Old 05-07-2014, 09:11 PM
68pl's Avatar
68pl 68pl is offline
Question Header Gaskets Bison or Copper
Can some tell me which Header Gaskets seals the best.
The Copper one is from Mr. Gasket they have lip on the the port holes. I have never used the Copper one before. Which side does the Lip fit? The Engine or Headers.
The other is the new style from Bison, they are thinner than the old ones.
I used Bison gasket before and they were thick ones and never leaked for 13 years.
My Car is a 68 LeMans with a 350 engine, Headers are Hooker long 28" ceramic coated.
Please let me know if you need more info.
Old 05-10-2014, 05:51 AM
MNBob MNBob is offline
I have had the Hooker comps for over 30 years and tried many gasket brands. The Remflex gaskets that I put on last time are by far the best I have ever used:
http://catalog.remflex.com/PONTIAC_H...t_p/12-001.htm
1979 TATA Extreme TKO .64
Hedman elite; Pypes 2.5; Borla XS; MSD 6A; Edelbrock intake; open scoop; Sniper Q-jet; Powermaster 150; 4 core radiator/Mark VIII fan; RobbMc mini starter; subframe connectors; solid body mounts; fiberglass rear springs; poly sway bar and link bushings; 81 master; D52’s; Blazer disks; 225/60 & 235/60 17's TrueContact's; relays for PW, PDL, lights; keyless entry
Old 05-10-2014, 10:21 AM
racegto65's Avatar
racegto65 racegto65 is offline
I started using Reflex. So far so good.
http://catalog.remflex.com/category_s/81.htm
Old 05-21-2014, 10:55 AM
68pl's Avatar
MNBob, racegto65,
Thank you both! I am going to try to get a set of the Remflex street PN 12-001
I don't want to do this twice.
By the way I had to take off my Oil Filter adapter for lack of a better word. Do I need to put it back on before i put the headers on or will I be able to do it after the headers are on?
Old 05-21-2014, 11:22 AM
Beebe's Avatar
Beebe Beebe is offline
Yes.... REMFLEX to the rescue.
Same here, i would almost install a header gasket every year , Untill i installed the Remflex's. Now i have been sealed up for 3-4 years with no sign of failure.
Also Known As "Beebe" on other sites....... PZ , Pro-Touring , Lateral-G, TAC
Old 05-21-2014, 05:51 PM
I've used the copper on both headers & iron manifolds & I like them the best. You can take them on & off several times before you have to replace them & they seal great. The soft copper expands faster then the other metals around them & seal it everytime it gets hot.
