Old 10-11-2014, 03:06 AM
roadrage david roadrage david is offline
That thussend matter for guys like us road racing being in diferend parts in the world at varius diferend elivations and tracks that have diferend tems and humidity it would be a blessing no carb tunning needed!!.. and that little bitty loss of a couple of HP is negleteble considering the mega loads of carb tunning for geting it right and iven then the weather can change in a harthbeat!!.. HO28 we wil have some soon as that awesome nice dry sumb system is on its way!!!..
Old 10-11-2014, 06:56 PM
Matt Meaney's Avatar
Matt Meaney Matt Meaney is offline
would this be a good intake to use with a turbo or two?
Old 10-11-2014, 07:26 PM
Depends on if the carbon fiber is up to the task of of 30 pounds per square inch of boost over all of the square inches of the carbon fiber section. Really do not see any support structure anywhere on the thing. Easy enough to make a upper out of aluminum on a cnc machine though. Just $$$$
You look at a HO Racing "Turbo Force" Bonnet and it is cast with thick wall aluminum and has 4 columns of support for the bonnet in the center section of the bonnet.
A very well designed part.
Old 10-11-2014, 10:08 PM
pont406's Avatar
pont406 pont406 is offline
Thumbs up
More cool performance parts for a traditional engine! Thanks guys for making these!
1966 Lemans, 3700Lbs, 406 ci, #96 Heads, Crane 467/494 cam, RPM Intake, Q-Jet, 11 inch Converter, 3:90 gears, 3 inch exhaust, Best ET 12.62@107 MPH 414ci shortblock coming soon!
Old 10-12-2014, 10:52 AM
Bnick166's Avatar
Bnick166 Bnick166 is offline
PM Sent....
Old 10-12-2014, 07:53 PM
bankbook's Avatar
bankbook bankbook is offline
What is the plenum volume?
DOC'S TA
Turbo 535, CV 1 heads.
Built by Cerralli Competition Engines
Tenth Anniversary (Van Nuys) restored.
Tenth Anniversary Barn Find (Norwood)
Both 4 speeds!
Old 10-13-2014, 09:00 AM
900HP's Avatar
900HP 900HP is offline
This manifold is designed for boost. It will take 30+ psi and can be ordered with thicker carbon if desired.
Throttle's Performance
(701) 893-5010
https://www.facebook.com/pages/Throt...70911996281602
Old 10-13-2014, 09:02 AM
900HP's Avatar
Originally Posted by Bnick166 View Post
PM Sent....
No PM, sorry
(701) 893-5010
Old 10-13-2014, 09:06 AM
900HP's Avatar
Originally Posted by ho428 View Post
But will it fit under a FGF hood?
Just kidding, very-very nice piece. But hmmm, will it?
I don't know what an FGF hood is but the overall height of this manifold is less than a Super Victor with a 4150 and an air cleaner on it.
The only issue I see with height is at the front as this manifold is tallest at the front and that is where the hood would be sloping down.
This manifold isn't intended for traditional restorations and if you are at the point where you need/want this manifold the hood is a secondary concern.
(701) 893-5010
Old 10-13-2014, 12:10 PM
69FIREBIRD76MM's Avatar
Can it be installed facing rearwards?
Old 10-13-2014, 12:39 PM
900HP's Avatar
It can be ordered that way.
It can also be ordered with a carburetor top instead of the forward facing throttle body as well.
(701) 893-5010
Old 10-13-2014, 02:41 PM
marks73ta's Avatar
marks73ta marks73ta is offline
There you go carb guys. Do you have a pic of the full carb top manifold?
Mark
My Gasser '63 Catalina build. Oh sorry, it's a Street freak. Either way it's a fun build.
Old 10-13-2014, 02:59 PM
900HP's Avatar
Mark
No pictures. You would have to call Performance Design on that. The intent was never to do a carb manifold but they CAN do a carb manifold, it wouldn't be that hard. You would have to eliminate the ram tubes for fuel distribution which would make the manifold more of a traditional tunnel ram.
Performance Design can incorporate about any change you would like to see to fit your needs.
(701) 893-5010
Old 10-13-2014, 03:16 PM
johnta1 johnta1 is online now
What's the bolt pattern on the throttle body pad?
Would a Toilet fit on it? (basically Holley pattern)
Old 10-13-2014, 03:20 PM
900HP's Avatar
The bolt pattern is 4.5" square and the throttle body is 125mm (almost 5"). You could order the flange for a 4150 or 4500 pattern (toilet) but I see no reason why as the 125mm moves more air. The 125mm is available from KCS (like ours) or from Accufab (not quite as nice but still sweet)
The bolt holes around the outside are for attaching things like throttle cable brackets and what-not.
(701) 893-5010
Old 10-15-2014, 09:01 AM
Bnick166's Avatar
E-mail sent to 900HP................
e-mail sent to Performance Design from the "contact us" link on their website.......came back as "undeliverable.......changed "at" to @ and still came back as undeliverable.
Old 10-15-2014, 09:50 AM
900HP's Avatar
I'm sorry but I missed the e-mail. It's possible it went to my spam folder and I deleted it or it's possible I just deleted it. I had a LOT of email to go through in the last couple of days.
You can re-send the e-mail or you can just call me at 701-893-5010 if you would like.
I can't speak for Performance Design, I am not affiliated with them.
(701) 893-5010
