Old 07-25-2014, 10:47 AM
3goats's Avatar
3goats 3goats is offline
Question 69 gto Driveshaft Issue
Anyone ever have a problem with the driveshaft hitting the floor when you put passengers in the back seat? Hits on crossbrace under front buckets.
New mounts on engine and trans. crossmember checked and not bent. Body mounts are good.
Any Ideas?
Old 07-25-2014, 11:00 AM
1969GTO's Avatar
1969GTO 1969GTO is offline
listining in.........
color me gone
Old 07-25-2014, 11:01 AM
1969GTO's Avatar
sure it's the driveshaft.....not the exhaust?
color me gone
Old 07-25-2014, 12:12 PM
RUFFJUDGE's Avatar
RUFFJUDGE RUFFJUDGE is offline
My 68 Lemans 350HO 4-speed car I used to have would bang the floor on the drive shaft between shifts with even just one person in the back seat. (Under hard acceleration of course)
The beatings will continue unless morale improves.
69' Judge R/A III 4-speed, Mayfair Maize/black interior.
Old 07-25-2014, 01:34 PM
3goats's Avatar
It is definitely the drive shaft you can see the rub mark on both floor and drive shaft. If you drive normal with one person no problems. Add weight and will rub when going over bumps.
This is a muncie. New u-joints,stock springs etc.
I heard that floors sagged in these cars from heavy persons sitting in front seats? And I need to jack up floor brace. The bucket seats are tilted inwards by the way?
Old 07-25-2014, 05:06 PM
Txbobcat Txbobcat is offline
How are your rear springs?
Old 07-25-2014, 06:02 PM
3goats's Avatar
Springs are stock height and are maybe 10 years old? I know if I jack rear up it would fix it but I'm thinking there's something else going on?
Old 07-25-2014, 10:05 PM
Bet Winner's Avatar
Bet Winner Bet Winner is offline
Just an idea to check out: I believe if the frame rails where the cross member bolts are bent up slightly, it will hold the transmission and driveshaft higher. You might check the frame rails and cross member to see that they are straight. The cross member can be bent alone causing the transmission/driveshaft to sit higher.
My Wife: "I thought I married a sophisticated business man, but what I actually got was a redneck fisherman with muscle cars."
Some people know all of their rights, but none of their obligations.
Old 07-26-2014, 11:17 AM
3goats's Avatar
Have a question?? The drive shaft is tapered on one end for 19" approx . What is the reason GM did this?
The taper is at the rear at this time and i'm thinking it should be at the front. That would give me approx 1/2 " clearance. Is the drive shaft in backwards?
Anyone will a unmolested car could you let me know which way the tapered end is front or back. Thanks again
Old 07-26-2014, 01:40 PM
Bet Winner's Avatar
The taper is at the rear. I don't know why it is tapered unless for weight savings.
I believe the repoed shafts do not have the taper so having an original is nice.
