Old 11-20-2013, 07:25 PM
Hammertime Mike's Avatar
Hammertime Mike Hammertime Mike is offline
Send a message via ICQ to Hammertime Mike
Originally Posted by Transporter View Post
looks like it's really coming together for ya Mike, although I usually don't care that much for cowl induction style hoods (read chevy) might flow pretty nice with the lines on that car and the slope back rear window, JMHO.
Or, possibly one of the bigger/taller T/A shaker scoops?
Stan
Stan, when it comes to cowl hoods on Pontiacs I do agree with you. I've already had that discussion. The cowl hood would compliment the body lines but all I see is a chevy hood. I hadn't thought about a shaker scoop. Looks real nice on Wanger's Ponte Carlo. My next focus will be setting up a tranny crossmember and brackets. Ill be dropping off the tranny rebuild kit tomorrow. I'm going to use the tired tranny that was in my 65.
The Following User Says Thank You to Hammertime Mike For This Useful Post:
  #262
Old 11-26-2013, 01:23 PM
RA462's Avatar
RA462 RA462 is offline
I agree I hate cowl hoods on a Pontiac BUT these cars. I don't think any hood scoop will as good. You should have bought that 2-1/2" cowl the guy had for sale for $50 at Norwalk. I thought about it but got a bit distracted. I have a 4-1/2" cowl hood on mine.
Todd Sedlmeier
Who ever thought pinewood derby cars would lead to this!
October 2004 HPP Shootout participate
http://www.highperformancepontiac.co...out/index.html
86 Grand Prix
535 High Port 8.93 @ 153
65 GTO
433 High Port 12.04 @ 113
  #263
Old 11-26-2013, 02:03 PM
Isn't that the way it works. I thought I was all set with the GTO scooped hood. I checked out VFN's site. They have a Grand Prix hinged fiberglass hood. And offer a number of choices for hood scoops at an added cost.
Old 12-04-2013, 02:18 PM
Cleaned up the hood hinges. Being that I'm going to put a glass hood on her now. I took the springs off the hinges. They came off with pry bar without any problems. Probably a little more tricky putting the springs back on.
Name:	aero coupe hood hinges 001.jpg
ID:	345415   Click image for larger version
Name:	aero coupe hood hinges 002.jpg
ID:	345416   Click image for larger version
Name:	aero coupe hood hinges 003.jpg
ID:	345417   Click image for larger version
Name:	aero coupe hood hinges 004.jpg
Old 12-09-2013, 09:41 AM
RA462's Avatar
I bought my hood from a small company NE of Cleveland. It was cheaper than VFN but I know it's heavier since a friend has the VFN one. I know I have the name in my toolbox if you want it.
Todd Sedlmeier
86 Grand Prix
65 GTO
  #266
Old 12-09-2013, 11:38 AM
RA462 I'd appreciate that info. I'm not quite ready to buy yet, but that info would definately be important. Thanks Mike
Old 01-03-2014, 01:29 PM
RA462's Avatar
Finally able to log in here. I found the form with the company I picked up my hood at. The place is called WS Racing Fiberglass but I did a search and couldn't find anything. Maybe they are no longer in business?
Todd Sedlmeier
86 Grand Prix
65 GTO
  #268
Old 01-06-2014, 01:05 PM
RA462 thanks ! I'll see if I can come up with some more info. If I do I'll post it.
Old 01-07-2014, 05:38 PM
I spent some time today looking up WS Racing Fiberglass. The website that I tried - http:/www.wsracingfiberglass.com/ is not up and the number 440-998-6341 has been disconnected. From what I gathered the owner of the operation had passed and his son took over. Change of owner and bad economy may have deep sixed the company.
Old 01-24-2014, 02:44 PM
mrrat1 mrrat1 is offline
a couple months ago on E-bay there was a huge scoop from an old Ford truck. It was in the shape of the SD scoop but maybe a 1/3 bigger.
OR
What about a custom clear oversize SD scoop out of plexiglass? Mounted with the opening in the back to counter balance the look of the rear glass. Maybe use plexi as the base of the scoop also. I think would look killer with the black paint.
