Old 07-20-2014, 08:10 PM
67'7F6'Bird's Avatar
Now that we got the 1050 Dominator dialed in I changed the engine oil and completed the install of the GZ Motorsports Super Pro Complete Racing Vacuum Pump and now my oil pan or Rear Main oil Leak is gone. It was a pretty simple install, with the hardest part being attaching the Push Lock hose onto the AN Fittings. I need to make some final Adjustments to the total Vacuum and then should be complete. I used the Mandrel from Tin Indian, which is a nice piece. I went with the larger pump and its under-driven so the pump will last longer per GZ Motorsports.
http://www.gzmotorsports.com/CPVK104...-pump-kit.html
http://tinindianperformance.com/Tin%...%20systems.htm
Steve
