Old 01-19-2014, 11:04 PM
jdh421's Avatar
jdh421 jdh421 is offline
Default 421 Piston Recommendations
Hi all, Time to get pistons for the original WG 421 for my 1965 2+2. Planned build will be .060 overbore (necessary) aftermarket forged rods, moly rings, original 76 casting heads, Ram air IV cam, Rhodes lifters, Tripower and H.O. exhaust manifolds. I do not have a ton of $$$ for this motor so no custom units for me. Should I go cast? forged? any recommendations for a manufacturer? The last one I built had a set from Warrior racing and I do not think they are in business any longer. any suggestions would be helpful. Thanks in advance!
1966 Catalina Convert
1968 Firebird 350
1969 GTO
1967 Bonneville 4 Dr Brougham 428
1967 Bonneville 2 dr
1959 Buick LeSabre 2dr
Old 01-19-2014, 11:12 PM
http://forums.maxperformanceinc.com/...d.php?t=745532
The Following 2 Users Say Thank You to b-man For This Useful Post:
Old 01-26-2014, 12:22 PM
8LUG 8LUG is offline
My two cents, going .060 over will create more heat.
Old 01-26-2014, 03:23 PM
If you're gonna beat on it Forged pistons are a must. A good balance Job is a must also
former." --Albert Einstein
- Winston Churchill
Old 01-26-2014, 06:04 PM
66bonne's Avatar
66bonne 66bonne is offline
I'm running BRC forged in the Catalina.
Jim
Old 01-26-2014, 08:04 PM
jdh421's Avatar
8 lug, I dont have a choice on .060. I know the heat build up will be a problem but I really want to use the original block. I will not be drag racing but will be thumping around on the street. being a manual trans car, it will see lots of RPM swings.
1968 Firebird 350
1969 GTO
Old 01-26-2014, 10:45 PM
mjm421's Avatar
mjm421 mjm421 is offline
.060 is not a problem in these early motors. Won't run noticably warmer.
Mike McCarty You can drop the line, but you'll never kill the spirit!
Pump gas 535 w/Marcella cv/1's. 11.0 compression, 4000 stall, 3.73 gears, 275 radial, to the axle exhaust, 3470# w/driver. 9.49 @ 140..........so far
Old 01-27-2014, 11:30 AM
Ziggy Ziggy is offline
As with Jim above, I am also running BRC Forged pistons in my 63 - 421 bored 30 over (~428).
BRC has a very good tech dept should you have any questions.
(386)364-5623
However, I did not purchase them directly through BRC,. Mine were purchased through
Ken at Ken's Machine Shop
512 S. Main Street
Brooksville, FL 34601
Phone (352) 796-8800
Email: pontiacdude@outlook.com
http://www.angelfire.com/fl4/pontiacdude428/
Ken helped in determining the correct dish-out which enabled me to run on pump gas ~ 9.8 compression ratio.
Old 01-27-2014, 12:51 PM
Ragtop Man's Avatar
Ragtop Man Ragtop Man is offline
Did the block already go +030?
If you could sneak by at 4.125 that gives you a lot of ring choices.
The +.005 Race Tec is a sweet piece.
Old 01-27-2014, 02:31 PM
Ragtop Man's Avatar
Assume all thread watchers have seen the build in HPP -- very cool, and much along these lines. Really put a hurt on the dyno!!!
