| The Body Shop TECH General questions that don't fit in any other forum |
The car will be completely blasted to bare metal this spring then primed and left in primer for a year or more. Heard horror stories about certain primers coming off in sheets. Would like to go with red oxide color if possible.
PPG dp epoxy or SPI epoxy is what I would go with.
1969 GTO 4spd. Antique Gold/black, gold int. 1969 GTO RAIII 4spd. Verdoro Green/black, black int. 1969 GTO 4spd. Crystal Turquoise, black int. 1970 GTO 4spd VOE Pepper Green, green int. 1967 LeMans 428 Auto. Blue, black int. |
PPG DP 50
Another vote for PPG DP. However you will be outside the recoat and have to put another coat in the future. I would probably use DP and then follow up with K-36 or 38 (high build).
My money talks to me-it usually says goodbye! |
DPLF 74 is close to a red oxide color.
X2 on that. Doing it that way enabled me to work on other things without about having to sand and re-spray the DP and worry about adhesion.
EPOXY PRIMER... WOULD USE BLACK JUST CAUSE WHEN YOU DO BODY WORK ON IT YOU WILL SEE ALL THE DENTS ...
Are people using the DPLV 2.1 VOC epoxy primers? Is VOC standard working out?
68 Firebird 400 HO vert under construction 65 Catalina Wagon TriPower 389 under construction ![]() ![]()
Unless it is a requirement in your area, I wouldn't worry about a low VOC product. All you are doing is spending extra money to buy a primer thinned with exempt solvents which are typically more expensive. low VOC doesn't necessarily mean higher solids, just different solvents.
SPI
Paul FAST Automotive -The Pontiac restoration shop, not the fuel injection guys! I had the name first. My site... needs updated- www.fastrestorations.com 68 GTO's (RA II, RA I, HO, convert, Pro Street, Racecar, etc.), 2 69 GTO Judges, 70 GTO racecar -10.77 @ 124mph, 68 Tempest survivor, 3 03 Aztecs! |
Thanks folks!
Bringing this back up. Did you get your car blasted and primed?
Sean 1967 GTO Koerner built 468 with Edelbrock RP’s 315cfm by Butler, Luanti Voodoo HR 20510713, 4l80e, Holley Terminator EFI |
Id use SPI. It has a nice long working window and is easily sanded if you need too. Nice price too. Comes in black, red, and white.
And grey.
I didnt know they had grey!
Also as a side note, if you reduce it (black), it drys to a nice sheen like suspention parts should be. |
I'm confused now. I talked to a local body shop owner and he said not to use Epoxy primer but if I do, use an acid based etching primer first. He also said the epoxy primer is porous and will rust underneath. Is he correct or way off base?
Sounds like SPI is the best way to go at this point. I will give them a call. Plan to have it primed next week. Was going to do it this weekend but slight chance of rain. Figures. |
SPI.
Jack Ferris RestoRacing LLC www.restoracing.com Sandy, UT --------------------------------------------------- |
Pretty much the exact opposite of reality. Since you are blasting it will leave a nice texture for epoxy to stick to. Epoxy is not porous, high build is. Etch primer is old tech.
-Jeremy 1968 GTO 4-spd convertible, console, factory gauges, hidden headlights, 3.90:1 posi, AM/FM radio. 1962 Catalina convertible, Starlight black w maroon interior & white top. |
