
Name:	SHAKER GROUND CLIP.jpg
The Following User Says Thank You to transam1972 For This Useful Post:
  #82
Old 01-18-2014, 01:52 AM
Default INTERIOR
Name:	REPOP KICK PANELS.jpg
Name:	E BAY PLUG N PLAY COURTESY LIGHTS.jpg
  #83
Old 01-18-2014, 02:59 AM
Default INTERIOR
Name:	AM FM STEREO.jpg
Name:	PDL & EDF.jpg
Name:	GM PLATE  & ORIG SCREW.jpg
Name:	SR REAR SPEAKER.jpg
  #84
Old 01-18-2014, 03:08 AM
Default random
Name:	ALARM LOCATION.jpg
Name:	FIREWALL DETAIL 2.jpg
Name:	INNER FENDER LEFT.jpg
  #85
Old 01-18-2014, 03:17 AM
Default random
Name:	CHASIS DETAIL.jpg
Name:	FRONT INNER FENDER.jpg
Name:	FRONT INNER FENDER 1.jpg
Name:	INNER FENDER.jpg
  #86
Old 01-18-2014, 03:31 AM
Default random
Name:	front shock mounting.jpg
Name:	FRONT SHOCK MTNG BOLTS.jpg
Name:	HORN RELAY.jpg
  #87
Old 01-18-2014, 03:40 AM
Default PAN LABRYNITH
Name:	OIL PAN 2.jpg
Name:	OIL PAN 3.jpg
Name:	one piece gasket.jpg
Name:	ORIGINAL RALLY  II.jpg
Name:	PAN INSTALLED.jpg
  #88
Old 01-18-2014, 03:48 AM
Formulabruce's Avatar
love the pics, thanks for posting, but where is the land speeder?
" Long may we DRIVE !"
  #89
Old 01-18-2014, 03:59 AM
Here is one worth a supersize!!
  #90
Old 01-18-2014, 04:35 AM
Default 20/20
I will dig out the Landspeeder and throw in a Cloudcar...I have many Formulabruce, but one of my regrets is tossing my original leafsprings,on top of my original fenders in 1990...I actually did not really need new ones and had I kept them I could have atleast given them to you!!...and had I saved the fenders I could have a nice vacation with the cash...
  #91
Old 01-18-2014, 02:35 PM
Looking at pic below, the "new one" ( far left) is actually a GM for another application. The rubbers, what are those? The gm ones are wrong and are 1 1/8th and dont fit the 1-1/4 bar and are too tall.. I ordered some 1LE ( 3rd gen) bushings but who knows what they even look like. thoughts?
  #92
Old 01-18-2014, 03:22 PM
Default repop bracket & bushing
the far left bracket is from P.Y. and is a repop for the original 1 1/4" front sway bar and is listed in the catalog, the bracket to the right is my original...in the early 90's I upgraded to urethane which is better...now with this correct business I am doing my best to compromise!...typical though, some how I lost one of the originals during the lost years...I believe NJSTEVE said that the original style bracket is also used on other GM products...but I could not find one...however in some ways this repop front bracket is better than O.E.M. as it has sides which secure the repop bushing...if you look at the repop bushing you can see how well the bracket will accept them...AMES sells them in the exact same design as you see here (the 1 1/4'' bushing) and possibly P.Y. lists them too, however these particular ones are from The Parts Place and they seem to be a blacker nicer reproduction...I sent my AMES back as they had a white flaky release film and were more light black...anyway I prefer the P.Y. repop bracket and everything, both front and back fits perfect so I am calling it a day with those parts!!..I definitely use reproduction items but it is a slippery slope!!!!...unless of course someone has atleast one of those original style brackets?!!..but really, even my one original bracket is rusty underneath and it will never be brand new again, so I would recommend this set up I have...especially if someone needs everything...the rear brackets are a 100% duplicate reproduction, but I could only find my 7/8 '' bushings on EBAY at a Corvette site
  #93
Old 01-18-2014, 04:19 PM
The PY bracket/bushing holder is no reproduction. Its a GM part for a truck/car. ( not ours) That said, it is NOT the 1995 3/4 ton diesel suburban bracket, THAT is discontinued. ( Idea on this from NJ Steve). The '95 'Burban bushings are available and are 1-1/8th, and although not big enough, are a bit Tall, and do have the typical powder on the rubber. Of note, they DO have the correct "nub" on the bottom that fits in the "indent" in our subframes. I feel its a bit long/ tall? , even if I could find a way to make the hole bigger in a uniform fashion. See pics.
ID:	349888   Click image for larger version
  #94
Old 01-18-2014, 04:26 PM
Default air dams
Name:	nos amber lens.jpg
Name:	nos air dam.jpg
Name:	1976 air dam moulded in colour.jpg
  #95
Old 01-18-2014, 05:16 PM
Default body
Name:	72 original spoiler trunk not aligned.jpg
Name:	needs welting.jpg
Name:	NEW GM QUARTERS.jpg
  #96
Old 01-18-2014, 05:20 PM
Default body
Name:	bumperette option.jpg
Name:	BLUE NOS STRIPES.jpg
Name:	needs polish!.jpg
Name:	rear panel detail.jpg
Name:	pulling a wheelie out of the garage!.jpg
  #97
Old 01-18-2014, 05:22 PM
SD73's Avatar
SD73 SD73 is offline
Question for ya, Glenn. What welting are you using on your spoilers? Is that NOS stuff? I've heard Danko and Ames sells some that's pretty close to original.
  #98
Old 01-18-2014, 05:34 PM
Default spoliler welting
the oem front spoiler and front airdams have the GM original..and I am just missing for one air dam...I see there is a new welting with a pull off tape so there is adhesive on the welting...fortunately mine have good fit but yes I need one piece of welting and need to match it...the darker air dams are GM nos made in Mexico and the white one I salvaged from my 76 T/A as it was brand new...but the moulded white welting turned funky!!
  #99
Old 01-18-2014, 05:37 PM
SD73's Avatar
Tell me more about the welting with the pull off tape. Who sells that one? Any part numbers?
  #100
Old 01-18-2014, 05:42 PM
Default Rubber Bushings
bad P.Y. for lying!!!!I will pull my bushing and post a pix and I will measure the inside hole...mine definitely did not have a centering hub...early in this thread are pix of the front end underneath and my install was fine...let me pull a bushing and then we will know!!!!!
