Old 06-30-2014, 02:06 PM
67Twistytee's Avatar
67Twistytee 67Twistytee is offline
If you've glazed the belt, it's toast and needs to be replaced. Even with a new belt, if it wasn't installed with the correct tension or the pulleys are not aligned, it will slip and squeal as you describe. Once glazed, it will ride too low in the pulley and continue to squeal until replaced. The belt needs to ride on its sides within the pulley. You also might have to sand the pulley with 200 grit or super fine steel wool to remove the old glaze.
Andy
North Carolina
1967 GTO SG over Parchment / mom original owner / sold in '78 / found 35 years later
