63 V8 rubber motor mounts
Still available or is original the only option? I am missing one.
I took a mount down to a enginering surply shop and they had a ruber mount that was very close and has worked very well.Have a look you may be surprised.
63 V8 Rubber Motor Mounts
I purchased a black rubber roller that is used on boat trailers. They are available in different sizes but measure the thickness of your original rubber mount and cut a section of the roller to fit. Worked for me on my '62 V8 conversion.
Will hit the stores with it today. If anyone has a used spare, let me know.
Just got a pair from Ames.
Pontiac Addict 66 GP 421-TriP/auto - purchased for $75 in 1978 65 2+2 421-TriP/auto 61 Tempest 2 dr Coupe - survivor 64 GP - work in progress 71 GTO Convertible - in 1000 parts and 69 Firebird |
Ames Catalog
Yep - top of page 26 of Ames catalog for $22 each!!
Gotta get a catalog if you own an early Tempest! |
Motor mounts
Check these poly ones out from Hinson Motorsports. I am going to get a set. http://www.hinsonsupercars.com/image...edium/1285.jpg
The round ones are for the four cyl, I believe. Ames does have the ones for tempest 8 which are not the same as full size
Google the 4-5 digit # that is on the rubber of your old one. I don't think that I paid more than $10 on line. I think that I still have one if you can't find the #? John
Found them online at Summit and Oreillies for $8 each, Anchor brand. Will see if my local Oreillies can get them in today, no shipping. Pioneer makes them also. Must be a common mount because this was way easier than I thought. Thanks all.
motor mounts
The parts manual shows the 1963 Tempest (T8) V8 motor mounts, both sides, as part number #9772120. It gives a different number for all the rest of the 1963 (P/8) V8 cars: #9780423. I don't know what the differences are, does anyone know? It does show the 4 cylinder engine as having different left and right side mounts.
I would like to know the difference also.
Mike McCarty You can drop the line, but you'll never kill the spirit! Pump gas 535 w/Marcella cv/1's. 11.0 compression, 4000 stall, 3.73 gears, 275 radial, to the axle exhaust, 3470# w/driver. 9.49 @ 140..........so far |
Internet research
After a quick internet search, it looks like there are motor mounts available for the 326 ci engine in a 1963 Tempest. RockAuto lists Them as "DEA 2204" for the left side and DEA 2205 for the right side. Both are priced at $7.73 each. Those part numbers are also listed for several other Pontiac applications from GTO's to 421 Catalinas. The original mounts must have been spec'ed close enough that only one reproduction set can fit all application today. ????
GTO's are totally different. The bolt runs horizontal through the mount. B bodies and F bodies are similar. Mike
Wrong
Mike is correct, the later engine models are attached to the frame pad with a long, horizontal bolt. The 63 models use a shorter vertical bolt. The DEA 2204 &2205 use the vertical bolt.
Here is the manufacturers page with pics, showing left and right are different:
http://www.anchor-online.com http://www.showmetheparts.com/anchor/ Looks like the drivers side has a safety tab? |
The replacement motor mounts are now L/R because they are inter-locking. John
Lock is on the driver side only?
Yep. Drivers side is trying to lift. Passenger side is getting pushed down. Mike
