Old 04-11-2014, 08:17 PM
RAIV-Z's Avatar
RAIV-Z RAIV-Z is offline
Ed , had meant to ask you before -
while the engine was apart did you do any more work on the interior of the intake manifold ?
Any other progress worth mentioning on the car lately ?
Hey Baron,
After spending $600 with McCarty for intake port work alone you’d expect it would be good to go for the intended application. For your guys running at least 25lb of boost with a basic single plane what mods have you performed on the plenum?
Here is what it currently looks like.
As for the chassis, the drivetrain is in its final position with engine and trans mounts done, lower firewall has been cut back to make room for the exhaust and the front bars are done. Turbo and intercooler piping next as well as seeing if the all steel frontend sheet metal can be removable. With the poor header design, it will be a B!%$h to work on.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #922
Old 04-11-2014, 08:30 PM
JMO but $600 don't buy you much in porting work in todays market.
(check Wilson Manifolds pricing some time or call Gaby).
  #923
Old 04-11-2014, 08:39 PM
RAIV-Z's Avatar
Does the work done fit the intended application? If it does, great!
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #924
Old 04-11-2014, 08:46 PM
Basically looks like he just cleaned up the wall surface finish and made sure that everything had a nice radiused entry.
With a large flow EFI type manifold and Boost you don't really need much more.
TV
  #925
Old 04-11-2014, 09:30 PM
yeh i remember it was just an intermediate level gasket match with some quick hasty blending. Maybe $100 or so worth of labor. For only $600 - groovy man.
Not that its crippling anything -
was just wondering if you improved on it any.
You still have those original guide plates and rocker arms ?
  #926
Old 04-11-2014, 10:00 PM
RAIV-Z's Avatar
I still have the guide plates, there in a tool box somewhere, crane energizers rockers are gone. Replaced almost the entire valve train when the engine was redone, running T&D now. They make a really nice piece.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #927
Old 04-12-2014, 10:09 AM
dci dci is offline
Ed, We going to see that thing this year at the Nationals? I hope so!!! I know you have working hard at it and I'm sure you will be really glad to have it completed. T&D does nice work and the fit is excellent. Are those steel rockers or aluminum?
Don Johnston
DCI MOTORSPORTS INC.
330-850-5050 shop
330-628-3354 cell
Designer of the DCI Tiger Heads and the NEW DCI Ram Air 5 Heads !!!!!
  #928
Old 04-12-2014, 10:35 AM
RAIV-Z's Avatar
Don Johnston
330-850-5050 shop
330-628-3354 cell
Hi Don,
I hope so too, it's still to early to tell though. The T&D rockers are steel, they did a really nice job lining things up and turn around time was pretty quick.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #929
Old 04-12-2014, 10:47 AM
cgeise's Avatar
cgeise cgeise is offline
Rockers do look great - hmmm - BTW - I was wondering why the list of vendors in your signature line - given the grief they have caused you ????
  #930
Old 04-12-2014, 11:55 AM
69FIREBIRD76MM's Avatar
Default SUPER 400 hood
That thing is going to be mean looking in black. I hope there is room for more tire under there LOL. Even then it is going to be a hand full on the street.
If your interested Ed. I just bought a super 400 hood from a member here, and we are going to make some changes to it. Once we get the hood the way we think it should look and get a little more room under it. We are going to start making and selling them. The hood right now looks pretty awesome, but there is still not enough room to fit a Victor with a 2" spacer. So we are going to raise it up some more and smooth the transition around the scoops to make it look more like the factory hood. I'll post some pic's after we get it modified in another thread once we get it done.
Don Johnston
330-850-5050 shop
330-628-3354 cell
I will be interested in your Super 400 Hood, any idea how much you going to sell them yet?
  #931
Old 04-12-2014, 11:59 AM
Default 69 bird turbo
[QUOTE=RAIV-Z;5113902]The 69 Camaro is something I've had for quite some time, it had a Pontiac engine in it for all but about 1 month since I've owned it
The 69 Firebird previously had a BBC, I picked it up as a roller.
[/Quote
Thats a very nice firebird, I personally love the blue but black should be killer, can you tell me what control arms and spindle the car has?
  #932
Old 04-12-2014, 07:05 PM
Ed i remembered you replaced about everything on the heads except the valves.
Was curious if you still had those funny farm pieces hanging around as souvenirs.
The guide plates would make some real conversation pieces worn on a neck chain at ANY type of car event .
Do you ever have thoughts about buying some Bird V headers and dropping the V engine in your Z/28 to get some NA seat time and shakedown during the Bird build ?
That could be a lotta Fun in the meantime .
  #933
Old 04-12-2014, 09:17 PM
RAIV-Z's Avatar
[QUOTE=69FIREBIRD76MM;5176615]
[/Quote
Front suspension is all Smith RaceCraft, haven't picked up front shocks yet, waiting on Jeff K to give me a call
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #934
Old 04-12-2014, 09:34 PM
RAIV-Z's Avatar
After posting pictures of the "guide plates" a joint task force made up of the DOT, ICE, NTSB and Dept. of Home Land Security raided my residence in order to secure what they termed as a “shrapnel for an internal combustion device”. I was however able to keep them after an explosives ordinance team determined that they weren't a threat to national security.
With regard to N/A headers for the RA-V and putting it in the Camaro, that would depend on who's fabricating them.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #935
Old 05-31-2014, 08:26 AM
67'7F6'Bird's Avatar
Here are some updated photo's of the car.
ID:	365497   Click image for larger version
  #936
Old 10-01-2014, 05:04 PM
RAIV-Z's Avatar
69 Bird backhalf is in primer.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #937
Old 10-01-2014, 06:03 PM
mysticmissle's Avatar
Alright look out 2015!!!
  #938
Old 10-01-2014, 06:49 PM
wreckmastr's Avatar
it's going to be a cool and FAST car fore sure. I cant wait to see it out.
ET/mph talks, bullchit walks.
6.98 @ 199mph
4.53 @ 164mph
  #939
Old 10-01-2014, 07:51 PM
Hooter's Avatar
Hooter Hooter is offline
Hope to see it at Norwalk next year. Looking good.
67 Bonneville ragtop
  #940
Old 10-01-2014, 08:07 PM
lemans411's Avatar
lemans411 lemans411 is offline
so jealous! thats one of my all time favorite cars. keep up the updates
-Rob
67 LE MANS in pieces...
68 gto
84 grand prix twin turbo 496 pontiac 25.3 cage
