Old 01-30-2014, 03:53 PM
Originally Posted by John Langer View Post
Was the 920 with eheads and 860 w cv heads or both w cv heads. Not starting **** just asking for clarification.
Thanks John for the question. I was not sure about that deal either. Only E-Heads, E-Heads vs CV heads, etc.
PS Gaby's hands were %5%hit for a good while now so he would have to respond on if he actually did the porting.
  #202
Old 01-30-2014, 06:30 PM
mjm421's Avatar
mjm421 mjm421 is offline
I believe both were with E heads.
Mike McCarty You can drop the line, but you'll never kill the spirit!
Pump gas 535 w/Marcella cv/1's. 11.0 compression, 4000 stall, 3.73 gears, 275 radial, to the axle exhaust, 3470# w/driver. 9.49 @ 140..........so far
  #203
Old 01-30-2014, 07:44 PM
John Langer's Avatar
John Langer John Langer is offline
I thought he scrapped the e heads and went with the cv heads hence my question???? Was the cam right for the new top end since it was the old short block?
  #204
Old 01-30-2014, 08:34 PM
mjm421's Avatar
"This motor made 920 hp four years ago." I could be wrong John, but I don't think he was running the cv's 4 years ago.
  #205
Old 01-30-2014, 09:11 PM
2manyponchos's Avatar
2manyponchos 2manyponchos is offline
Fairly certain the cv's have nothing to do with the 2 dyno numbers mentioned. Think it was comparable tests with eheads before and after.
P.O.S.I - It's not just a club...it's an addiction!
  #206
Old 01-30-2014, 11:53 PM
lemans411's Avatar
lemans411 lemans411 is offline
The 920hp was with his e head wide ports. the 860 hp was with same shortblock with gaby e head upgrade (same e heads just worked over by gaby ), gaby intake and carbs is what i understand to be the truth. if you read his post again he explains it fairly well i thought. maybe he will post and clarify as its best to come from him.
-Rob
67 LE MANS in pieces...
68 gto
84 grand prix twin turbo 496 pontiac 25.3 cage
The Following User Says Thank You to lemans411 For This Useful Post:
  #207
Old 01-31-2014, 12:39 AM
Torment's Avatar
Torment Torment is offline
Dick had E's on his car in 2011, and his post says Gaby did Eheads for him - so Ehead, Ehead.
The secret to happiness is not getting what you want but rather, wanting what you have.
The Following 2 Users Say Thank You to Torment For This Useful Post:
  #208
Old 01-31-2014, 03:19 AM
john marcella john marcella is offline
I agree fully.
This used to be a great section, but now it's the 'Clubhouse' worse than the 'Lobby' where most of these posts belong.
Where's the 'technical' or 'race' stuff is, I don't know.
And no EHTTFMF is not race or technical.
Also thought the name calling, back stabbing, etc was not allowed.
But I guess if your an ECM fan it is OK.
I really thought when you came on this board it would really help the racers out.
Along with some of the other people that have came along also like Chad S. and others it was starting to get good.
But if we wanted a 'YB' type board we could always go there.
That is the main reason I don't go there is too much blowing and posturing and no real substance.
Guess it's time to find something else also.
You are the worst MFr here on that. You must have directly insulted my intelligence 10 frickin times in the rambling thread.
John Marcella
Marcella Manifolds Inc.
[email protected]
ph. 248-259-6696
  #209
Old 01-31-2014, 08:53 AM
mike leech's Avatar
mike leech mike leech is offline
Without asking one question as to your experience with them!
EHTTFMF!
Being dead, it is not hard on you. You don't even know you're dead. It is hard on everyone else that is not dead.
BEING STUPID WORKS THE SAME WAY! The rest of us suffer.
  #210
Old 01-31-2014, 12:31 PM
v869tr6's Avatar
v869tr6 v869tr6 is offline
I predict my car will get used at a few different events on the bucket list.
Wondering if I have the balls to try a 1/2 or 1 mile race.
  #211
Old 01-31-2014, 02:22 PM
mike leech's Avatar
Do it!
EHTTFMF!
  #212
Old 01-31-2014, 02:31 PM
bad69bird's Avatar
bad69bird bad69bird is offline
You don't have any balls if you don't try it! LOL
East Coast Mafia TTFMF
Making CVWHAT's great again. I guess it took a deplorable ECM member to do it!
Originally Posted by Ray Cox View Post
Holly cow we must be some dume corn huskers here in indiana or somthing!!!
Fastest Blow-thru Pontiac powered car in the Country [email protected] (3465lbs)
Fastest Pontiac CV-1 car on the planet with only 6 passes on the combo: [email protected]/ [email protected] (3365lbs)
  #213
Old 01-31-2014, 03:03 PM
v869tr6's Avatar
Open top, butt 7" off the ground, plenty of torque and enough gear with the converter locked for 203 mph at 5500 rpm, what could possible go wrong???
The Following User Says Thank You to v869tr6 For This Useful Post:
  #214
Old 01-31-2014, 03:10 PM
Rob B's Avatar
Rob B Rob B is offline
Thats easy, to much ass puckering at the 3/4 mile point leading into a full scale Chitting of your pants at the slightest bump in the road!!!
74 GTO Bracket/Street car and another 74 for the wifey to race with!
70 GTO 400, 4 spd, #'s matching and a little to nice for me to own.
Friendship is like peeing your pants..everyone can see it but only you can feel the warmth!
  #215
Old 01-31-2014, 05:51 PM
cgeise's Avatar
cgeise cgeise is offline
So let me get this straight -- you have an Engine that made 920 hp -- you get you heads modified to replicate the same program that had made at or near 1000 hp and you can -- as your own engine builder -- only get 860 hp out of the deal -- Do you see where the problem lies with pointing fingers at " the other guy " ???
I know there are two sides two every story - and communication errors happen -- its how there addressed that is the defining point.
  #216
Old 01-31-2014, 06:00 PM
mjm421's Avatar
What exactly are you trying to say Curt?
  #217
Old 01-31-2014, 07:48 PM
mike leech's Avatar
Rut ro relroy
EHTTFMF!
  #218
Old 01-31-2014, 07:54 PM
Time for some INTROspection: http://m.youtube.com/watch?feature=p...&v=tnt0RknIklI
  #219
Old 01-31-2014, 08:08 PM
mike leech's Avatar
Was that an intentional pun?
EHTTFMF!
  #220
Old 01-31-2014, 09:06 PM
cgeise's Avatar
What Im saying is -- just like ANY engine -- the combo has to be right to make it produce, How many cams do you think Comp cams sells and in one engine it makes a 100 hp more than another -- same cam - different combination. We see it stated all the time here and most live by that creedo - what may be a good port, good cam , good head ect.ect for one guy may not work for another guy if his combination is different or wrong to maximize it. Point is if the heads worked on a number of other cars and applications but they didnt on yours just maybe its not the heads, Im not trying to take a shot at you but im trying to explain the logic behind my statement.
