Old 02-25-2014, 07:34 PM
428GTO70's Avatar
428GTO70 428GTO70 is offline
Send a message via MSN to 428GTO70
Awesome! you just did exactly what the engineers should have over 40 years ago. And now I'm going to copy you! Thanks a lot for the great pics
1970 GTO 458 CID .040 over 4 Bolt 428 Block, Forged Eagle 455 Crank, 295 CFM SD KRE D-Ports, SD Old Faithful HR Cam + Comp HR Lifters, PPR Maxx-lite rods, Racetec pistons, PRW 1.65 SS Rockers, 900CFM Holley HP TBI, Performer RPM, Hooker Super Comps, 3" X-Pipe into 2.5" mufflers/tailpipes, 2.75 1st TH400, Continental 13" Converter, 8.5" 3.08 Posi.
Everything installed, fired up and tuning has begun!
Old 03-12-2014, 06:35 PM
428GTO70's Avatar
Just a note that I got mine done also, pretty much just like you did it. I just bought a 12" hinge though and it was pretty much perfect. It took a little bit of figuring out where to rivet it so it would work correctly but it fits great and has never worked so smooth! I even took it all apart, sand blasted and repainted the inner shell and got a new tire pressure sticker for it and even gave the front a quick coat of satin black Krylon Fusion to spruce it up a bit.
Thanks again for the helpful nudge to get me to do mine
Old 03-12-2014, 10:53 PM
GTO JOHN's Avatar
GTO JOHN GTO JOHN is offline
Mike, Thanks so much for taking the time to document the repairs you made. This will undoubtedly help scores of other '69 owners including myself. Nice photos and the repair looks great. John
John
Email [email protected]
My Website www.minnesota-muscle.com
Old 03-13-2014, 10:42 AM
madtexan's Avatar
madtexan madtexan is offline
I'm glad it worked for you. The 12" hinge is much cheaper but I bought the 48" one just because I thought I'd screw them up and have to make multiple prototypes. I'd say the most critical parts are to install the hinge with the pivoting part as close to the location of the plastic hinge and to be careful to drill the holes in the door at the location where the metal is separated from the plastic front.
Old 12-27-2015, 06:18 PM
snakepod's Avatar
snakepod snakepod is offline
Thumbs up
Very informative thread!. I just finished fixing the hinge on my 69 GTO glove box door. I did basically the same thing that you did. I don't have a drill press or a rivet gun. I hand drilled and tapped holes for 6/32 screws. These worked out very well and were easy enough to do with the tools I had on hand. I put a light coat of Rustoleum flat black on the hinge. I used the 12 inch hinge as well. Its hardly noticeable. Very sturdy repair. The key is to get the hinge as close to the factory hinge seam as possible. Very handy advice as the ONLY glove box door I could find was for $250. Thanks again, Ken
Old 03-23-2017, 05:21 PM
madtexan's Avatar
Glad it worked for you. I noticed this thread doesn't show up in searches anymore so this might bring it back into relevance so it can help other people.
Old 03-26-2017, 11:51 AM
Better than new Mike. Goodness.
I wonder if the 68 Glove box hinge transfers to the 69-70 door.
...yea i've favored the 68 LeMans & GTOs because these qualities abound
Old 04-05-2017, 03:29 PM
JG'SGTO JG'SGTO is offline
Nice Job. Came out great.
Old 04-19-2017, 04:09 PM
backinhs backinhs is offline
OP did a great job. For anyone who comes to this thread in the future, I just got the new OPGI catalog and they now have sourced a new supplier for the complete glove box door which was previously not available. Here it is for '70-'72. https://www.opgi.com/lemans/G241956/