Get to see a little of whats under the hood ala Corvette.
  #271
Old 01-25-2014, 02:25 PM
OR
I agree that the scoop's shape needs to counter balance the look of the rear glass. I've picked up a scoop that I want to mold to a fiberglass hood. Haven't bought the hood yet. I'm waiting on spring to tackle that project.[warmer weather]
Old 02-26-2014, 01:12 PM
I just picked up my turbo 400 tranny yesterday. Now I'll be able to fit a crossmember and frame mounts to the aero coupe frame.
Name:	aero coupe tranny 001.jpg
Old 03-21-2014, 02:08 PM
Moving the aero coupe into the lift bay so I can trial fit the tranny. Gave her a quick bath before putting her back in the garage.
Name:	64 conv 010.jpg
ID:	357508   Click image for larger version
Name:	64 conv 013.jpg
ID:	357510   Click image for larger version
Name:	64 conv 015.jpg
Old 03-21-2014, 03:32 PM
Here's the 400 tranny attached to the motor. Looks like I will have enough room so I shouldn't have to mess with the floor pan . That lip where the floor pan and firewall meet could be trimmed a little for easier access to the bellhousing bolts. Next step will be to see what crossmember works best. I have the original g-body,a 70's firebird, and an a-body to choose from.
Name:	2+2 crossmember 004.jpg
ID:	357515   Click image for larger version
Name:	2+2 crossmember 008.jpg
ID:	357516   Click image for larger version
Name:	2+2 crossmember 006.jpg
Old 03-22-2014, 09:06 AM
Looks like I'm going with the original g-body crossmember. As it turns out the crossmember perch for the tranny mount fits pretty good. With the crossmember sitting on the factory frame mounts. I'll need to carve out the driver side of the crossmember to clear for the dual exhaust. The other two crossmembers were not even close. The left and right side floors in the g-body cars are not the same. The catyltic converter sits under the front passenger seat. And that side does not drop down as far as the driver side. There's about an 1 1/2 to 2 inches difference. Time to scrape the grease off the crossmember and start cutting and welding.
Name:	2+2 crossmember 009.jpg
ID:	357678   Click image for larger version
Name:	2+2 crossmember 010.jpg
Old 03-23-2014, 08:19 AM
I was able to spend some time on the crossmember. I cut out the section for the exhaust. Then welded in 1/8th inch steel. I also welded one more piece to the top section for a little more strength. After welding ,I went to test fit the crossmember. And found that I had to reshape the left side of the crossmember as it had distorted from the previous welding. I also added some weld to the tranny perch. I welded up the single bolt hole for the tranny mount, then drilled it for the two bolt mount. Now the crossmember is ready to be painted.
Name:	2+2 crossmember 001.jpg
ID:	357761   Click image for larger version
Name:	2+2 crossmember 002.jpg
Old 03-24-2014, 07:12 PM
Transporter Transporter is offline
Looking good Mike, keep it up, you'll be done before you know it, came home off the road today, 30 degrees and snowing, this is getting a bit ridiculous.
  #278
Old 03-24-2014, 07:18 PM
Stan, good weather is knocking on the door. Give it another week. Getting ready to drop the tranny back out, so I can put the torque converter in. Still waiting on my other tranny for the 65. Been a month so far. I need to get out on the track !
Old 03-25-2014, 12:07 PM
I plan on putting a driveshaft safety loop on the car. I'm seeing a place that the g-body had a small support brace attached. I'd like to use this as a mounting place for the safety loop. I attached a couple photos.
ID:	358035   Click image for larger version
Old 03-26-2014, 09:19 AM
RA462's Avatar
I make my own but it looks like this one on ebay
http://www.ebay.com/itm/1982-1987-G-...155bcd&vxp=mtr
I also picked up one of these chrome moly cross-members last year.
http://www.maliburacing.com/iceman/
You don't have an extra 2+2 front end laying around do you?
Todd Sedlmeier
86 Grand Prix
65 GTO
