Old 07-27-2014, 01:38 AM
FLYNLOW's Avatar
FLYNLOW FLYNLOW is offline
Default Right front blinker dead, as is indicator.
Well, wrapping up with reassembling the car and have noticed my right blinker indicator doesn't blink. Its not the bulb, swapped with a known good bulb. Also noticed that my front right blinker in the valence and in the fender fails to light. Rear works correctly, as does the left. Hazards do the same, indicator fails to light as does the front right signal. Leads me to believe they are all tied in together. I've been looking at some of the wiring diagrams for Camaros but not getting anywhere with those. Anyone know where these would be tied together on a bird or have any input on where to look? Oh, and the running/parking lights work all the way around.
'73 Formula 400
Cammed LS1/T56/3.73's
12.92@106.04 2.03 60 ft. <~~ Bone stock LS1 with 4L60E/3.08's
Went 12's in pure daily driver trim! A/C, leather power seats, power
steering, full stereo, sound deadening, power windows, full suspension,
true street tires, power 4 wheel discs, and 25MPG!
Old 07-27-2014, 11:38 AM
With the parking lights on does it dim when you turn the blinker on? Possible ground problem.
'68 GTO
'69 Corvette
'75 Cadillac Coupe Deville
TOM
Old 07-27-2014, 04:46 PM
LATECH's Avatar
LATECH LATECH is offline
Turn signal switch problem,or the wire for the indicators and front bulb (both from the same circuit on the switch) is not hooked up, or in the wrong place on the switch connector
