I seen here were Scott asked if anyone has made 2.3 HP per cube. My question is. What does it take to make 2.3 or more HP per cube? I want to clarify first I have not made 2.3 HP per cu. in. So I am not asking this to offend anyone.I just want to see what others have done or might think it takes. I think to make 2.0 HP per cube takes way more than the average guy is willing to spend or to make the effort to achieve. I have been fortunate enough to have seen some of what it takes to make 2.8-2.9 HP per cube in pro stock, and let me tell you. I do not have the funds or time to dedicate to such an endeavor. It gets way more involved at this level than I think most realize. Let's see what everyone's thoughts are. Let's use a 500 cubic inch limit with our current deck height of 10.240" and the cylinder heads that we have available right now. There are no limitations except the two I just mentioned. If the engine is capable of making a minimum of 2.3 HP per cube. Then this theoretical engine will make 1150+ HP. Let's not turn this into a cylinder head pissing match. I don't care what heads are used to achieve this goal. I just want to get people together to brain storm. We have some really smart guy's here and I think this will be of interest to everyone from the amateur racer all the way up to the professional level engine builder.
Don Johnston DCI MOTORSPORTS INC. 330-850-5050 shop 330-628-3354 cell Designer of the DCI Tiger Heads and the NEW DCI Ram Air 5 Heads !!!!! |
Don, I'm just curious why you are using a 500 cu.in baseline? I am assuming that it's because with our deck height it is easily achievable without getting into overboard stroke/bore dims.(IOW, a happy medium) or were you simply picking an easy to figure number that is equates to a class limit?
The only reason I am asking is it "seems" easier to get closer to or exceed your 2.3 number with a smaller cu.in limit as you are not asking for largest gross hp numbers, but a specific hp per cube number. The only reason I say this is because of the number of small cube motors (other makes) that already exceed this number. Not trying to confuse the issue or taint your thread, just asking. Thanks Stan |
prostock as a baseline for hp per cube I assume
EHTTFMF! Being dead, it is not hard on you. You don't even know you're dead. It is hard on everyone else that is not dead. BEING STUPID WORKS THE SAME WAY! The rest of us suffer. |
That is what I was guessing as well Mike, I guess what I was really getting at is would it be "easier" (relative term) to get to 2.3 with a 400 ci motor at 920, vs a 500 at 1150?
Actually I just picked a number that is easily attainable with a Pontiac engine. Cubic inch really does not matter here. Just trying get people thinking about what it takes to get to this level of performance. I know that it is a little easier to make more HP per cube with smaller engines and I am not adverse to doing that. I think that the basic's are going to be the same for a large or small engine. So the same theory and parts can be used used for most scenario's.
At 500 cid I think we have the induction capabilities now with several heads. But its still going to take king kong lobe area above .200 to get it done IMO. A build like this is not just heads cam and intake, ITS EVERY THING!
^^^^^true^^^^^
I agree, cam lobes for this level of performance will need to be well thought out and require a stout valve train. Pushrod length will be a challenge for sure.
John what are your thoughts on lifter diameter and a taller lifter? Have you used or know of anyone using 2.0-1 rocker ratio's? Don Johnston DCI MOTORSPORTS INC. 330-850-5050 shop 330-628-3354 cell Designer of the DCI Tiger Heads and the NEW DCI Ram Air 5 Heads !!!!! |
thats an all in deal. 2-1 rockers. nasty cam lobes, dry sumps, the whole shooting match to get there.
Yes , many at 2.0-1 , I am at 1.9. Rocker ratio is your friend and then it becomes your enemy. The valve acceleration is the thing you're after but that's the same thing that can send the system out of control. Spintron is the answer for the seriously trying. I don't like a tall lifter, it puts more ang in the push rod. .937 key way is the only way to go IMO. |
Not to mention rotating weight. Things that need attention as well will be piston pin height, ring thickness, ring tension, how far up the piston the ring package will need to be. Crankshaft counter weights, bearing diameters, cam drives. The list is pretty lengthy at this level. That's why I thought it would make a good topic. As things are brought up, I would like to see each one get broken down and analyzed.
All that is the easy chit^^^ LOL
Good points!! Pushrods no doubt will need to be 9/16 tapered if there is room.
Were will the intake port csa's end up at the valve, port opening, port throat? How much taper will be needed in the intake for what given rpm? What will the best bore and stroke combination be. How does rod to stroke ratio effect the torque curve?
A friend that run PS bike and after spintron testing has told me that the port needs to cater to the push rod, Make room! But then again he runs a 2.700+ valve at 9800 so because of weight and valve acceleration ,he has big spring press, you may not need that kind of press. There are many variables. Just for reference I am at 284@50 206@200 .543 lobe 1.9 rocker and total weight of valve, retainers , locks and lash cap is 119g. I am stable through 9200 no prob. IMO you will need to get more like 210+ at .200 with a 1.9-1 and better yet 2.0-1. That im sure would be enough area to insure you could make the 2.3 with a Pontiac with that kind of area. JMO I could wrong. |
If it were me I would go 4.420 bore. I like a shorter deck and shorter rod for what it allows me to do with certain parts of valve timing. JMO As far as the cyl head and manifold= to business related to discuss
but not with a Pontiac V8 ![]() Car: 2009 Cobalt SS Engine: Ecotoec 'LNF' 2.0L (121.9ci) w/GMS1* HP & TQ: 290hp & 320 ft/lbs (iirc those are GM Tuner Source published numbers) 121.9 x 2.3 = 280.37 * = I'm actually making a fair ammount more hp than this, but I'm using GM's published numbers here only because I don't have any dyno numbers to prove any assertion which I might make. The latest Shelby GT-500 Super snake obliterates this ratio as well.... but I digress, I'm verring futher from the topic than anyone probably cares for
I thought the Cobalt SS is supercharged.
I look back at my original post and I guess I did not specify NA or boosted. Sorry about that guy's. I'll try and fix it before I'm done here. Don Johnston DCI MOTORSPORTS INC. 330-850-5050 shop 330-628-3354 cell Designer of the DCI Tiger Heads and the NEW DCI Ram Air 5 Heads !!!!! |
Well I guess I cannot go back to my original post and edit now. So I will just add a note here saying I am looking for normally aspirated HP.
Thanks, Don Johnston DCI MOTORSPORTS INC. 330-850-5050 shop 330-628-3354 cell Designer of the DCI Tiger Heads and the NEW DCI Ram Air 5 Heads !!!!! |
![]() 2005-2007 Cobalt SS*: 2.0L Ecotec 'LSJ'; 205hp 2008.5-2010 Cobalt SS: 2.0L Ecotec 'LNF'; 260hp * = "Cobalt SS Supercharged"; there were two Cobalt SS models for 2006 & 2007, the other was a 2.4L n/a Ecotec 'LE5' 171hp motor Quote:
